Turco gas heater conversion kit natural gas to lp
SOURCE: LP Conversion Kit?
I'm looking for the same thing! My kitchen is covered in black soot and the inside of my new oven is BLACK!!!
Posted on Jan 06, 2008
hotuna
  • 288 Answers
SOURCE: changing lp heater to use natural gas
Yes. the orifice has a tiny hole in it.It is located at the tip of the pilot before the flame, and at the tip of the injectors. Natural gas and propane molecules are different sizes in the vapor state. The orifice regulates how much vapor comes out. You need to change the orifice in the pilot and the burner injectors for it to work properly. If you don't you will get a very large flame or a very small one, depending which way convert from. If you have the papers from the company that made the heater, they should be able to help you changer over. You also may need to make some adjustment if you are at high altitude, 2,000' or more, as the air is thinner (less oxygen) so the regulator needs to be set to higher volume.
Posted on Mar 10, 2008
SOURCE: natural gas conversion
I have a similar problem. But, I want to convert it to propane. I have a 5 burner vent free modelMN300HPA. If your are handy. I would consider shipping you the parts inside mine to install in yours. These parts are very simple to remove after removing the access panels. I have taken mine out already. Called procom then to no less find out the propane parts needed are not sold by them. I think only the injectors (5) the main valve (regulator) and the pilot are the only things need to change. When taking out the pilot this is easly done, By removing the nut on the supply line. And then bending back the retaining tabs to then slide back the pilot then it comes out of the assembly bracket. Injectors are simply removed. Regulator located at the bottom is a simple remove. The only other item that might be questionable would be the valve that selects the amount of burners you would like to operate. And I would think this would be the same and not need removing. Let me know if I can help. I would like to get mine converted to propane. Thanks Tom
Posted on Nov 06, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: switching from natural gas to lp gas
yes, have a qualified technician do the conversion. You will need to order the conversion kit. It is listed in the back of the installation manual (available on-line).
Posted on Dec 05, 2008
  • 108 Answers
SOURCE: Dyna-Glo natural gas space heater to propane gas.
Yes it is possible and a good idea. You need to have a regulator installed to reduce the pressure to the heater and this is a simple procedure. Contact your local Propane distributor and they will probably do this free to get your business.
Ray
Posted on Dec 09, 2008
I have a GWH1600h LP. can this unit be converted to natural gas with orfice change? If so, where to obtain the part. Thx much. Al
The 1600 series Bosch tankless water heaters, including the GWH1600H LP water heater, do not support a LP to NG gas conversion. Bosch does sell a gas conversion kit, 8719002176 , for the 2400/2600 and a few other water heater models. See http://www.prowaterheatersupply.com/bosch-therm-gas-conversion-kit-8719002176.html for the applicable models.
I wish that I had better news for you. See http://bosch-tankless-water-heaters.blogspot.com/2012/05/gas-conversion-for-bosch-retail-gas.html for some of the details. (The professional model water heaters are more likely to support gas conversion. However, it depends on the specific water heater burner/exhaust designs.)
Mar 05, 2017 | Kitchen Ranges
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Gas conversion lp kit 8927 has 2 pilot orifices...I only need 1, correct?
The smallest pilot orifice is used for LP. Make sure you read the instructions thoroughly. Usually the gas valve pressure regulator is disabled and the burner orifices are also changed. Good luck and hope this helps.
Aug 11, 2014 | Williams Wall Heaters: 30,000 Btu/hr...
LRG3095ST I need the conversation kit to switch for LP to natural gas
http://www.appliancepartspros.com/lg-conversion-kit-asm-ebz37171903-ap4448315.html
Jan 10, 2013 | Kitchen Ranges
Change orfis in water heater
Do NOT do that.
If you put LP gas to NG heater you can cause explosion.
Contact manufacturer and see if they sell conversion kit. Most do not.
Copy following link for general overview and cautions:
http://waterheatertimer.org/pdf/Convert-Natural-Gas-water-heater-to-LP-heater.pdf
Jul 11, 2012 | Water Heaters
Is it possible to convert a rinnai avenger 25 from natural gas to lpg?
Yes it Should but you will want to check with manafactuer because it will need a conversion kit for lp gas. Natural gas is a different p.s.i. than lp gas so don't try without conversion kit. It should be just a small fitting that goes inside the gas valve. Hope this helps have a good day
Aug 12, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Switching from natural gas to lp gas
Get in contact with the appliance manfacter, ask them for a conversion kit and if it can be done they will send you out all you need. Obviously there will be a charge.
Jun 02, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Natural gas to lp conversion kit for a Thermador GGNCV30 cooktop
Your LP gas provider will get the orifices for you just call them with the model number of your thermador. They have gotten them for me many times.
May 07, 2009 | Thermador SGS36GS Gas Cooktop
Dec 05, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
