Question about Toshiba Satellite P755-s5320
My toshiba satellite laptop touchpad not working
  • 624 Answers
SOURCE: HOW TO ENABLE TOUCHPAD ON TOSHIBA SATELLITE PRO M15-S405
Press the Fn and F9 keys, that should turn it back on. Let us know if that solve your issue and please dont' forget to rate this posting.
Posted on Feb 09, 2007
TampaNative
  • 778 Answers
SOURCE: Hi! My touchpad mouse has stopped working in my
While holding the "FN" key, press the "F9" key and that should re enable your touchpad.
Posted on Apr 19, 2009
benwabnick
  • 2404 Answers
SOURCE: Toshiba Satellite Touchpad not working
Restore the defaults in the BIOS to begin with, this will make sure its not a setting in there that is disabling the mousepad.
Then in windows see if the touchpad is working. If not then take the keyboard out with the power turned off.
When you take the keyboard out you will see the ribbon cable that comes from underneath the touchpad. disconnect it from the motherboard and reseat it firmly back in. Then turn back on the motherboard and see if the mousepad works. If it still doesn't then try the shortcut key to enable it.
If it does't enable then that means its either going to be a mousepad problem where you would have to replace the top cover assembly or a motherboard problem cause it could be where the voltage required to run that mousepad is missing.
Posted on Jun 27, 2009
  • 566 Answers
SOURCE: Touchpad not funjctioning on Toshiba Satellite L40/45 laptop
You might have inadvertedly disabled the touchpad.
1. Press Fn + F9 to enable the touchpad.
This key combination acts as a switch, enabling or disabling the touchpad: press once to enable (if it is disabled), then press again to disable.
2. If the touchpad still doesn't respond, check the settings in the mouse control utility.
Click on the touchpad icon on the right side of the task bar if you see one or click Start button/Settings/Control Panel, select the Mouse icon and Press Enter.
Change the settings if necessary.
Posted on Aug 17, 2009
  • 23 Answers
SOURCE: Touchpad doesn't work on Toshiba Satellite 305 PSAGU-03601V
Go to
Use a mouse or Tab+Aly keys
Win XP
Start > Control Panel > System
Click the "Hardware" tab
Click the "Device" manager button.
Click the cross near "Mice and other pointing devices".
Right click, "Enable"
Vista
As above but
Start > Control Panel > Device Manager
Posted on Mar 19, 2010
I accidentally deleted the installer of my toshiba satellite m35x - s109 touchpad...now the touchpad is no longer working and the 2 buttons below it...please help
hi flyrech,
You can just your touchpad needs a driver for it to work fine again. Here's the link:
http://www.driversforfree.com/omn_ofm_omd/toshiba/satellite/m35x-s109/drivers.aspx
Just download and install the "Toshiba Alps touchpad driver".
Hope this helps, inform me this is solution effective or not. Thanks.
May 12, 2011 | Toshiba Satellite M35X-S109 Notebook
Toshiba satellite L505D GS6000 mouse freezing
reinstall the driver for the mouse touchpad
Feb 22, 2010 | Toshiba Satellite A60 Notebook
The touchpad mouse on my toshiba salellite does not function even though it shows it working properly when you go into the touchpad icon. I have an external wireless mouse (usb) hooked up that works fine...
The touchpad is most probably defective. If you have dropped your laptop the touchpad cable could have get out from its connector on the mainboard. You can get a new touchpad/palmrest on ebay. You have to remove your touchpad/palmrest as shown in the link below, steps 17 to 19 :
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
Identify the part number of your touchpad/palmrest. Search on ebay.com : Toshiba Satelitte A105 palmrest. Buy the one with the same part numer as yours.
...or have your laptop repaired by a professional.
Oct 09, 2009 | Toshiba Satellite A105 Notebook
I have a Toshiba Satellite Laptop. The mouse pad is not working.
You might need a palmrest/touchpad replacement. Check the touchpad cable connection on the motherboard first. Remove it and reinsert in its place. If still not working you have to replace the assemble.
Oct 03, 2009 | Toshiba Computers & Internet
Hi! My touchpad mouse has stopped working in my toshiba satellite L305-S5875 notebook please help
Apr 19, 2009 | Toshiba Satellite L305D-S5874 Laptop
Touch pad refuses to work
Try going to Toshiba's support page and re-install the driver for the touchpad. If this does not work. You may need to replace the touchpad itself.
Apr 16, 2009 | Toshiba Satellite A135-S2386 Notebook
Toshiba Satellite touchpad sensitivity
if you go to :
  1. control panel
  2. hardware and sound
  3. mouse
  4. device settings
  5. click the "setings" button
  6. then go to sensitivity
i hope this works as i have a toshiba a200 laptop. while you're there you can toggle palm check in case you lean on the touchpad.
Jul 24, 2008 | Toshiba Satellite A135 Notebook
Feb 09, 2007 | Toshiba Satellite Pro M15-S405 Notebook
Toshiba Satellite P755-s5320 Logo
348 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
