Projection Televisions
Problem for Projection Televisions
Generic problem for all Projection Televisions
KP-57WS500 8 blinks will not power on
By dcxguy48080 on Jan 04, 2009
when i turn my tv on it tries to power on and then powers off and the standby light flashes 8 times
no pic or sound at all........power light goes on and then after a few seconds starts flashing 8 times......
can you help me
Comments:
Jan 04, 2009
- i have researched this and it says it could be flyback transformer also
is there any way it could anything to do with convergence?? or no
thaks for asnwering my questions but i dont want to make sure what you say is what the problem is since the part will cost a lot of money and generally non returnable....
i would apprciate anymore input you have
Jan 04, 2009
- also i have 2 other sony tvs same model as this one except smaller screen kp-51ws500 im sure the parts are compatible with the 57 inch kp57ws500
maybe i can try taking the HVB block off the known good one and swap it out to see.......and also cant a bad pic tube cause the same problem??? when a tube goes bad which sony is known for the tv will not turn on correct???
my brotehr said prior to this happening the screen would turn all blue and then power off......but now there is no blue screen or anyting just black and powers off after about 5 secondsd with 8 blinking lights
i appreciate your help
Jan 04, 2009
- i also looked it up and here is what it says for 8 blinks
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and
blinks the self-diagnosis code. Check IC406 audio amp, PS401 and
402.
i dont see flyback or HVB in the description at all
i really would like to fix this tv i can solder and desolder very well
Jan 04, 2009
- thank you
Solution #1
posted on Jan 04, 2009
Not Rated)
ladywinn
Rank: Guru  Televisions & Videos  Expert
Rating: 86%, 890 votes
High Voltage Splitter Block #8-598-955-32 8 Blinks Call MAT electronics 1-800-628-1118 or Electronix Parts 1-800-223-3205 or you can go to thier websites online.
Comments:
Jan 04, 2009
- OK ,I have the List of sony Blinking codes i also am a member of a Teamworld of nothing but Electronic Techs trading repair Tips with other TV shops. Yes it does say on some sony sets this code means that T8005 FBT or other componets in high voltage circuits, next stop High Voltage Block try the one out of your other set see if they have same Part # on them. There is also a Self-Diagnostic Mode when set shuts down you can see what codes come up on screen .Press display,5,vol- then power.
Was this helpful?
Yes
No
Popular Solutions for Projection Televisions
Questions and Unsolved Problems for Projection Televisions
Answer
Sony 51 in projection TV, left are right sides are white with a snowy picture in the middle, will... (More)
Answer
i have the same tv the problem is sound is cumming and there is no projection..not able to c the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in , AR
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
