Question about Datamax Office Equipment & Supplies
My Datamax E class 4203
Printer will not print? I see a VERY faint print only? Any idea why?
5 Suggested Answers
Labelzone
  • 4 Answers
SOURCE: DATAMAX PRINTER
Hi
Its worth checking that you are using the latest drivers. You should be able to get these from the Datamax website. Also check the printer set up, gap sensor etc. Also check the media is loaded correctly. Hope this helps. Regards Stu www.labelzone.co.uk
Posted on Jun 19, 2008
  • 54 Answers
SOURCE: Regarding Datamax E-4203 - Won't print
Check to see that the label sensor is over the gap in the label. It is just under the head on the right hand side.
You might also have the unit configured incorectly. If you go to the Datamax site, you can download the printer config program, It is easier to use than trying to push the buttons in the correct order to configure the printer.
Also use at least a 6" long label, and print the config file to see if you are set correctly for gap mode if using die cut stock.
Posted on Feb 25, 2009
Nic61
  • 1073 Answers
SOURCE: s there any free software for running Datamax E 4203 Printer? it is meant for printing library barcode labels.
http://www.datamaxcorp.com/software/e-class/
There u go!
Manuals, drivers, firmware and utility for the E-class,E-4303,E-4204 and E4304
Good luck
Nic
Posted on Apr 24, 2009
  • 54 Answers
SOURCE: We can not use our print DATAMAX DMX M CLASS
What type of stock are you using? Gapped, continuous, or reflective mark?
If you are using a standard gapped stock, and the stock is loaded in the printer and ready, press the feed button until 3-6 labels are passed beneath the media sensor.
If you are using reflective (eyemarked stock) go in the the media settings. Change the sensor type to reflective.
Make sure that the eyemark is presented to the sensot at the small white strip on the sensor. Do not move the sensor to a place where the sensor will see anything but the mark.
Posted on Jan 27, 2010
DATAMAX E-4203 ONLY PRINTING HALF OF THE BARCODE
I doubt the sensors would have anything to do with only printing half a label. I'm not familiar with the E-class series of printers, but the common causes of that problem that I've seen before with the larger M & I class printers can be:
1) A piece of label or ribbon is stuck on the printhead.
2) The printhead is not seating properly on one side, causing the printhead to be too far away from the label & platen roller to apply enough pressure in order to print.
3) A printhead cable is not seated fully somewhere and not supplying the signals properly to that half.
4) The main logic board is bad.
5) The printhead is bad.
6) There is a software problem or label configuration setting that needs to be corrected that controls the print width.
Feb 26, 2014 | Datamax DMX E4203 Printer
Barcode scanner won't read printed labels
1. The printhead in your printer might be scratched (evidenced by thin white streaks through your print). This is common, and the most likely cause. Printhead must be replaced.
2. Material might be stuck on your printhead (usually evidenced by wide white streak vertically through print). Printing surface of printhead can be cleaned with rubbing alcohol and cotton ball.
3. The ribbon might be wrinkling due to uneven tension, producing intermittent diagonal streaks in your print. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment and/or proper media loading solves ribbon wrinkles.
4. Poor pressure and/or printhead alignment. Evidenced by grainy, light or no print on one side or the other of the media. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment solves printhead pressure and alignment issues.
Dec 11, 2012 | Datamax E-Class E-4203 Label Printer
Got to work this morning and the thermal printer had continuously printed the previous days manifest until it had run out of labels. I inserted new labels and it started to print the manifest again. I...
Uninstall the printer and restart the computer once installed reinstall the printer from the CD that came with the printer or get the latest software / pilots from the printer's web page
Jul 21, 2011 | Datamax E-CLASS DMX-E-4203 Label Printer
Please send your dealer address in kolkata or orissa in india
PRAJOOKTI
4/16 FERN ROAD, Kolkata,India. 700019, West Bengal
p: + 91 0 9433082863 f: + 91 33 24401928
techbelkin
Jan 08, 2011 | Datamax E-CLASS DMX-E-4203 Label Printer
Hi! I have a problem with my office Datamax E class printer. When i change tickets in the printer it doesn't print them the right size - normally they are too short. Do you have any idea how to solve...
If you are changing length(feed length) you may have to recalibrate the printer . Also ensure that your print format is the correct length for the stock.
You can look at the setup of the printer using the datamax-oneil printer configutation program, or if it is using IP connection, you can go directly to the internal web page for set up. make the cal length 3 times the label length, or leave at the default value.
Dec 29, 2010 | Datamax E-Class E-4203 Thermal Label...
Only prints ''smeared labels'' with no text even remotely recogniza
You need to alighn your print heads and or buy new ones. Also, the paper must be the right specified paper or it will blotch or smear.
Feb 19, 2009 | Datamax E-Class E-4203 Thermal Label...
DATAMAX PRINTER
Hi
Jun 19, 2008 | Datamax DMX E4203 Printer
May 16, 2008 | Datamax DMX E4203 Printer
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Joseph Mueller
Joseph Mueller
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
