Question about Philips DVP642 DVD Player
Disc Loader got jammed.
2 discs were put on ( a single loader) by error. 2nd disc played but we could not remove discs without moving the holder out of sinc. Now the disc holder is out of alignment with the machine & is locked into a ready position but is stuck. Anyone understand what I am trying to explain? How can I realign this or should I just buy another one. The DVD is a DVP542/37 & is like new. Thanks for any advice!
  • beachwinner Jan 04, 2009
    Thanks for reply re removing cover. Trouble is the discs are already removed but in the process of removing the 2 stuck discs the holder got jammed and no longer will move into the DVD. It is now sticking out of machine (discs fits fine on it) but is out of position to freely enter DVD. What now?
  • beachwinner Jan 05, 2009
    Still trying to get the jammed disc tray to reenter machine.
  • 492 Answers
Remove the top cover.  You will see where the disc are, take care in removing the stabilizer housing, you should be able to get the dvds out and put it back together.
Posted on Jan 04, 2009
I have an 1990 JVC XL-M303BK Home Compact-Disc player (2 channel) and am unable to eject the 5-disc cartridge. Is there a solution for this ?
There is a CD jammed in transit between the playing mechanism and the magazine. Some disassembly will be necessary to get the disc into the magazine so it can be removed.
May 28, 2017 | Audio Players & Recorders
Dvd stuck in home 7-cd/dvd changer
So you want to remove the disc without damaging the disc? so its ok to damage the player.
Put a cushion on the floor, put player on it.
Use a strong pair of pliers to crush and bend all the plastic parts of the loader near the disc, shake the player so that the disc falls onto the cushion.
Dec 21, 2013 | JVC Audio Players & Recorders
Our mds-je440 is not ejecting the disc, it's not coming up far enough to eject it
Your loader is probably worn out, or you jammed a disc into it. Take off the cover, then take off the loader mechanism internal cover to remove the disc.
I paid $250+ to get a loader rapaired professionally on a JA3ES and the repair did not last, I migrated to units with loader trays like the 20ES and the rare 50ES.
Probably the best thing to do is to get another similar deck since the prices have fallen on most of these units, they are readibly available with anything you could need for minidiscs on ebay. The decks are more popular in Europe and Japan than in the USA.
I recently had to buy a loader belt for a stuck loader tray on my 20ES, it will only work with the right sony band, your unit has no bands, so when the loader is bad you need to replace the entire loader mechanism.
Most MD parts are available on eBay Germany, most sellers routinely ship to the USA.
Aug 11, 2011 | Sony MDS-JE440 Mini Disc Player
I have a Sony MDS-JB which I bought new, now when i insert a disc it won't play it, plus I have a vert hard time try to get it out of the unit I have to trun it off, so I can get the disc out,\. HELP.
Pull off the top cover, then remove the inside cover of the loader mechanism and you can gentily remove it.
Your loader meahanism is worn out, you need to get another similar unit perhaps on ebay to replace it.
Feb 08, 2011 | Sony MDS-JB940 Mini Disc Player
Can you manually release a DVD from the Panasonic S32? The DVD player 'died' - with a CD inside. The instructions are silent on a manual solution.
Well you can please follow the below steps -
1. Unplug the DVD player and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
2. Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It's the part that holds the DVD loader in place.
3. Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don't want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
4. Slide the disc tray out. If your disc got stuck before it was read, it's probably still on this tray. If so, your problem is solved. However, if the disc was fully set and loaded, the job isn't quite finished yet.
5. Move the small mechanical arm that holds the disc in place over so that the disc and the reader are both exposed. Some DVD players will not have anything holding the disc in place. Instead, these devices use a system not unlike that of a common DVD case. The DVD will be locked in place in the center.
6. Carefully lift the disc up and out of its loaded position in the DVD player. This may entail sliding the disc reading mechanism over slightly. This won't hurt the device as long as you're careful. You should be able to access and remove the disc.
Good Luck!!
Apr 01, 2010 | Panasonic Televison & Video
CD/DVD drawer won't open so CD stuck inside :(
Good Luck!! Thanks for using FixYa!!
Feb 03, 2010 | Cambridge Audio Azur 540D DVD Player
Dr787t won't play disc. Player won't recognize
You can try to stop this by dis-assembling the unit to gain access to the laser and you can clean the laser using a cotton bud or cue tip, if that doesnt solve the issue, what you can do is with the case off, put in a dvd and see if it spins, and also note if the laser is lighting up, if it isnt lighting up or if the disc isnt spinning you may need to replace the dvd loader of the unit.
If the laser doesnt light up and the disc doesnt spin its possible you may need to replace the MPEG Printed Circuit Board which you will fing attatched to to the dvd loader via small ribbon cables, be carefull when removing these if you need to remove them or a seriens of small plugs. I hope this helps. Good Luck.
Dec 06, 2009 | LG DR787T DVD Recorder
Nintendo wii
if its under warranty take it back to the retailer, otherwise i recommend you replace the disc loader assenbly and the laser. good luck.
Aug 17, 2009 | Nintendo Wii Console
Sony DVP CX860 300 disc just keeps rotating the carousel
I just got one of these and i notice mine does the same thing. WHat i found that helped mine is tip the unit back a little. The loader uses a little but of gravity to get the disks to roll back into the loader. If its level the wheel sometimes cant spin the disk up into the loader fully. If its tipping back a little the disk will roll back easy into the loader and load it properly.
Also, dont forget if your playing a disk and you want to stop the unit, DONT POWER IT OFF AT THE UNIT. Power the unit off by the remote power this way it will finish its cycle and put the disk back into the proper slot.
Jan 18, 2009 | Sony DVP-CX860 Multi-disc DVD Player
Philips DVP642 DVD Player Logo
127 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
