Question about Hitachi Garden
How To Fix a Hitachi 441 CFM Hand Leaf Blower primer bulb
  • 211 Answers
SOURCE: leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Posted on Dec 05, 2008
  • 77 Answers
SOURCE: craftman leaf blower when I press primer bulb I
Diaphram gasket in carb is swelled and air is getting through,get a carb reduild kit and it should be fine.
Posted on Aug 10, 2009
SOURCE: craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Posted on Aug 21, 2009
  • 148 Answers
SOURCE: Won't start
Have you tried cleaning the carb? If not take some carb cleaner and spray into the carb inlet and outlets (gently inserting the nozzle). After that see if it will start.
Posted on Sep 08, 2009
2strokeguy
  • 183 Answers
SOURCE: My Homelite Mighty Lite 26b
Homelite wants to sell you a new carburetor assembly. Your blower came equipped with a RuiXing brand carb. RuiXing does not offer any repair parts for their carbs, only replacement units.
Now for the good news....a Zama brand primer bulb fits perfectly on the RuiXing carbs. Check with your local small engine repair shop for a Zama primer bulb. The blower requires removal af the carb to get at both of the screws that hold on the bulb. It is not difficult, just one nut holds on the outer airbox cover...don't lose the little washers. Then one long stud and one short screw will take the carb off. Replace the primer bulb and reinstall everything the same way it came off.
Posted on Dec 21, 2010
How can i fix a primer bubble that hisses
Here's a link to your poulan part site,you probably need a primer bulb,lowes,homedepo,or sears may have them. http://www.repairclinic.com/Shop-For-Parts/a27b345/Poulan-Leaf-Blower-Parts
Jul 21, 2015 | Poulan Garden
4 lawn mowers same problem wont start until I prime the by hand. Briggs Stratton 917.387500/ 12AV566n01124987/20043/SDSP2245D Will the same primer bulb fit the above mowers.
If its identical it should work ,if not take the old one to a mower shop,to get correct one and make sure the choke is going right on when the cable is in choke position.
Aug 05, 2014 | Ryobi Snap In Primer Bulb Pump 683974 ...
Primer bulb will not fill with gas
does it have a small hole in it or split check gas lines also
Apr 01, 2014 | Vehicle Parts & Accessories
Where can i find a primer bulb for this model
Tractor Supply if there is one near you, or any small engine sales center. Hope this helps
Aug 01, 2012 | Weedeater Featherlite Blower 18 Cc 150 Mph...
How to change primer bulb on Husqvarna 125 b leaf blower
Remove air filter cover,remove air filter, remove two nuts holding the assembly,pull primer bulb assembly out,remove primer tube. Reinstall in reverse order. http://www.ebay.com/itm/530047721-POULAN-WEEDEATER-RED-SNAP-PRIMER-BULB-/190568099240?pt=LH_DefaultDomain_0&hash=item2c5ebe6da8#ht_1848wt_718
Aug 31, 2011 | Husqvarna Hand Held Blower 125 B Grass...
Craftsman leaf blower, primer bulb will not return, won't start
Apr 22, 2009 | Craftsman Garden
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
287 people viewed this question
Top Hitachi Garden Experts
Phil Walker
Phil Walker
Are you a Hitachi Garden Expert? Answer questions, earn points and help others
