Question about GE Refrigerators
Rust in the freezer section.
The freezer shelves have rust on them & the fridge is only 3 years old.
    Top Expert:
  • GE Master
  • 9,472 Answers
Could you please describe the problem you are having a little better?
If you are trying to get rid of the rust you will need to sand the rusted area and spray the shelves with appliance paint. Make sure it is an enamel based appliance paint. Here is what I use on all my appliances.
Posted on Nov 01, 2012
IrishDruid
  • 2712 Answers
SOURCE: Sears Kenmore 16 series fridge
A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Posted on Sep 05, 2008
SOURCE: rust under water dispenser on freezer door
I had the same problem and I replaced the door. I also found out that this problem is cause by water going into the two screws in the back of the Water/Ice dispenser. He is right; it was hard, but possible. Be careful when removing the Water/Ice dispenser.
goodluck
Posted on Feb 19, 2008
Richie_asg1
  • 1036 Answers
SOURCE: Rust on Jenn Air Refrigerator Door at Water Dispenser
You may end up respraying the door, but here goes.-
First mechanically remove as much of the rust as you can with an old screwdriver or similar scraper. Then use coarse emery cloth - 80 -120 grit untill all you're left with is shiny metal with rust pits.
You may need to go out further than you think - about 1" all round.
Then use a paint- on de-rusting fluid from vehicle products supplier. When all rust is black or dissapeared, use a zinc primer on all the bare metal. (this will stop it reacuring)
Then either spray the area with an "appliance white" aerosol or squirt it into the cap, and use a paintbrush.
If you are spraying it, open all house windows and doors, cut a mask from newspaper- then tape it to the fridge. Use blankets , plastic dustsheet or old sheets to protect things, and spray it from 12" in several very light coats.
When done, "polish" with T cut - which should remove the rust stain too.
Seal the area of the original leak with a white or clear silicone - and sort the original leak out.
If you polish the plastic with a silicone spray, water will tend to stay put rather than seep.
Posted on Jun 11, 2008
aborcass
  • 2651 Answers
SOURCE: Repainting doors on whirlpool white refrigerator
oowwwww!!! thats what we call in the refrig biz "refrig cancer" the door itself is actually rusting from the inside out. the older refrigs used fiberglass insulation inside the doors which has a tendency to hold moisture, and overthe years rusts through. the new door use blown-in poly styrene foam far less likey to hold moisture. That being said you could remove the door lightly sand and paint, can of krylon enamal aint should do it, at least for a little while anyway
Posted on Nov 30, 2008
  • 16 Answers
SOURCE: GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
Posted on Mar 25, 2009
Why does my camper freezer have rust all over?
Probably condensation building up inside from running hot, cleaning out the coils with one of them dusters or vacuuming the coils (underneath the unit on some models or on the back of some models of refrigerators and/or freezers helps them to run cooler and to avoid that rust. With our pets I have to clean our freezers coil every 2 or 3 months.
Apr 23, 2014 | Thetford Norcold 618847 Refrigerator Part...
After my truck has been seting for awhile the breaks do not seam to work very well. the pedel is hard but truck does not want to stop.after truck has been driven prolbem goes away
Rust on the rotors from sitting
Moisture on the pads, until they heat cycle
Rust,possibly for years on all caliper & pad sliding
surfaces & no lube whats so ever
Brakes have to come apart once a year for rust removal,
inspection & lube,any pad replacement or machining can take
place as needed,say every 2 or 3 years
3 year old pads can be heat cycled & also the backing plates
rusted away
Honestly,neglect & improper brake work is 100% of all brake
problems
Mar 28, 2013 | 1993 Chevrolet K2500
Rust on my shelves in the freezer section?
Nov 01, 2012 | Refrigerators
A 11 year old whirlpool fridge.. freezer working but not the fridge.. water dripping out from the shaft between freezer to fridge
HI, sounds like you have 2 problems. First of all, your drain pan in the freezer is clogged and will need to be cleaned out, second: this ice has caused an air flow restriction to the refer section. When you clear out all the ice, look for obstruction that you prevent clean air flow to the refer section. This should solve the problem.
You may have to remove all the food from the freezer, remove shelves and rear wall to clear all the ice. Failure to remove all the ice can prevent air from circulating from section to section. I would not suggest in using a hair dryer, too much heat in the wrong place can cause damage to the liner in the form of warping.
Turn off the unit while doing this de-icing, this will help greatly.
Good Luck
Aug 14, 2011 | Whirlpool Refrigerators
Hi GE top freezer fridge - 5 years old( no ice
Well for one thing that unit was manufactured 10 years ago. But it sounds like the defrost drain is clogged and the water is running down the inside of the unit. The evaporator (not condenser) is on the bottom of the freezer compartment. The bottom panel of the freezer comes out. They are a bit of a pain to do, but can be done.
Jan 03, 2010 | GE GTS22KBP Top Freezer Refrigerator
Outside of fridge door turns brown in color with high humidity
Check your door seals or for cracks in plastic shelves. Sounds like condensation getting to metal causing rust.
Jul 25, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Rust spots appearing on front of doors of kitchen (indoor) Kenmore refrigerator.
paint ain't perfect!
rust on a 15yr old appliance is normal
Dec 01, 2008 | Refrigerators
Rca fridge freezer... bulb gone in freezer compartment, how do i change it?
rca fridge/freezeer about 4 years old - door panels have rust spots
May 26, 2008 | Refrigerators
Replacement shelves
Yes you can get a replacement for the shelves, at a hardware store or somewhere else. Or you can try spray painting the spots there are rust.
Mar 29, 2008 | Sanyo HF-5020
Refrigerators Logo
902 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
