Question about Toshiba Televison & Video
Toshiba 26c3030. Using Freeview, only BBC1. No signal message appears
TV previously plugged into sky box at friend's house. Now using freeview can only get BBC1. 'No signal' message appears. Could it have lost its settings in recent switchover?
4 Suggested Answers
  • 49 Answers
SOURCE: Hitachi TV - no signal on DTV since switchover
Hi It sounds like you need to re-tune your DVB-Tuner on your TV, NOT the old analogue one, it'll be in settings or setup, or installation and use the "First Time Install" option, because it clears all old channels and loads all fresh new ones! hope this helps!
Posted on Dec 06, 2009
  • 3 Answers
SOURCE: bbc1 1nd 2 not on my freeview TV after several
reset the TV to factory settings and try again
Posted on Feb 13, 2010
  • 909 Answers
SOURCE: lost our freeview
if you have connected your sky box as per instructions, putting the aerial coax to it and a fly lead(as in a male to female coax as used on a vcr to tv) from the output to the tv's aerial input, then disconnect the aerial from the sky box and put it back to the tv. The skybox will weaken and even loose the signal.
Posted on Feb 14, 2010
Tv is 4 years old yesterday it lost its built in freeview channels. when trying to get the menu up it appears for a second then goes off. Tv still receives sky and picture is good
Hello pip_o
It's possibly a defective digital tuner, but the vanishing menu suggests a more serious (and expensive) fault with the main/AV board, assuming it's an LCD TV. It's impossible to be certain which one without doing some testing, but due to the inherent dangers with high-voltage electronics, I don't advise on self-repair for TVs.
If you're looking for an inexpensive solution and the TV is no longer covered by any warranty, I'd suggest buying an external Freeview box to connect to your TV. This would also enable you to upgrade to Freeview HD. Being 4 years old, your TV will not have been fitted with a DVB-T2 (Freeview HD) tuner.
If you want to try this solution, I can recommend the following box, which is great value at just £25.
http://www.ebay.co.uk/itm/270828771661
They are described as "reconditioned", but I've bought and installed 2 of these for my own customers recently and both have been brand-new. The majority of these are unused returns which Tesco are consequently not allowed to sell described as "new". For a lesser known brand, I've been quite impressed with some of the recent Technika products and they are easy to install and come supplied with all the necessary cables, etc. Additionally, if it doesn't work for any reason, you will be able to return it under UK Distance Selling regulations.
Before purchasing this (or any other) Freeview HD box, please check your TV has a spare HDMI input socket as SCART cannot carry an HD signal. If you don't have a spare HDMI socket, I'd also check your TV has a spare SCART input socket or you will need to disconnect your Sky box every time you want to use the Freeview box - which brings me to my final point . . .
. . . Off the top of my head, I can't think of any Freeviews channels which aren't available on Sky, so as long as you can still use your TV for Sky, do you really need to spend any money on it?
Hope this helps. Please let me know if I can be of further assistance.
Regards,
BElectric
Oct 09, 2011 | Televison & Video
I have an LCD HDTV BLA. I have Freeview and
Hi.
If you are using an external freeview box you need an HD box (See available products).
If you have an LCD TV with built-in HD tuner (TV will say HD Ready and will have internal tuner), then you can use the TV internal tuner.
The best way to get HD is via satellite. Althought HD Freeview is theoretically available since end 2009 I have not been able to receive any HD channel using Freeview tuner, and I live in a London area where HD FV is supposed to be available since 2010.
Even with Free Sat the choice is poor. You get steadily only BBC HD, where at most you can watch some documentary or drama series (it is a kind of sample channel). ITV HD, BBC1 HD and the rest frequencies on Astra change Sat quite often. I am a TV technician and the sat tuning job is not difficult to me but retuning every month was still an awful waste of time.At the end I gave up and I only watch HD through Sky.
At the end of the day the only efficient way to receive HD TV is still through Virgin or Sky.
Regards.
