Question about Hotpoint Refrigerators
Bushing for bottom right front door CSX24GR
No frost side by side purchased 1993; need bushing for bottom right front door
  • 213 Answers
SOURCE: ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
Posted on Nov 29, 2007
  • 4 Answers
SOURCE: side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Posted on Apr 19, 2009
  • 21 Answers
SOURCE: Frost is forming in freezer of side by side
There may be a switch on inside of refrigerator to regulate the sweat on outside of fridge.Also,door seal gets stretched to prevent good air seal.Open the door and insert a dollar bill. Shut the door,the door seal should be tight offer enough resistence that dollar bill does not freely pull out of door.If it doesn't,replace door seal.Hope this helps. Gregg
Posted on Jun 05, 2009
App King
  • 55 Answers
SOURCE: excessive frost/ice buildup near bottom on freezer
Hello.
If you remove the bottom drawer in the freezer you will be able to see the back of the freezer. You will notice a large build up of ice in the bottom of that panel. If this is the case, you will need to empty the freezer up to the icemaker bucket. There is a panel with several screw in it that you will have to remove. Once removed you will want to defrost as much of the ice as you can with a hair dryer. Once you get the ice down to the hole you will want to heat some water up in the microwave and pour it into the hole repeatedly until it clears the line and drains on its own. This will remove whatever bug of ice particle that blocked it. Put everything back together and you will no longer have this problem.
Posted on Jul 16, 2009
  • 4793 Answers
SOURCE: My Maytag side by side has frost that develops on freezer side
almost deffinately door seal.try hot cloth to warm seal and pull into shape ,close door ,if you look down seal it should stick to door frame all round.no air leaks...
Posted on Feb 11, 2010
Why does my front end Squeek
4 main things to check on your particular vehicle. 1. Check your stabilizer bar bushings, make sure there's no play. 2. Your bottom control arm bracket which hold the non-serviceable bushings is probably the culprit. 3. Upper control arm. 4. Ball joint. Most likely it's your bottom control arm bracket. Spray some silicone on each bushing one at a time to narrow down what it is.
May 22, 2014 | GMC Envoy Cars & Trucks
The front door is not aligned. since the hindges are welded; is the only thing keeping the door straight is the pin & bushing?
  • yea, that's about it other than the frame they are connected too. If you took a hit to the vehicle (bent frame) this could be part of the problem as well.
Nov 05, 2011 | 1993 Buick Century
Hi, I have Frigidaire side by side doors refrigerator about 5 years old. refrigerator door knocks when when I close the door . Is that adjustment problem or some parts worn out and have to be...
It is probably a cracked lower bushing or loose lower hinge. If the hinge is tight, then the bushing is probably bad. It is not a hard part to change. Empty the door then then remove the top door hinge. The door should lift off the lower hinge and expose the bushing. Put in a new bushing, grease it a litte with some Vaseline or equivelent and reinstall the door. This link has an exploded view and part # of the bushing (#22 on the diagram). http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5150332&diagram_id=1239787#d1239787
Hope this helps
Jan 29, 2011 | Frigidaire FRS3R5EMB Side by Side...
Door will not close
Did you take the door off (moving or new purchase) to bring in the house? if you did then you didnt put the door on correctly. never heard of a door go from fine one day to not closing. take door off and make if the bushing is still on the bottom hindge. re attached door in close position.
Mar 27, 2010 | GE Profile PSW26P Stainless Steel Side by...
We'd like to change the door from left opening to right opening on our refrigerator
Good day,
Before proceeding there are a lot of buttons and cover emblems that cover screw holes. Remove by prying off with a small screw driver as needed. As well, remove all food etc.
As well, keep track of all bushing and shims holding the door hinges in place.
1. With the top door closed, remove the top bracket. Open the door with both hands, open approx. 1 foot and lift off.
2. Remove the middle bracket, and remove bottom door as in step one.
3. Remove and reinstall handles on the opposite side of each door.
4. The bottom support bracket must be removed, and remounted on the opposite side, with the pin sticking up.
5. Reinstall in reverse order using bushing and shims as needed to assure correct alignment.
Dec 01, 2009 | Kenmore Refrigerators
1996 lincoln door hinge adjust
Which door is it ? If it is a front door, then it may be the hinge pin bushing that needs replacing. These can be bought at any auto parts store. Get the pin and bushing set because the hinge pin will need to be ground off to remove it. Press the new bushings in with pliers and insert the new pin from the top
Sep 10, 2009 | 1996 Lincoln Town Car
Frigidaire fridge door makes a loud popping sound
You need to take the door off the hinges and remove the lower hinge plate from the bottom of the door. This is where I found my popping problem. The black bushing with the 3 bumps and dips on it is loose in the plate going into the door. I took black eletrical tape and rapped it around the part that goes into the plate to tighten the bushing up so it wouldn't turn anymore. ( This was a temp fix to see if the popping would go away) 3 Weeks later and still working. If the sound comes back I will put some double sided sticky back foam on it. Both doors were doing this on my fridge, and now its as quite as a mouse. I hope this fix works for you.
Dec 29, 2008 | Electrolux Frigidaire Professional Series...
Attach hood prop rod 2001 Ford Focus
First you will need to get a hood prop bushing from pobably your Ford dealer or you can get one from a salvage yard. You may also need a hood rod attchment. In order to attach your hood rod on. In order to allow your hood to close without the rod interfering with the closing of your hood.This can either be obtained at your dealer or salvage yard. Then you will need a 4or 5 foot poll in order to prop your hood.So that you can place the bushing in and also hood attachment bushing.Both bushings snap right in. You will need to take your hood rod and place it in the hole of the bushing the hood rod should have a short bend at the bottom of it.Like an L or 7 the L shape should seat it self into the bushing.In order to erect the rod to hold the hood up.Or in order to attach it on the hood attachment.Before closing the hood. The hood rod bushing for extending your hood rod.In order to hold your hood up.Goes in the side of the inside frame of the body to the rear of the passenger side of the car again it just snaps in. And the hood rod attachment goes towards the front of the passenger side and it also snaps in.It's located horizontal of the headlight.The hood rod bushing is a 2 sided little round shaped plastic bushing just big enough for your hood rod to fit through.And it is usually white. And your hood rod attachmewnt is usually black.
Jul 31, 2008 | 2001 Ford Focus
Front suspension on a 1968 sportster
man its been awhile since i saw one of those. i wish hd still made rebuildable front ends instead of throw away *** units. run your finger to the bottom of bushing to see if there is a lip on the bottom, if so, go to harbor freight and buy a blind bearing removal set if it will go to the size you need. if not, they also sell a slide hammer tool with claws that will work if it will go into the hole. if all else fails, take a hack saw blade and carefully cut the bushing almost through on opposing sides, try not to scar tube. you can then use a small screw driver and work the bushing out at one of the slits, once the tension is gone, it will pick out. other than that, find an old hd shop. as an after thought, there are expanding pipe ez outs which should clamp to the bushing allowing you to pull it out but do not over expand so damage to the tube will not occur.
Mar 25, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Refrigerators Logo
21 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
