Is Zanussi ZFV826 automatic, I chose program 8 and it washed, rinse, spin but did not stop. Started taking water again and looks like washing again. I had to stop manually
rachael
  • 4 Answers
SOURCE: Washing machine stops mid cylcle
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
Posted on Dec 17, 2007
  • 101 Answers
SOURCE: zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Posted on Apr 23, 2008
kevin000
  • 1847 Answers
SOURCE: Simpson Esprit 750 Washing Machine.
the control panel has gone bad needs replacement.
Posted on Jul 15, 2008
michiganfan9
  • 179 Answers
SOURCE: Kenmore model 22432100 - it won't drain or spin
sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
Posted on Dec 29, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
My Zanussi WJD 1257 washer/dryer's drying cycle has started finishing early. No error codes. The wash cycle works fine but the drying cycle is simply stopping prematurely. You can set it to dry for 45...
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Zanussi Washing Machines
Hoover 750 top loader goes through cycle drains but will not spin if you manually put it in spin it will not stop fills up and rinses drains but will not go again into spin until manually do it then again...
Two issues are possible , After the first start of the wash , check if the machine starts only when the water level is reached- to confirm the working of the water level sensor.
Secondly if the program cycles seems out of hand then it is possible there are errors in the program controller unit.
Apr 21, 2011 | Washing Machines
The washing machine is stopping half way through any normal cycle, seems unable to spin then stops. the spin is working on a rinse cycle
Possible that the suspect is the main program controller unit. You will need to check the voltage to the motor during the wash and spin cycle.
If there is no voltage then the controller can be faulty.
Feb 05, 2011 | Zanussi Washing Machines
Machine is not washing, spinning or draining
has someone interfered with the inlet tap. The buzzing is normally a sign that the appliance is trying to take water but tap is off.
Mar 29, 2010 | Zanussi ZWF14070 Front Load Washer
Anussi ZWD 1271W stops at beginning of program
Did you fix this problem? We have the same with Zanussi ZWD 1472 W. It takes some water and stops after 2 minutes. We need to shut machine down and fill water manually. It works fine then.
Feb 02, 2010 | Zanussi Washing Machines
Nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Jun 30, 2009 | Washing Machines
Zanussi ZWF1437W E23
E23 indicates Drain pump faulty; Wiring faulty; PCB faulty.
The service information also says it should stop with the door open.
Unplug the appliance and manually remove the water via the filter or front drain point if it's fitted.
Drain it into a shallow dish, tighten the filter when you need to stop the water (or plug the hose if draining via a hose) while you empty the container.
Once empty, try the door again.
Take the filter out and clean out any debris in it.
Plug the appliance in and put the machine on a drain programe.
Listen/look at the open filter to check that the drain pump is running.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 27, 2009 | Washing Machines
Zanussi zwf1211w
are the water supply taps fully on ? check that it is filling quick enough. let my know how you get on. also is it heating the water?
Feb 16, 2008 | Zanussi ZWF1430W Front Load Washer
Machine will not empty or rinse
Put off the machine. After 3 or 4 minutes put the control to "spin only" & put the machine on. If this does not work you hv a drain problem which shd be checked......
Aug 27, 2006 | Zanussi F1045W Front Load Washer
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
