Question about Polaris Garden
How to replace axle seal on rear gear case 2008 polaris ranger xp because it is leaking
  • 883 Answers
SOURCE: Rear Axle Removal
rate me solved...this is all I can find...
figure 1
figure 2
Posted on Jun 27, 2008
  • 51 Answers
SOURCE: Left rear axle seal is leaking differental oil.
ok then here is the procedure  1 take off the axle nut
2 on the lower control arm you will find a large nut and bolt i belive the nut is a 21mm and the bolt side is an 18mm. this bolt is the one at the knuckle near the brakes. remove it
3 you will need to pull the knuckle out of the way or a helper to pull the knuckle out of the way so you can slip the axle out of the knuckle.( its a tight fit but there is room to slip it out.)
4 use a pry bar to pop the axle free of the diff. hosing its held in by a spring clip make sure the clip comes out with the axle if it gets stuck inside you will have to fish it out.
5 use a pry bar or screwdriver to pry seal out of housing then use a flat object that contacts the entire rim of the new seal so it can evenly be installed with out getting smashed and tap it in with a hammer. ( a good trick here is to use some grease and pack it into the new seal where the spring is this will prevent the spring from being shocked out of the seal during instalation . the spring keeps tension on the rubber in the seal so it stays tight to the shaft it is sealing.)
6 then revers the above steps. also make sure you are using the right gear lube it will most likely be 75w-140 but make sure you check your owners manual will tell you if it doesnt say on the diff cover. you can cause a lot of damage if you put in the wrong thing. and make sure  you feel the axle spring clip snap into place.
as a note there are two types of axle seals that are used on these so if the new seal looks different than the old seal then the folliowing will be important to you.the seals on these have been redesigned so if you axle has what looks like a cup or dust cover pressed onto the shaft where it goes into the diff the new style does not use this and it will prevent the axle form going in all the way so the spring clip will not lock in and you will have a leak. so you will have to remove it and install the axle without it.
Posted on Mar 22, 2009
  • 1596 Answers
SOURCE: rear axle seal replacement
Drain axel of Fluid, Roemve Diff Cover (Push IN on Axel to reseal at Wheel side) Remove KEEPERS From Insied END of axel then Pull OUT on WHEEL END of Axel. use Proper Seal removal tool to remove seal. Also Use PROPER Install tool for SEAL INSTALL Reverse Procedure to Install. In hopes this helps you Out.
Please RATE Me Also LoL Thank You.
Posted on Mar 24, 2009
  • 52 Answers
SOURCE: Rear Axle Seal Replacement
remove rear tires, then remove brake calipers and rotors, then remove the 4 nuts (each side) that hold the axle shafts to the axle tube (located around the axle tube behind the backing plate) then using a slide hammer pull the axle shafts out, next using a die grinder and an air hammer get he retainer collar and the bearing off (without damaging the axle shaft) then remove the seal and the outer race which will still be in the housing. next put it all back together, make sure the plate with the studs is still on then slide the seal, bearing, then retainer on (all new parts) and using a press push them all the way back on. then is simple reassembly.
Posted on Apr 22, 2009
  • 335 Answers
SOURCE: REAR AXLE SEAL LEAKING ONTO BRAKE SHOES NEED INSTRUCTIONS ON HOW TO FIX
Jack up vehicle and support on stands. Remove wheels. Remove differential cover . Locate and remove lock pin that holds cross shaft in. Slide cross shaft out. Push axle inward to release axle c clip. Remove axle and pry out old seal. Install new seal with proper tool.Add some lube to the seal lip to aid axle intallation. Revese removal procedure. This is for a "c" type axle.
Another type has 4 nuts attaching a retainer plate to the backing plate behind the axle flange. In this case the 4 nuts are removed and the axle will come out. This may require a little effort. I think that you have a "c" type axle in your vehicle. Hope this helps. Moe
Posted on Apr 28, 2009
1999. How can I replace front diff seal?
on the actual front diffr, pinion or the front transfer case seal
the front seal is like the rear.
its a crush cage.
that means when you remove the pinion yoke/flange big bolt
the crash cage is destroyed. also wrecking pinion gear to ring gear back lash..oops.. big big mess-up there...$$$$$$
and such cage must be replaced.
questions????????????
how can you be sure its leaking, when the engine this old loves leak oil
i bet that oil on the ground does not small at all like the nasty stink of hypoid GL5 gear lube. I BET
why not post how to find leaks first
and not do $1000 damage
no engine size posted G16? J20?>
The G16, ill demonstrate (coin toss)
Distributor 2 , o-rings leak like made, all do this old !!!!
same with the 60k mile service and valve cover gasket
all leak, for that reason alone, on all 1990s era
next is cam seal
crank seal
pan seal (or pan is rusted thru as many see (today)
oil pump seal
and gawd forbid the rear main seal , engine.
easy peasy japanezzy
why not ask your mechanic to sniff that oil first and save a fortune
guessing.
see man pulling axle to remove pan
wana do that?
http://www.fixkick.com/axles/Pan-drop/pandrop.html
to replace this seal, remove the carrier first
then take it to a shop that can rework the carrier
the correct way.
