Question about Generac Guardian Electrical Supplies
I HAVE A 20 KW GENERAC--MOD 0055251-NEXUS TRANSFER SWITCH- 2 BATTERIES IN A ROW WILL NOT HOLD A CHARGE. ANY IDEAS?
CarlGehrke
  • 169 Answers
SOURCE: 10kw Generac shut down overspeed
Make sure that the throttle linkage is all there and not damaged/misadjusted, then get a manometer and check your inlet gas pressure. Gas pressure should be 8 inches of water column and stay there running or not.
Carl
Posted on Apr 06, 2009
  • 33 Answers
SOURCE: Generac control wires
older model Generac only haver 4 control wires:
N1
N2
23
194
if it is the included wiring harness the wires should have their numbers stamped on the jacketing and a sticker should designate the proper screw to mount it to in both the ATS and the generator housing. hooking these wires up incorrectly often results in blown fuses and/or damage to the control board in the generator.
Posted on Dec 01, 2009
SOURCE: When utility power goes out, the transfer switch doesn't transfer
Call an electrician.
Posted on Jan 23, 2010
GeneratorDan
  • 44 Answers
SOURCE: 5875 generac starts running when switched to auto
Check the N1 N2 fuses in transfer switch one or both of them are probably blown. N1 N2 fuses have the yellow wires on them if they are blown the generator thinks there is no utility power and will start There needs to be 220 volt on them .
Posted on Nov 06, 2010
  • 3 Answers
SOURCE: I have a 10 KW Generac Guardian Stand By withe a
Hi, I have a 10kw Generac Generator and I went out to check on it to see that all was working and saw the display panel blank. The generator wont turn over. This was installed 3mos ago and all was fine. It has an automatic transfer switch in the main panel. I tested to see if the gen was getting power from the 2p 15amp breaker and showed power to gen. I think it might be the battery charging system were can I find this?
Posted on Feb 27, 2011
Coil smoked on start up
THIS SOUNDS LIKE OIL IS LAYING ON TOP OF THE PISTON.
Apr 08, 2013 | Generac Guardian 200 Amp Transfer Switch...
Under voltage alarm /shutdown on generac 10 kw gen.
The brushes on Generac automatic units are most likely not lined up with the slip rings and will wear down and burn out very fast. There is no way of checking this during assenbly because they are hidden from view and the generator has to be dismantled to be able to replace them. It's an extremely poor design and Genrac should face a class action lawsuit for producing this piece of junk.
Sep 18, 2012 | Generac 6051 Guardian Series Air-Cooled...
How do I remove and oil seal from a generac 20 kw set
The flywheel side or the PTO side? In either case you need to disassemble the unit to get at the end and then use a hook to pull the seal out.
Aug 27, 2012 | Generac Power Systems Generac 5525 20 Kw...
No lights are lit on my Nexus Remote monitor for my Generac standby generator. The generator is working - just went through the testing cycle. Batteries are less than 6 months old. Maybe I need to...
batteries only last about 3 months on these units. make sure you are within 20 ft of the generator and put in new batteries. The green light will blink is a minute or so.
Apr 23, 2011 | Generac Power Systems Generac 5928 Nexus...
Just finished installing a 20 KW Generac generator (fueled with natural gas). The included transfer switch will not automatically transfer to the generator, but transfers back to the utility without...
Check the connections on the tranfer relay and two coils. The two coils have blue wires. I have seen them come off from assembly or shipping its common. Each coil has two blue wires #8 and E1 with crimp steak ons and limit switches make sure there all pushed on all the way. Hope this helps
Mar 09, 2011 | Generac Guardian RTSE200A3 200 Amp...
5875 generac starts running when switched to auto , Utility is hot .. using nexus smart sw.
Oct 31, 2010 | Generac Guardian 200 Amp Transfer Switch...
Electrical Supplies Logo
57 people viewed this question
Top Generac Guardian Electrical Supplies Experts
jdthefixer
epangan29
ken skalski
Are you a Generac Guardian Electrical Supply Expert? Answer questions, earn points and help others
