Question about Cyberhome DVR 1600 DVD Recorder
My dvd player blinks
This morning I was setting my dvd recorder up to record a show and the logo screen was blinking as soon as I put the dvd in to be formated. I took it out and the logo screen continued to blink and I cut the dvd recorder off and the screen was fine. So I know it is something wrong with the dvd. I tried unplugging the dvd but that did not work. Please help
    Problem Solver:
  • 5 Answers
Try cleanning the lens in the unit with dvd cd cleanner which can be bought in any office surplus store make sure its for dvd there are two types cd and combo dvd?cd i recomond staples office supplies it is only 10 dollars cad
Posted on Aug 11, 2007
When the dvd/hdd is on it not show any picture on the tv
Do it show its Logo on screen. If it shows the logo, and does not show picture, the fault is with its pick-up lens system. If it do not show the Logo too, the fault is with its main power regulator board [SMPS]. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 26, 2014 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Will not play DVD from other regions. Specifically, plays a few but mostly does not play DVD from Australian region. I resdie in Serbia. thansk for any advice or work arounds on this issue. We inherited...
Your dvd is locked to a region code so will only play dvd's for region it was made for.
good news is that you can unlock most dvd players to be region free.
URC-3445 ONEFORALL
First of all set the command mode of the recorder to "DVD1"
from the menu and from the remote.
After that
1. Press DVD on the remote control
2. Hold MAGIC button (or SET Button) until the led flashes twice.
3. Press 0, 5, 3 and 3 and the led flashes twice.
4. After that the URC can manage the recorder...check it
If not, then use the code search (have a look in the manual of the remote control).
When the rc works, then step over to
MAIN PROCEDURE (DON'T HAVE ANY DVD INSIDE THE PLAYER)
1. Hold MAGIC button until the LED blinks twice
2. Now type "994" (then LED blinks again)
3. Press the MAGIC button (shortly)
4. Now type 001891
5. LED blinks twice
6. Repeat steps 1-5 and enter instead of step 4 the codes 002552,000953,002214,000795
7. Put the player on standby (and be sure that there is no DVD inside)
8. Press 1,2,3,4,5 (pause briefly between each button and make sure LED of remote flashes) then the display shows "TIMER OK" and the DVD-Player goes on
9. Press 1,2,3,4,5 (pause briefly between each button and make sure LED of remote flashes) then the display shows "TIMER OK" and the DVD-Player goes off
10. Then it is done. Your DVD-Player/Recorder is Codefree
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Sony SLV-D990P DVD Player/VCR
Dazzle DVC 100 blinking screen
Dazzle DVC 100 blinking screen After I record...
Jun 16, 2010 | Pinnacle Dazzle DVC-100 DVD Recorder
All region code for Medion DVD recorder MD84100
Found on another board, tried and it worked on my Medion
P70002 / MD84100 DVD recorder:
Turn on DVD recorder
Press HOME on remote
Go to SETUP in Easy Menu
Move down to padlock icon
Press 0 seven times
Message appears:
Congratulations!
Region Change Free!
YES (press ENTER)
It now plays US and UK as well as Australian (in my case).
Dec 31, 2008 | Electronics - Others
DVD Player won't show recordings on my TV screen
put the dvd player on the same channel as you set your Tv when wathing direct tv. and try recording
if you are using rca push on cable yellow,red ,white set to your A,V audio,video channel
when recordining you will be changing channels on the direct tv box
do you have a manual for dvd player read that really good that might help.
Sep 28, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Magnovox MWR20V6 will not begin recording when it should.
This is more a work-around than a solution, as the unit is failing to function normally; however, having the identical problem I observed that the unit is failing to power on at 2:00 minutes before beginning recording, a necessary step to record to DVD.
My work-around is the following:
1) Set up the timer, inputting necessary date, time, etc. as normal. With the unit still powered on, start the timed recording mode by pressing timer set, as normal. You will see the red clock icon and the DVD logo iluminate on the VFD.
2) Press the Standby-On power button. This will power the unit on in VCR mode. You should at this time be unable to switch from VCR to DVD mode since the DVD is still in timer mode. LEAVE THE UNIT POWERED ON in this manner. The timer will function and the DVD will record normally.
I have no clue why my unit suddenly forgot how to power up on its own in order to record to DVD. If anyone has an answer for that one please post!
Tom Gee
May 03, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Can i record from tv to dvd
yes
make sure the cables are connected correctly, the manual will show that.
If the mwr20v6 has a tuner you must have the channel on the dvd set to the program, if it has no tuner, you must have your tv set to the correct channel.
Feb 13, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Vcr won't record on timer
when you set the timer you need to ok the settings of the programme you record then you need to switch the video off on the controll as it will only record in standby mode cus if the video is switched on it will wait for you to tell it to record hope this helps
Oct 19, 2007 | GoVideo DV2150 DVD Player/VCR
Won't ower up
Unplug unit for about 20 minutes then plug back in and see if it works
Aug 27, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Cyberhome DVR 1600 DVD Recorder Logo
77 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
