Question about Traulsen Refrigeration 48'' Wide x 24'' Deep Reach-In ''Ultra'' Wine Refrigerator With 2 Clear Blac...
Traulsen URS 48 DT Freezer in Freeze/Thaw Cycle/Fridge Side O.K.
We purchased our Traulsen Ultra Side By Side Freezer/Refrigerator (incl ice maker) in 1993. We were away for 3 days over New Years and returned to find that all the food in the freezer section had thawed. The ice cubes in the ice maker drawer had fused together in a lump.  Refrigerator section was normal temperature. We tried reset and fiddling with the two temp dials, as well as turning the two switches on and off. After a couple of minutes or maybe more, we noticed the temp in freezer beginning to drop AND the fan was working. We were relieved, until 4 hours later, the temp began to rise again and the fan was off. It appears the freezer is doing a very dramatic temp up and down cycle. Any suggestions or ideas? We are in a rural area and have asked the local appliance man to come out Monday but he didn't sound like he really had ever dealt with such a high end fridge/freezer (it was rated as a commercial unit when we bought it and we gather from info we  found on the site that they don't support such units any more.  It is 15 years old BUT it cost $10,000 back in '93 so we hope we don't have to replace the whole unit. Thanks in advance for any help!
  • bjgibb Jan 05, 2009
    Thank you for your quick response AND two good suggestions which I will run past our appliance service man when he comes here this afternoon. I am not sure where the thermostat is or the defrost timer is so perhaps he can locate and check. I will report back later. Thanks again.
  • bjgibb Jan 17, 2009
    As promised, for any Traulsen owners in the future, who may experience my problem - the compressor relay and the defrost timer were replaced (cost $45 Can and $Can respectively) and everything is working normally now!
    Problem Solver:
  • 16 Answers
I'm not intently familiar with this particular brand, but here's some ideas to check. If the thermostat sticks on, the freezer coils can freeze, blocking air flow and jamming circulation fan. This will cause the temp in freezer compartment to rise. When the ice on the coils thaw, the compartment starts to cool again, but the cycle will continue. Another thought is if this unit has a defrost timer that could be defective. Without seeing the unit, it's hard to determine the exact cause.
Hope this helps.
Posted on Jan 04, 2009
What does Er 1F mean of the control panel?
I believe the 1F error indicates a problem with the ice maker. This could be an issue with the ice maker fan icing up, the fan motor failing or the PCB board that controls the fan. First try unplugging the power to the refrigerator for 8 hours. This may reset the error code. Next check if the fan is spinning freely. If the fan has iced up, then the motor could fail from the attempt to spin the fan.
If you add a comment with the full model number, I may be able to give you the parts information. (Look inside the refrigerator for the model number; there is usually a plaque with that data on the side of the fridge.) If your refrigerator is under warranty, contact Kenmore.
I hope this helps.
(If you turn off the ice maker after resetting the code, you probably won't see the error again.)
May 14, 2015 | Kenmore 72093 Elite Stainless Steel 32.5...
Traulsen Ultra freezer quit and right wall is leaking water--why?
The fridge is twenty eight years old and not worth putting another dime into it. A fridge that old will just keep dimeing you to *****.
Mar 06, 2017 | Traulsen Refrigeration 48'' Wide x 24''...
Ice Cream In Freezer Is Soft
DON'T BY ICE CREAM! LOL Try putting ur ice cream somewere else
Oct 26, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Leak to under ice cube tray causing drawer to freeze shut.
May be your freezer evaporator drain hole is frozen. If this is the case, you can try to install a low heat drain hole heater into the drain hole and connect the wires with the defrost heater.
Jul 04, 2009 | Traulsen Refrigeration 48'' Wide x 24''...
GE Adora Side by Side Refrigerator Ice maker
You may ahve a problem with your freezer temp. Check your setting. Turn down a few notches to see if problem goes away. Also Pull out your fridge and vacuum out your coils underneath unit. Plug coil causes freezer temp to rise. Rus
Jul 04, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Frozen foods collecting ice crystals in my freezer
Your freezer is getting too warm during the defrost cycle, causing condensation in your veggies and eventually freezer burn. Likely your door seals are leaking as well after 17 years which introduces even more humidity into your freezer, but I'm assuming your talking about sealed bags of veggies? You need to decrease the temp in your freezer. Get a thermometer and make sure you average around zero degrees. The cause? When is the last time you cleaned the coils at the back of the fridge. Or if they are sealed, perhaps you need to have it serviced. You can try moving your freezer setting to a colder setting it may take care of the problem.
May 20, 2009 | Traulsen Refrigeration 48'' Wide x 24''...
My GSS22SGRE Side by Side freezer & Refrig temp is too warm
Possible the defrost thermostat is bad and need to be replaced. Not allowing the evaporator coil ice buildup to melt , which acts like an insulation and restricts the air flow in the freezer compartment.
Jul 31, 2017 | GE (PSS26MSRSS) Side by Side Refrigerator
Hello margrek
Ice has bad odor and taste.
1• Ice has picked up odor or
flavor from strong food stored
in refrigerator or freezer.
2• Water running to ice maker
has poor taste or odor.
3• Ice not used frequently enough.
4• Cover foods tightly. Discard stale ice. Ice maker will
produce fresh supply.
5• Add filter to water supply line. Consult a water purifying
7• Discard stale ice.
Please remember to leave a rating!
Oct 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
Ice maker stopped working and no Water in Ice maker,,,
I had this same thing happen and I just fixed it! After returning from a long trip, I threw out the old ice (now mostly shrunk), but no new ice was being made. The tray where the ice is made was completely empty/dry (maybe any ice cubes there had "shrunk" away to nothing as well? perhaps part of what keeps the freezer "frost free"?).
So I filled the tray with water using a small measuring cup -- which is what the manufacturer suggests when the refrigerator is new. Now it's making ice again just fine! This might or might not work for you, but trying it won't cost you anything.
Aug 27, 2007 | KitchenAid Superba Architect KSCS25INSS...
Furniture Logo
1,430 people viewed this question
Top Traulsen Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Traulsen Furniture Expert? Answer questions, earn points and help others
