Question about Delta Home
Delta Lahara Monitor 14 series faucet
Hot & cold water reversed. How can I correct the mistake?
  • minnmoose
    minnmoose Nov 02, 2012
    The pumber reversed the hot & cold water lines. To correct the problem, do I need to turn the cartridge 180 degrees?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
No call delta 1-800 345-delta see if they have a reverse cartridge
Posted on Mar 06, 2013
  • 659 Answers
SOURCE: low flow hot water in Delta Shower
If your water heater is old or has been recently replaced, it will slough off debris that will get caught in the hot water supply side of the faucet. You have to disassimble the faucet and use a dental pic to remove the debris from it. This is a real common occurance. You can also try to flush out that side by removing the parts and then slowly turning on the water without the parts inside. Be careful not to flood your bathroom when you do this. But usually you have to dig it out. I have spent as high as 3 hours digging the liner from the dip tube of a water heater out of a faucet.
Posted on Apr 05, 2009
manhandy
  • 146 Answers
SOURCE: Delta single handle faucet. Hot or cold no in between.
well they should be same size but unless you getting more of one then other then sound like mixing valve is not mixing. do have 3/4 hook up to mixing valve? you only need 1/2" to valve.
Posted on Jun 26, 2009
  • 115 Answers
SOURCE: low hot water pressure in kitchen faucet
this is fun, you probably have some rust or lime build up in faucet, most of these single handles you have to remove handle setscrew usually small allen wrench. shut off water supply first!!! next the barrel should be held on by a screw remove and lift barrel out you should now be able to see build up clean and reassemble if you are not confident with this call a plumber good luck
Posted on Oct 14, 2009
  • 35 Answers
SOURCE: Water is not very hot.
First try adjusting the pressure balancing gear located right behind the handle. If you still do not have hot water I suggest to replace the cartridge.
Posted on Feb 23, 2010
heatman101
  • 43501 Answers
SOURCE: delta 600 series single handle shower. replaced
The hole under the seal and spring for the cold side is plugged with dirt....
a small screw driver will sometimes do the trick, and sometimes you need to unhook the piping underneath and blow air back through it...
heatman101
Posted on Aug 23, 2010
Delta T2738 Deck Mount on Jacuzzi Tub. Hot Water side leaking.
With the detailed part number you have, I would just walk into stores like Home Depot or any plumbing store and they will give you the exact parts you need. They are not expensive and a lot of them are standard parts and come in kits.
Good luck.
Apr 08, 2013 | Delta T2738 Lahara Deck-Mount Two-Handle...
Is there a way to reverse hot and cold?
Is it moen brand? if so all you have to do is take off the handle and remove the cartridge inside and flip it over 180deg and put it back in.
be sure to shut the water off first.
hope that helps you.
Dec 18, 2012 | Delta 144962-SS Mandara Monitor 14 Series...
Brand new delta roman tub faucet. Cold works great and hot side is anemic. All new pex tubing feeds it. When I got it out of box both faucets worked counter clock wise to open hot was anemic then. I pulled...
Cna you remove water line feeding hot side to make sure it has correct flow. It could have something blocking inside of water line. And check hot inlet side on faucet to make sure it is open and not blocked.
Remove line you can run water in a bucket to ensure that hot side water line has no blockage in it and have someone help you with turning water off and on for you.
Jul 31, 2011 | Delta Plumbing
The plumber reversed our hot and cold water supply for our Delta 1400 shower. This repair is not the same for the temperature adjustment is it? I have the handle apart and can see the adjustment but have...
I dont know if you really want to hear this but the faucet will have to be replumbed. The way this works is on the faucet you have 2 inputs (hot and cold) if they are not in there proper feed ports they will have to be removed and installed correctly. if they are installed using flex lines you can probably do it yourself but if its hard plumed (copper pipe) it will be more difficult as the pipes will have to be cut and moved.
Jun 22, 2011 | Delta & Single Handle Shower Faucet
Delta 13022 - Hot water out of the shower is much cooloer than out of the sink faucet. How is the mix of hot & cold controlled?
The Delta shower has a rotational limit stop designed so that when another fixture is activated, such as a toilet or dishwaser, the water does not go to extreme hot or cold. The reason for this is that the Delta shower unit is not pressure balanced or does not contain an anti scald device. The pdf document below will show how to adjust the water tempature if you feel it is too cold. Please use caution as it is probably set the way it is to prevent scalding.
http://www.deltafaucet.com/media/Product_Tech_Docs/Maint_Installation/50001to80000/51975RevH_4.15_15e05.pdf
Aug 03, 2010 | Delta T13420 Chrome Classic Single Handle...
I'm not getting enough hot water from my delta 14 multi shower faucet. How do I set the temp?
Go to the link below then click on download. This will bring up a pdf file for the Delta 14 series. Scroll down to page 5 for instructions from Delta on how to adjust the temperature after removing the handle.
http://www.deltafaucet.com/customersupport/documentation/T14430-LHP%20H74%20A74.html?document=mi&documentIndex=0
Jun 03, 2010 | Delta & Single Handle Shower Faucet
Adjust the hot & cold water for delia monitor 1700
Remove handle and check to see if there is a dial to take out to repostion back in to adjust cold and hot water flow. take it out and move it a little put handle on and turn on see if it changes,
May 05, 2010 | Delta Home
No hot water from Delta T13020 contro
Try reinstalling control valve in opposite /reverse position this should be the correct position.
Mar 17, 2009 | Plumbing
Home Logo
155 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
