Sony Walkman CD player won't play the disc.
My Sony Walkman CD player won't play. It has new batteries but when I push play it acts like it is trying to work for a few seconds then says no disc. The same discs play fine on other players.
  • Anonymous Feb 22, 2009
    Have been having that problem today with mine. Any solutions?
The Marv
  • 72 Answers
SOURCE: vcd/mp3 player always says "no disc"
First try and clean the laser with a Q-tip with rubbing alchol on it. gently wipe the lens with the Q-tip. Then allow to dry for a couple of seconds. Try again if problem persists. Try to get the disc spinning wth your finger. While spinning clockwise close the lid and see if it takes off. If it does you have a bad spidle motor and it will need to be replaced. If it does not respond to either. I would consider replacement. The cost to repair by the time you pay a tech and parts you could get a new one with warranty. Generally if these need more than just a cleaning most people just replace due to cost of repair.
Posted on Aug 07, 2006
  • 9 Answers
SOURCE: Blinking "disc" error
Hi Lambo, 1) Your disc may be bad: scratches on surface, the surface maybe dirty, the disc is maybe bended,... Try with other discs, if the error occurs see next steps. If not, the initial disc was bad, but don't throw away, you may be able to clean it. 2) The Laser-optics in your Walkman can also suffer: - open your Walkman as if you would load a disk; look inside and you will see a little lens inside: clean it by using a ear-cleaner ( little stick with cotton on one or both ends). First dip the cotton end in some pure natural alcohol ( ethyl) and wipe very carefully over the little lens surface 3) The drive-mechanism of the Laser may also be cause; the only thing you can do on the field; the little lens ( see 2 ) normally should be near the end of a channel which you can recognize as the cut-out of the plastic . While reading a CD the lens moves thru this channel. You can try to push very softly this lens towards the nearest end of the channel. It often helps. 4) The Laser can be to its end of life; you can ask to change the opto-electrical mechanism, but I'm afraid it will cost you nearly as much as a new player; if you can buy a second hand might be even cheaper. Important for the future: - don't write with markers on discs; these texts release small quantities of fumes on laser-lenses - smokers pollute also with nicotine-fumes their lenses and discs Hope you can get nice music ASAP; let us know
Posted on Nov 01, 2006
  • 12 Answers
another thing to do is listen to the unit as it spins up, you may be able to hear the disk spinning (though you can definitly see it if you open it up) and you should also be able to hear the mechanism that moves the optics allong the rail. If you hear that but still no read, you might try opening up the case (6 small phillips screws and then a small bit of prying to open) and look to see if the small thin plastic wireing harness is fully seated in the connector on the main board. If not loosen the small brown retaining clip and push the plastic strap with the traces fully into to connector and push the retaining clip back in. I have fixed 2 d-nf420 units this way.
Posted on Nov 16, 2006
tvsandstuff
  • 24 Answers
SOURCE: `Sony CD player won't play burned discs
Many of the older Car CD Players will not play CD-R's or they may with static sounds behind the music. What you need to do is try using a different brand of cd-r disc. If this doesn't work then it means that you may need to replace the CD player because the model that you have may not be decoded in order to play CD-R, CD-RW, play MP3's or anything of that such.
Get back to me if this doesn't work I'll help you square it away.
Posted on Nov 20, 2007
SOURCE: Sony Walkman D-NE004
I assume you've tried batteries, cleaned the laser, etc. If so, then the laser might be knackered!
Posted on Mar 20, 2008
Sony 5 disc cd player won't play 5 cds but plays just 1 disc
Check the mode of operation. There can be a setting where it just plays one disc. Random or mixed will give you more songs to get to other discs.
Dec 26, 2012 | Sony CDP-CE375 5-Disc CD Changer
Mz-n510 walkman won't play 140 mb disc
No. MZ-n510s cannot play those discs. Buy a HI MD machine or sell the disc.
http://www.minidisc.org/hi-md_faq.html#_q96
Dec 17, 2012 | Sony Net MD Walkman MZ-N510 MiniDisc...
My radio/CD player constantly says "ERR" and CD's won't play anymore. It doesn't show the time or the radio station either, just "ERR". I can hear it, like it's trying...
HI lisasmith566 IT is not a fuse problem .
the problem is your the CD part of the radio
must likely the cd is stock or more likely the cd drive motor is defective .
FIRST try pushing eject on radio and see CD comes out if not you need a new radio .
good luck vote
Jul 27, 2011 | 2003 Chevrolet Tracker
SONY Walkman D-NE005 won't play my CDs I am getting a "no disc" message
you may need to contact Sony Support. You're lucky if its still covered by the warranty.
Oct 14, 2010 | Sony Walkman D-NE300 Personal CD Player
I have a Sony Psyc CD Walkman D-Ej010 and I will have a cd in there at it will play for a few minutes and then stop and say no-disc. What could be the problem?
There may be a couple of reasons why a NO DISC , DISC ERROR or INSERT DISC error may appear in the display of your CD player. Try doing the following steps to troubleshoot why the error is displayed:
  • For disc players with a HOLD switch, make sure to move the switch to the OFF position.
  • Verify that the disc being used is supported by the CD player. NOTE: CD players do not support VCD or DVD discs. In addition, some CD players do not support CD-R or CD-RW discs that are created by a CD burner. For information regarding disc compatibility with your player, refer to the operating instructions supplied with the product
  • Ensure a disc has been inserted into the player. Make sure that the disc is inserted correctly, with the playback side of the disc facing down on the disc tray.
  • If the disc still does not play, attempt to play a different, commercially-produced disc.
  • NOTE: If more than one of the commercially-produced discs do not play, verify whether the discs are extended-length discs. Some players are not able to play discs where the recording exceeds the standard 74 minutes. If the recording of the disc is longer than 74 minutes, it is possible that some of the specifications of that disc were compromised and therefore, the CD player will not recognize that disc.
  • If the disc is dirty with fingerprints or smudges, or if the disc is scratched or broken, the CD player may not recognize the disc.Clean the disc using a soft, dry cloth.
  • Properly reinsert the disc into the player.
  • Attempt to play the disc again.
  • Only press the PLAY button once. If the PLAY button is pressed more than once, the disc may stop playing.
  • If the disc is still not recognized, remove the disc and leave the CD player powered on for approximately one hour to resolve the possibility of moisture condensation inside the player.
  • Please use a Lens Cleaning disc and check if that helps.
If the issue persists, please click hear to locate the repair facility near your area.
Thanks for understanding. Please let me know if you require any clarifications.
Jan 29, 2010 | Sony Walkman D-EJ010PS Personal CD Player
Sony Walkman D-NEO50 How do you play the darned thing?
Maybe you have to clean battery compartment from leakage . Afterward there is a nob in the right side (3rd nob from right). which you have to press it
May 09, 2009 | Sony Walkman D-NE050PS Personal CD Player
WILL NOT PLAY FROM THE POWER DC PLUG
is it the right dc plug sounds like its not getting the right voltage
Feb 06, 2008 | Sony Walkman D-SJ301 Personal CD Player
Nov 20, 2007 | Sony Walkman D-EJ360 Personal CD Player
Nov 01, 2006 | Sony Walkman D-EJ100 Personal CD Player
147 people viewed this question
 Grubhead
Grubhead
