Question about Hitachi 53SBX59B 53" Rear Projection Television
Projection lights don't line up
The projection lights don't line up. You get a 3Dlike picture, with a green, blue, and red outline. The screen begins to bend up from the bottom and the screen splits into 3 colors, giving you the 3Dlike picture with the aforementioned green, red, and blue outline. If you hit the side or top of the tv the screen will line back up giving you a perfect picture, but only for a minute or two. Is there a loose connection, or has something burned out? I'm at a complete loss.
  • Hitachi Master
  • 3,459 Answers
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
projection lights don't line up - bb0cf99.pngsrc="http://i.fixya.net/uploads/images/bb0cf99.png" alt="bb0cf99.png" class="h_mi" />http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Mar 25, 2010
Our tv has red and green shadows on the picture when words come on at the bottom of screen they look like a shadow double Peoples faces will be outlined with red and green lines
your color engine is failing its also known as the optic block and they are very expensive to replace good luck google the optic block failure in these sets to better educate yourself with what your dealing with ok it most often blue that shows the failure but green and blue to and red
Dec 21, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Blurring of lettering on bottom of screen
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Apr 15, 2010 | Philips 60PP9202 60" Rear Projection...
I have a Sony kp53xbr35 rp tv, the problem is that i turn it on the lights begin to turn on. the screen turns blue to blue green then red and the tv shuts off. i can still get sound but no picture. the...
Projection sets have two very common problems outlined below.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can get more information and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
Nov 16, 2009 | Sony KP-53XBR45 53" Rear Projection...
Sounds like your convergence chips have failed. This is a common problem. You can get a repair kit from www.TvRepairKits.com .
Apr 11, 2009 | Philips Magnavox 9P6034C 60" Rear...
HITACHI 53SBX59B, projection lights don't line up.
You need to have the covergence adjusted.  Consult user manual for instructions on how or have a professional do it for you.
Jan 04, 2009 | Sprint Hitachi P300 Cellular Phone
It sounds like bad solder connections in the convergence output circuit. It may also be an intermittant convergence output ic which will need to be replaced.
Jan 04, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Green, red, and blue lights don't line up on screen
hi you have faulty convergance ic also there may be some faulty resistor and capacitors that sit in front of the ic, thanks
shaun
Jun 27, 2017 | Hitachi 50SBX78B 50" Rear Projection...
Projection tv is Blurry and offset
You have a focus and screen control box it has 3 controls on top 3on bottom these are the controls for Red-Green-Blue screen drives and for focus to each tube. IT should have Focus /Screen on it.
Dec 19, 2008 | Philips 50P8341 50" Rear Projection...
43H70 Blue Convergence out of line and will not line back up
If the blue colors will not line up, and the blue appears to sag inward from one or more sides, then you can bet that one of your convergence IC's has either cracked loose or burned out. The IC should be resoldered or replaced and the convergence realigned by someone experienced with projection TV convergence circuits.
May 21, 2007 | Toshiba 43H70 43" Rear Projection...
Hitachi 53SBX59B 53" Rear Projection Television Logo
187 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