Jan 25, 2016 | Geo Tracker Cars & Trucks
Left rear axle seal leaking on 2007 ford escape how do you fix it
you will have to dimantle rear hub withdraw driveshaft and replace seal oon axle drain axle oil first square drain plug in centre of axle hope this helps
Sep 22, 2012 | Cars & Trucks
2008 Mercury Mariner rear axle is leaking. Is there a possibility I can just tighten it down or will it require me to replace it?
You have to loosen the rear suspension on that side
Remove the axle nut & pull the knuckle clear of the axle
Then remove the axle on the side that leaks
Change the seal & replace axle,etc.
Jul 08, 2012 | 2008 Mercury Mariner
Axle seal keeps leaking
Most likely you need to replace the axle shaft.
Jun 22, 2017 | Cars & Trucks
Fluid leak from left rear axle housing
This is caused by a leaking rear axle seal you will need to pull the left rear axle out and change the seal and check for a worn axle bearing, this requires the removal of the differential cover, pin and center block or posi spring and clutch pack (if so equipped) and spider gears and then the "C" clip that retains the axle into the gear carrier, u will need a tube of silicone to reseal the cover and a axle seal installer tool and about 2 hours of your time
Oct 28, 2010 | 2000 Ford Mustang
Does a 2009 ranger xp rear gear case normally have a magnetic drain plug?
I don't remember the drain plugs being magnetic.
Polaris uses a very high quality synthetic gear oil, and most failures are caused by neglect or abuse (water through the vent hose).
Sep 13, 2010 | Polaris ATV
2005 single axle F-350
Yes you will need to pull the axle to get that seal out. You will need to pull tire open punkin or gear case there will be a C clip holding the axle inplace pull this out and very carefully slide the axle out the seal is in the axle housing
Apr 08, 2010 | 2005 Ford F 350 Super Duty
Rear wheel seal leaking
Remember SAFETY FIRST. Jack up the right rear wheel, support the axle with a jack stand, remove the wheel, the brake drum, the banjo cover or differential cover. Allow the gear oil to drain out into you drain pan, carefully and slowly spin the ring gear (watch out not to pinch your fingers) look for a small bolt that is restraining the king pin, remove the bolt and then carefully slide the pin out !(don't spin the axles or ring gear while the pin is out) if you do the bushings and spider gers will move out of their places. After the pin is out then go over to the exposed axle and push it in until it stops. Go back over to the pumpkin and look inside, for a "U" shaped washer it will be on the end of the axle. Remove it from the axle. Now you can remove the axle and replace the wheel seal. Either rent a seal installing tool or carefully use a block of wood and evenly install the seal. If you kink or damage the new seal remove it and try it again. When you put everything back together put a little thread lock on the bolt for the king pin. dont over tighten it, could snap it. Let me know if I can help any more.
May 27, 2009 | 1999 Ford Ranger SuperCab
Getting rear gears out of the difential case 1999 dodge durango
  1. Raise and support vehicle. Ensure that the transmission is in neutral.
  2. Remove wheel and tire assembly.
  3. Remove brake drum. Refer toBrakes, for proper procedure.
  4. Clean all foreign material from housing cover area.
  5. Loosen housing cover bolts. Drain lubricant from the housing and axle shaft tubes. Remove housing cover.
  6. Rotate differential case so that pinion mate gear shaft lock screw is accessible. Remove lock screw and pinion mate gear shaft from differential case
  7. Push axle shaft inward and remove axle shaft C - clip lock from the axle shaft
  8. Remove axle shaft. Use care to prevent damage to axle shaft bearing and seal, which will remain in axle shaft tube.
  9. Inspect axle shaft seal for leakage or damage.
  10. Inspect roller bearing contact surface on axle shaft for signs of brinelling, galling and pitting. If any of these conditions exist, the axle shaft and/or bearing and seal must be replaced
Feb 07, 2009 | 1999 Dodge Durango
Trying to identify rear differential on 87 ford ranger 7.5 or 8.0 need to replace since teeth from gears were in case.
You most likely have the 7.5, as that was the stock rear axle on older rangers.
There should be a tag on the differential cover bolt that has the gear ratio and differential size on it.
Jan 03, 2009 | 1991 Ford Ranger Supercab
Garden Logo
140 people viewed this question
Top Polaris Garden Experts
Paul Bade
john h
Are you a Polaris Garden Expert? Answer questions, earn points and help others
