Question about HP Photosmart C5180 All-In-One InkJet Printer
Printer says it is disconnected
I replaced the yellow and black ink and it still comes up when I am trying to print and says that I must replace 3 more colors and have to print in black ink only although I still have ink in all of the other colors. I just got a new computer that has vista, downloaded the drivers but now have problems. it was fine when I had a computer with windows xp.
  • lildarlin57 Jan 04, 2009
    I downloaded the vista drivers and it works but it says it's disconnected and I don't know what else to do for it. I haven't had it that long but too long to return it.
    Sergeant:
  • 237 Answers
This is an indication that the devices you are using has drivers for windows xp and will work with the xp os.
Posted on Jan 04, 2009
  • zabrina liang Jan 06, 2009
    So does this mean the problem is solved?=)
Wrong Color Printing
Type "print nozzle test" in the search box and click Search. Perform a nozzle test, and if the colors match what are on the instructions, your print head and inks are OK.
(1) If the print head and inks check out OK, type "wrong colors on print" in the search box, and you will see several troubleshooting steps you can try.
(2) If the nozzle test colors are off, confirm that you are using BCI-6 inks for all three colors and the small black tank. You should only have a BCI-3 tank in the large black position. If you have all the correct inks, your machine probably needs to be serviced/ repaired.
Thank
Jan 09, 2014 | Dell 1320c Laser Printer
Brother Printer-copy-scan-photo capture Model DCP-110C After replacing black ink and yellow ink, still says yellow ink low, and will just print out pink menu items, no message. I cleaned it 5 times. ...
place the printer cartridge into a small amount of water to make sure the yellow is flowing out. Let me know what this finds and try it again if yellow comes out.
Also, what exactly did you clean, the metal contacts?
Jul 03, 2008 | Brother Office Equipment & Supplies
Why are only black and yellow printing?
The printer has two ink-cartridges: black and tri-color.
The black cartridge has ink left.
The tri-color cartridge has run out of 2 of the 3 colours of ink.
Buy a replacement tri-color cartridge,
and responsibly recycle the "empty" cartridge.
Nov 19, 2009 | Canon i9100 InkJet Photo Printer
Windows Ink Cartridge Empty false error message.
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Oct 28, 2009 | HP C6280 All-in-One Printer
Black ink not coming through
I had the same problem. Ended up replacing the black/yellow "printhead" and that corrected the problem.
Jun 08, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Only black and blue will print on test page; yellow and magenta does not. Ink was just replaced.
Did yellow and magenta print OK before the previous cartridges ran out? If so, it looks like your new cartridges are not working properly. Try another yellow and magenta cartridge - you can re-use the previous cartridges if they turn out not to be faulty. If new cartridges don't solve the problem, you can try soaking the print head, in case you have nozzles blocked with dried ink for some reason.
Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any magenta/yellow ink on the nozzle check, then there is hope! Repeat the head clean/nozzle check process 2 or 3 times, but not more. Leave for 24 hours for any air bubbles to disperse. If nothing, repeat the soak process once more. If still nothing, post a new comment detailing what you have done and the results.
May 04, 2009 | Epson Stylus C86 InkJet Printer
Black Ink won't print
epson printers are very picky about the ink it could be possible that the off brand ink has ruined the print head
Feb 10, 2009 | Epson Stylus CX4200 All-In-One InkJet...
Colors are not printing properly
Looks like your printer head is in need of replacement
Nov 11, 2008 | Canon i950 InkJet Photo Printer
Color
Recheck the placement of the ink cartridges. The black ink cartridge is larger; the cyan, magenta, yellow cartridges are all the same size.
When the ink cartridges were replaced, two or more may have been inadvertently switched or an extra yellow cartridge placed in.
Aug 04, 2008 | Canon BubbleJet i560 InkJet Printer
Cannot get yellow to print
I had the same problem with the yellow cartridge. Yellow quit printing, put in a new yellow and still would not print yellow. I had a help file, don't know where I got it, but it suggested replacing the black ink cartridge also, even though the black wasn't low yet. Replaced the black, ran a few nozzle cleans and everything worked fine. Don't know why. Try it
Mar 03, 2007 | Epson Stylus CX6600 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
60 people viewed this question
Ben Johnson