Ginko
Sep 01, 2011 | Samsung Televison & Video
Sky is saying there is no signal. Turn box off and on again. I have done this but still get no signal. I have freeview only channels on my sky box
Firstly, you don't get Freeview through your Sky box. If you are watching Freeview channels then it's from an aerial connection. If you are getting a 'No signal' message on your TV, the first things to check are:
1. Check that you have selected the correct input source on your TV. If you are using a 'co-ax' connection (standard aerial cable) you will have to select this manually from the remote. If you are using a SCART connection, all you need to do is turn the Sky box off and back on - but you've done this already.
2. Check the connection from your Sky box to your TV - disconnect it, check that the cable and connectors aren't damaged then re-connect it.
3. Check the cable between the dish and the Sky box. Unplug this from the Sky box and reconnect it.
4. Check that your viewing card is correctly inserted. This is unlikely to be the problem as it doesn't usually result in a 'no signal' message, but remove it and re-insert it anyway.
Finally, it's very windy tonight and this can affect the Sky signal if your Sky dish isn't properly secured. It's possible that your dish has been moved by the wind and is no longer aligned with the satellite. If none of the above work, you should inspect the dish as soon as conditions are safe enough to do so. If you can move it by hand, it can probably be moved by the wind.
Try these tests and post back and I will try to assist further if the problem has not been resolved.
Regards,
BElectric
If your problem has been solved, please be generous and award this solution 4 thumbs-up. This service has been provided FREE - your simple acknowledgement is appreciated. Thanks.
Nov 09, 2010 | Televison & Video
I bought a Toshiba 32 Inch HD Ready Digital LCD TV - 32BV500B yesterday from Argos, Leyland. I tried to set it up and it searched for programmes but did not return and any programmes. It had a blue...
Are you using the freeview tuner, I only ask as it looks like your having a similar problem that I had a few months back. I moved into a new house and plugged in the tv. Using the freeview tuner I wasnt able to get any channels. It turned out although the aerial picked up regular analogue tv it wasnt the correct aerial for freeview.
Aug 17, 2010 | Toshiba Televison & Video
Although the Freeview box is correctly installed with my TV,when the men button is pressed the only message to appear on the TV screen is No Signal,HELP!!
Ok, if you have "No Signal" that can only mean you must be selecting the wrong INPUT, when it is hooked up yo the TV, essentially the TV, is just a Display Monitor, and it doesn't use "Channels" anymore, it uses the AV, or EXTERNAL Inputs, any channel changing is done on the Freeview box. Make sure you are connected color to color, cables are connected. The antenna, goes into the freeview, the AV cables go to TV, taking the Video 7 Audio, from the Freeview box, to the "Screen" TV, set to the External input, that the "Box" has been connected too. Check your manual out.
May 08, 2010 | Televison & Video
Lost our freeview. New TV in bedroom (Sharp LCD, LC-19SH7E-BK), which has freeview and was working fine. However, we set up a magic eye so we can have SKY (which we can now use through channel...
Feb 14, 2010 | Televison & Video
How do I setup my full hd freesat tv I have sky + do I take the dish cable out of the sky box or do I need another cable from the dish
If you really want to do this, well then you could use and antenna switcher, a small control box that the Antenna from the dish plugs into it and the Sky Box & Freeview each, plug separately into that box too, and then, you can select, which one the antenna is connected to. (Some even have remotes) OR you could simply "Split" the signal "IN" with an Antenna "Splitter" and run one feed to Sky & the other to Freeview. Now thats all amusing that you can get freeview from that Dish.
Feb 05, 2010 | Panasonic Viera TC-L32X1 32 in. LCD HDTV
Cannot tune all digital cahnnels on Sharp aquos
Start by doing a factory settings/ defaults on the Sharp rather than a normal automatic retune.This should then be ok. You need to empty the existing presets first so it will find the new type of signal BBC is now using.
If still not working for BBC1 +2 then look at whether you have too much aerial signal strength. (ie a booster/splitter that you could bypass)
Nov 07, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Question regarding audio connections Akai 30" LCD TV
a switch box is needed the s video shares the red/white audio with the yellow rca that is being used already
May 07, 2008 | Televison & Video
Televison & Video Logo
16 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
