Question about Homelite Garden
Have a 18" power chain saw.
Wont run at full throtle unless u pump the triger. then it cuts out. can run it at have throtle
  • 36 Answers
Fuel restriction could be dirty in tank filter, or high idle screw needs to be adjusted. Do this by turning it counter clock wise 1/8 turn at a time start and check for improvement after each adjustment.
Posted on Jan 04, 2009
Oiler mechanism to bar of ryobi 40cc 10532 18 inch
I get asked this question a lot , im gonna have to make a video on this subject someday .
but here:
1st ck your oil viscosity/SAE it should be 30 and say bar/chain oil
next dump out entire oil tank and wash out with kerosene (you'd be surprised what I seen come out)
then remove bar and chain , locate oil outlet it's in body of saw near adjustment screw , use a small can of air to blow in this port softly , use a touch more of kero to clean this all out , refill tank with proper oil !!!! and run saw (no need to put bar/chain back on yet ) might take several minutes but oil should start to flow out hole !! stop saw and reinstall bar/chain then run again .. fixed !! if no oil comes out ever your oil pump is gonna need some fixing
for a low cost oil I use filtered used motor oil cut down with a dab of kerosene
Jul 07, 2014 | Ryobi Factory Reconditioned 18" 40cc...
My Brand new Stihl ts420 cut saw wont run full throtle, smokes white, and leaks fuel out of exhaust filter. it runs like the choke is half on.
This sounds like the carb is flooding, there is a rubber tipped needle under the metering side of the carb, this may be leaking, before replacing the needle make sure the air filter is not blocked, replace with a new filter and try again
Dec 14, 2011 | Stihl Ts 410 420 Cut Off Saw...
42cc 18 inch craftsman chainsaw model 358-351910-18. Saw runs great at idle or while not cutting wood, when starting to cut wood just after the entire bar gets into the wood engine bogs down and chain...
Generally this is a fuel / air ratio problem. Usually it can be solved by a carb adjustment. On the carb there are usually two screws, one marked low or L , the other marked high or H. Low is your adjustment for idle mixture, high is for mixture at full throttle. The saw should Always be adjusted to run well during the cut. Make adjustments a little at a time, then try The saw. Continue small adjustments untill the saw is performing well at full throttle while Cutting.
Aug 09, 2011 | Poulan Pro Chain Saw 46cc 20"
I have a new Echo CS-400. It starts easily, and appears to run aat full power, however, It is very hard to cut logs. I have to exert a great deal of force to saw through a six inch log. The chain is new...
Are you certain you have the chain on the right direction? Sounds like you may have it on backwards. A new chain should cut easily almost without effort unless it has come in contact with stones or metal or something equally hard. Hope this helps
May 03, 2011 | Echo CS400 18" Chain Saw
Please tell me your closest technitian in Norcross; Georgia 30093 My Chain Saw is not turning on
i cant tell you were to look but i can tell you what to look at on the saw to try to fix it,,,,first change the spark plug and check for a spark by holding the plug on the cylinder head and cranking the motor over,,,hold it down tight or it will bite you?
then check you have a clean carb and that the fule pump rubber is good,,its under the cover were the fule pipe fit on the carb clean the carb out as well,,clean the air filter out,, then give it a go starting her up,,if she runs but keeps stoping get a small screw driver and find the two small screws on the side of the cover,, one is for slow running,,one it for top reves,,,undo the slow running screw till the saw ticks over without stoping,,then hold the triger full open and addjust the full throtol screw till it wont rev any higher,,,dont have the chain brake on at all so watch your self,,,,,cutting a leg off hurts im told????
Aug 11, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Chainsaw dies out when gas is pressed to full throtle
Carb needs teardown and cleaning. May be a stuck float or clogged jet.
Spraycleaner just wont cut it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 05, 2010 | Poulan Pro Chain Saw 46cc 20"
Chain saw will idle, but not run at full throtle
First, check the air filter and clean it well. Then make sure the spark plug is clean and gapped properly.
Then prime, start it up, and allow it to idle, even using the trigger to make it fast idle if you can. Using a small thin screwdiver, turn the high speed idle screw on the carb in small increments to the right, kepping the speed up on the trhrottle.
The idea is to screw it out until it sputters, then screw it a half turn back in. If it doesn't smooth out when turning it to the right, try going to the left.
Afterwards you may find it doesn't run at low throttle well. If not, try the same thing starting to turn left until it smooths out. If it doesn't, screw to the right. Again, the idea is to go until it sounds rough, then back off a half turn.
You should be able to adjust it to the point where you can open the throttle all the way with smooth sure throttle increase.
Nov 05, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
18"poulan chain saw wont rev up
carbs dirty need cleaning. try adding some stabil you can buy at auto zone with fresh fuel it may clean itself out w/o having to remove the carb.
Sep 14, 2009 | Poulan PP4218AV 18" Chain Saw
Garden Logo
97 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
