Installed H/P 6300C scanner now epson C60 wont print any idea how to remedy ? lite for out paper or ink comes on text says communication error . Many thanks *****
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 98 Answers
The H/P 6300C can be plugged right into you router using a network cable. then you can plug your epson C60 back into your computer.
Posted on Jan 04, 2009
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Printer has ink, is properly installed and connected to the computer but when you command it to print the paper comes out with no writing
Do printing normally but nothing witing at all? Problem with board. Lost electrical to head (micro piezzo). Search on aicaxz solution for reference to solve this.
Dec 31, 2009 | Epson Stylus C60 InkJet Printer
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson c60 printer not compatable with windows vista need a driver but have no idea where to download it
The driver for the Epson C60 printer is included with Vista - all you need to do is connect the printer to the computer with Vista running and turn it on. If you have already done this and the printer does not work properly (but see the info about the Status Monitor below), turn the printer off, uninstall the printer using the Control Panel-Programs and Features-Epson Printer Software, then reboot the computer. Once Vista is running, turn the printer on and it should then install OK.
HOWEVER, the printer Status Monitor (SM) is not included in this process and if you try to install the XP version of the SM, it will not work. Epson appears to have no intention of remedying this problem. This means you have no means of monitoring your ink levels, nor of changing the cartridges, cleaning the heads etc via the computer, although some of these tasks can be carried out via the printer control panel (see your hand book on how to do this).
A good solution is to use the free SSC utility as your SM - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C60), then close the ssc window. Now right click the ssc icon in the sytem tray and choose the SM function you wish to use.
If you have any further queries on this, please post a new comment.
Oct 23, 2008 | Epson Stylus C60 InkJet Printer
Not printing, please help
yohoo
It is usually one of these 3 things. Out of paper, paper is jammed or one of your ink cartridges is out of ink. But make sure your cartridges are seated correctly.
Davecapt
Mar 25, 2008 | Epson Stylus C60 InkJet Printer
My troublesome printer
New ink comes with a strip attached at the ink hole and sensor area, makes sure u ermaove them also try to clean the catridge contacts in the printer
Mar 06, 2008 | Epson Stylus C60 InkJet Printer
Printer paper won't feed
Dear Queenbee1
plz visit following website for details:
http://www.epson.com/cgi-bin/Store/support/supDetail.
Dec 12, 2007 | Epson Stylus C60 InkJet Printer
Epson C60 Stylus Status Monitor Does Not Work On Windows Vista
-As the driver is part of Windows Vista, there is no Status Monitor available for your printer. Some printers may have an INK LEVELS options included as part of the resident driver. Otherwise, the printer does have its own indicators. The RED error light will flash when the printer is low on ink and go solid when it is out.
-If the ink levels do not appear, click GET INK LEVELS from the MAIN tab of the printer driver. Ensure the printer is directly connected to the computer as the Ink Levels does rely on full bidirectional communication.
Oct 11, 2007 | Epson Stylus C60 InkJet Printer
It will not print.
Hi Greenhorn, Your info is slightly conflicting - I think. As I remember the C60 has just 2 LED's: 1 - Green for Power 2 - Red for Error The third button - Cartridge exchange - has no LED Now it is a while since I looked at a C60 and my brain leaks like a sieve, but that's the way I remember it and feel free to correct me if I'm wrong. The error codes I remember are: Printer status - Indicators - Priority Power - Error Power ON condition On - Ink sequence Blink - Ink Cartridge change mode Blink - Data processing Blink - Paper Out *1 - On Paper jam condition *1 - On Ink end (Black) *1 - On -> Blink Ink level low (Black) - Blink-> Blink Ink end (Color) *1 - On -> Blink2 Ink level low (Color) - Blink-> Blink2 Ink end (Black and Color) - On -> On No Ink Cartridge (Black or Color) *1 - On Maintenance request (Ink Overflow Countererror) *1 Alt Blink Alt Blink Fatal error *1 Off On Special setting Blink2 Blink2
Mar 27, 2007 | Epson Stylus C60 InkJet Printer
jasbo
jasbo
