Question about Electrical Supplies
Craftsman 2100 watt generator owners manual - Electrical Supplies
mamicheddy
  • 79 Answers
SOURCE: I have a Generac portable generator 5000 watts, won't start!
I am assuming the generator worked fine before the oil change. Now that you have done the oil change the genset does not start. These generators have a safety switch, which is basically an oil pressure switch that keeps the engine from running when there is not enough oil in the engine. Make sure that there is enough oil and if there is, look for a wire that runs along side of the engine to a round component. disconnect that wire and try starting. If it does not start then try to ground out the wire to the engine block. If this does not work, then there is other engine problems.
Posted on May 08, 2009
mamicheddy
  • 79 Answers
SOURCE: Need Owners Manual
The best place to obtain manuals at a discount price is - repairmanual.com
Hope this works for you.
Posted on May 09, 2009
  • 112 Answers
SOURCE: Is there anywhere I can download the pdf file -
http://pdfcatch.net/ebook/coleman+generator/
Posted on Jul 24, 2010
  • 10 Answers
SOURCE: How do you remove the
The rotor is attached to the crank via taperlock. You must remove the rotor bolt which goes thru the rear bearing. Then take a 3 LB. rubber or deadblow hammer and sharply strike the rotor on the laminations. not the winding. You usually have to do this several times from both sides before it breaks the taperlock free, Use force behind your hammer swing, It will eventually come off. Have patience.
Posted on Aug 31, 2010
Homelite HG600 Lightnin'bug generator. Where can I get an owner's manual?
Homelite Vintage Camping Generator - HG600 Lightnin Bug ...
? 1:23
www.youtube.com/watch?v=Amq5VLOsiN8
May 6, 2014 - Uploaded by david lum
For Sale: Great Generator 500 watts - quiet - looks like new - starts easily. Complete with owners manual.
Sep 25, 2015 | Electrical Supplies
Craftsman 5600 watt generator won't stay on and white smoke pours out when started.
try running it with nothing hooked up if it runs fine, then the power draw is to much for it that would cause it to hunt !!!
Jan 30, 2013 | Craftsman 5600 watt Generator
Just up graded from a homelite 4400 to a craftsman 5600 generator 5600 does not have enough output as did the 4400 why
Some manufacturers tend to fudge the numbers and throw around the 'peak' output power as continuous and it isn't. Peak (or surge) is the power a generator will handle as starting current (for example) for a motor and can be 120-140% of the actual continuous power.
Check you owner's manual, find the detailed specs which will normally contain the maximum continuous current rating. If it is listed separately for 120 and 220 (240) volts look for separate current ratings for each output.
By multiplying the current(s) times the output voltages you can find the total resistive output into a purely resistive load such as an electric heater.
For example: 120VAC X 20 A=2400 watts. If other outputs are available such as 220VAC, multiply its current rating: 10A. or 2200 watts Adding those two results 2400 2200=4600 watts will give you the rated power of a unit.
You can also recognize stupid power claims if the engine's horsepower is given. One (US) HP = ~746 watts. Since no generator is 100% efficient, its a fair rule of thumb to guesstimate the available electrical power at ~70% of the engine's rating (although, this is often also wildly optimistic). 10 HP X .7= ~746 X 7 or a bit over 5,000 watts.
Oct 03, 2010 | Craftsman Electrical Supplies
No spark for a craftsman 2100 watt generator
Get the Sears model number from the machine and go to: www.searspartsdirect.com Look to see from the drawings whether the engine is a points/condenser magneto or a composite ignition module. If it's a magneto system, the points may be dirty or mal-adjusted. The composite module is totally self contained and must be replaced if faulty. Make sure that the stop switch and wiring is working correctly. Hope this helps!
Dec 20, 2009 | Garden
Nedd owners manual, parts list and warranty info.
you have got a china copy, hard to get bits for.
whats the prob u got with yours
Jan 16, 2009 | Sunpentown 2,800 Watt 6.5HP Power...
Electrical Supplies Logo
159 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
