Question about Lowrance GPS
Lowrance lms-480 It blinks & beeps, and shuts off and on
SOURCE: I have a lowrance lms-522c.
Followed the instructions that the manual gives to show trail.
Posted on Jul 04, 2008
SOURCE: My Lowrance LMS-337c df keeps going crazy.
Have the same problem. Have you resoved it?
Posted on Jun 20, 2009
  • 508 Answers
SOURCE: My Lowrance Lms 240 comes up gps module not
http://www.lowrance.com/Downloads/Manuals/ try this site. Also nor being real familiar with these units since i have no use for a water unit, i am going to suggest that it may be the transducer or the cable linking it to your gps unit. That's the only idea i have and if it's right , would you let me know, or let me know either way, since information like this helps me learn what and where i went wrong. Thanks
Posted on Jun 12, 2010
  • 2069 Answers
SOURCE: lms-332c lowrance fishfinder unit turns
well, you should beging by doing a soft reset..hold the pages button down as you power up to do the soft reset. if problem persists, then you are most probably having a keypad problem.. some button is stuck and anything could cause that.. even moisture. i recommend you have it serviced by tech in this case.
Regards
Posted on Sep 23, 2011
gopakumarg43
  • 75571 Answers
SOURCE: lms-332c lowrance fishfinder unit turns on as soon
Hello
I don't know whether you have made a factory reset to this device or not. If not, set it first and see whether it helps you. To make it factory settings:
[1] Press 'MENU""MENU" (down arrow to system setup) "ENT" (down arrow to RESET options/ ENT
[2] The unit asks if you want to reset all the options. Press [<---] to YES and then ENT. All options are reset, and the unit reverts back to map page at 4000 miles zoom range. Any recorded sonar logs of GPS data will be unchanged. OK.
Posted on Nov 03, 2011
Lms-332c lowrance fishfinder unit turns on as soon as the power wire is plugged in and goes to blinking pinging beeping between hi and low light settings constantly. All other features seem to work fine. A...
Hello
Sep 23, 2011 | Lowrance LMS-332C GPS Receiver
Lowrance completely dead
my lowrance lms 337c df will not power up. I checked all the cables and poer and they are good . can you assist me
Aug 14, 2011 | Lowrance LMS-337CDF GPS Receiver
GPS NOT RESPONDING
My GPS module on the Lowrance 480M does not work, any ideas? Thanks
Aug 06, 2011 | Lowrance LMS-480 GPS Receiver
Hi,when i switch on my lms-332c the map does not come up on the screen.If I remove and replace the map card it works perfectly. Can I fix this? regards nigel
I am guessing that the card you are using is a NAVIONICS chart? There have been some Lowrance units that were made around the same time that have had problems recognizing a Navionics chart right from power up.
Make sure the LMS-332 has the latest firmware version which can be downloaded from http://www.lowrance.com/en/Products/Marine/Full-Size-SonarGPS-Chartplotter-Combos/LMS-332C/Downloads/LMS-332C-Software-Update/
If the update doesn't help, this is going to be a compatibility problem with the LMS-332 and that particular card. You will need to replace the card or upgrade to a newer unit...but probably can just get used to removing and replacing the card when you turn the unit on.
Jul 08, 2009 | Lowrance LMS 332c Mapping Sonar/GPS...
I need CD, or DVD to learn how to use my Lowrance it is modle LMA-332C & LMS-337C DF.
Here you can buy the DVD for $13:
Bennett Training DVD For Lowrance LMS-332C
Here is the user manual:
LMS-332C and LMS-337C DF Owners Manual
Do not forget to rate the solution appropriately.
Many thanks.
Aug 31, 2008 | Office Equipment & Supplies
Keeps blowing fuses
It has a short in the wiring which is "not user fixable". I think the wires are crossed. Take it back, they need to repair or replace it. I suggest you replace it. Take the GPS with you show you can show them the problem. If you bought this on line call Lowrance and find the nearest repair center. Repair it yourself and you loose the warentee.
Aug 21, 2007 | Lowrance LMS-480MDF GPS Receiver
GPS Logo
48 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
