Question about Kenmore 21.7 cu. ft. Top Mount Refrigerator w/Factory Installed Ice Maker
Water standing under drawers of Kenmore fridge
I feel that this is something to do with the drain tube as it is probably clogged. Where is it? Model No. 106.7184101
  • Kenmore Master
  • 8,220 Answers
More than likely the working end of that drain tube is located just above the compressor where the water can drip into a pan on top of the compressor and help keep the compressor cool.Get some compressed air and blow it out at that point AFTER you thaw out the ice box.
Posted on Jan 04, 2009
I have a problem with my Samsung model no. Sr-L628EV water gathers under the chiller drawer, any idea?
Not familiar with this particular model, however it sounds like a plugged drain. Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged with gunk, resulting in standing water at the bottom of the refrigerator. (A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer).
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Try c
learing the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
Jun 12, 2017 | Samsung Refrigerators
Water leaking out from inside and running out under the fridge. Do I need to clean out the outlet pipe and if so where would it be??
Check the drain tube that leads to the defrost pan under the fridge. The drain tube maybe plugged. Do you have water standing in the bottom of the fridge and if so that is probably the problem. However, something must be defrosting inside the fridge to create that much water. Be sure your fans are running inside the fridge.
Jan 08, 2016 | Refrigerators
Kenmore refridgerator with top freezer is leaking water from bottom of vegetable drawer
There's a drain line for the defrost cycle that's likely just plugged up. Sometimes you can find it from the drain pan located under the fridge and if you snake a long piece of weedwhacker line or something similar up the tube, you can sometimes clear it.
Good luck.
Mar 19, 2015 | Kenmore Refrigerators
My Kenmore Elite Trio Fridge is leaking water from under the front of the machine. It is not the water connection. Do you know what the problem might be?
Your defrost drain tube is probably clogged with ice or something. Defrost your refrigerator (put towels around to soak up any excess water), then after it's defrosted, take off the back, lower panel and look for a 1 inch diameter tube coming down from your refrigerator. Remove it and clear out any blockages and then re-assemble everything.
Oct 15, 2014 | Kenmore Refrigerators
Freezer drain tube clogs causing water to drain
drain tube is clogging with debris or freezing? is there a pan under your fridge with a float valve on it, these pans are usually heated and the water evaporates, except when the factory doesnt hook up the wires, because it wont pass the eer rating, you can hook up after you, the consumer has purchased it , i know it sounds dumb but thats what viking does as well.
check that pan under your fridge and see if there are extra wires that are unplugged , plug them together(2) and good luck.
initially you will have to shut your fridge down for a couple of hours to defrost, but once you restart you should be good,
empty that pan under the fridge for now as well
Oct 10, 2009 | Kenmore Refrigerators
I have a kenmore refrigerator model 36369262991. I have water accumulating on my top shelf. It drips from the thermostat control panel. what is wrong?
I had a similar problem on a Whirlpool Fridge. In fact, there is a good possibility that your Kenmore is made my Whirlpool. As you probably know, Sears doesn't make appliances, but contracts with well-known appliance makers to manufacture kenmore-branded products.
If your fridge is an auto-defrost model, whenever it auto-defrosts, water from the melted ice collects in a tray behind the freezer, and drains into an evaporation tray at the bottom of the fridge through a drain tube. Over a period of time, the drain tube can become clogged, and instead of draining out of the freezer, the water overflows into the fridge. The clue is that the problem is intermittent -- the dripping stops between defrost cycles.
The fix is to remove the liner panels from the freezer, melt and sponge out any collected ice, clear ice from the drain with hot water, and clear any gunk from the drain tube with compresssed air or a flexible "snake." I used 1/8" pvc tubing as a snake.
It isn't hard to do, but if you are nervous about disassembling parts of your fridge, you will need to get a pro to do it.
Jun 29, 2009 | Kenmore Refrigerators
Water is not draining into pan. it is going inside fridge under
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Mar 17, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Whirlpool has water drip inside fridge
Oct 25, 2008 | Frigidaire GLRT212ID Top Freezer...
Fridge filling with water
There usually is a drain at the back of the fridge it's possible that this is clogged, This drain leads to an evaporation tray usually in the base of the fridge.
Oct 09, 2007 | Kenmore 94499 Refrigerator
Clogged fridge drain tube
The drain is behind the back panel in the freezer at the bottom. Sounds like it is frozen over which is pretty common. Will need to remove panel and thaw out drain by running hot water down. You can use a putty knife to break up ice first. Make sure you get all ice around the drain above and below the thin aluminum tray at the bottom. After the drain is free don't be alarmed if you get some water on the floor because the drain pan may not hold all of the water you ran down the drain. Not anything you can do to prevent this on this model.
Oct 07, 2007 | Refrigerators
Kenmore 21.7 cu. ft. Top Mount Refrigerator w/Factory Installed Ice Maker Logo
256 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
