Question about LG DLE2514 Electric Dryer
Taking cover off dryer
How do you remove the cover
    Scholar:
  • 121 Answers
The top cover or rear cover? The rear cover is usuallyr held in place with a small handfull of screws. You might have to slide the cover off some hooks when all the screws are removed. If you want the top of, you will probably have to remove the rear cover first, then loosen the top cover and slide it off, or slide it slightly then lift it off.
Posted on May 18, 2007
  • robert j sims Nov 03, 2012
    im talking about rear cover ?? do u have to tip it on its side and remove bottom screws then ??
How do I take stacked washer/dryer apart - Kenmore C82062 and C42062. Thank you!
There should be two plastic covers in the front bottom corners of the dryer. Remove the two small covers and then remove the two screws. You will be able to lift the dryer up and forward.
Jun 06, 2011 | Washing Machines
Dryer stopped in the middle of a cycle. Time kept going, drum and motor stopped. Unplugged dryer, check lint and exhaust hose for build up. Plugged dryer back in, when I select time and hit start, dryer...
The motor tripped..The wiring diagram for the dryer is inside the back cover tie-wrapped to the frame as it sounds like the motor has a trip on it:
To reset the switch unplug the dryer, remove the power cable and back cover completely. two screws holding back cover are under the top cover which is held on with two screws at the rear. Remove the screws then pull top cover back and then lift it off. Remove last two screws and take off the full back cover . On the front of the motor you should see two white wires going into the safety switch for the belt breaking. Push the button on the left to reset the switch (you probably will hear a click) Do not push the right button as that is what got tripped originally . Good Luck Tim
Mar 12, 2011 | Bosch Nexxt 500 Dryer
Dryer taking too long tp dry. Removed alot of lint buildup in exhaust system. Does this dryer have a fan and how can I check if it working?
The front of the dryer should be able to come off..maybe with clips maybe a couple screws...first you will need to pop up the top of the dryer with a flat blade screwdriver,then you can look down the front cover to see if there are clips or screws...remove screws/clips to remove front cover and gain access to fan and components...the fan is usually attached to the main motor that turns the drum. you should be able to run the dryer with the front cover removed to see if everything is working.
Dec 19, 2010 | Dryers
Where is the reset switch on the Bosch 3510 dryer
The wiring diagram for the dryer is inside the back cover tie-wrapped to the frame:
The motor tripped?.
Nov 28, 2010 | Bosch Axxis WTA 3510 Electric Dryer
I have a G.E profile dryer dpgt750 cant seem to figure out how to take off the back panel, the dryer is making a loud noise sounds like possible belt problem. any ideals? THANKS MARTY
Marty, you need to remove the front cover on these and most dryers by removing lower front kick panel screws, then remove the front cover and then you access the top cover screws to remove top cover then you can access th drum belt
Nov 17, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Getting back off
you dont, you start by removing the front cover, then you'll see the screws to remove to take top cover off,then remove drum belt and drum and your inside the unit
Oct 03, 2009 | LG DLE2532W Electric Dryer
How do you take the back off of a Maytag Dryer LDE4914ACE? I want to change the belt?
you cant take back cover off, you remove front cover and then access the top cover then you can replace the belt,there is an access panel on the rear you may need to remove to put belt on motor and idler pulleys
Jul 10, 2009 | Maytag PYE2300AY Electric Dryer
I need to take outer cover off dryer to lubricate pulley
if indeed you have an amana NDE2300, hter eshould be 2 5/16 screws across the lower bottom panel, after removing them 2 more screws will release the next bulkhead, and more screwws will become evident as you remove them
Jan 01, 2009 | Amana NDE2330AY Electric Dryer
open door and look for screws going up into top
Jan 04, 2008 | Dryers
LG DLE2514 Electric Dryer Logo
638 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
