Question about Kenwood Car Audio & Video
Kenwood KAC-859 red light flashing - Kenwood Car Audio & Video
SOURCE: kenwood kac 859 amp
The amp will reset every time it's turned off. The red light flashing, instead of staying constant is a warning that one of the protection circuits are activated. If the amp is bridged wrong, it can do this. If the load impedance is too low, it can also do this... don't trust the speaker, it it says 4-ohm, it may actually be 3.8-ohm, which could cause a problem if two speakers are wired in parallel. If it's not getting enough power, it will turn off briefly, but will turn back on after a second. A capacitor is not necessary with this, just use 4 gauge cable and have a good battery... make sure the ground is good, that one is commonly ignored.
Posted on Aug 21, 2007
  • 631 Answers
SOURCE: kenwood KAC-PS201T
The first thing you must do is to confirm that you have voltage at the amp. Just because the fuses look good, that doesn't mean you're getting power to the amp.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Posted on Jan 22, 2008
etirbynnor
  • 655 Answers
SOURCE: To bridge a Kenwood KAC-9102D
Hello laurogleal,
The Kenwood KAC-9102D is a mono amp. There is no bridging. Having two sets of terminals is just a more convenient way of connecting two subwoofers. The amp is stable down to 2 ohms impedance, so it is safe to run 2 4 ohm loads in parallel.
Hope this helps.
Posted on Apr 28, 2009
wikkidd420
  • 96 Answers
SOURCE: want to bridge my subs I have a kenwood kac-719
from what i have read about your amp, it is already a mono amp, and rated for 2 ohm's, so all you have to do is wire the subs in parallel (both positives together to positive and both negatives together to negative) or series/parallel if you have dual voice coils (both positive and both negative paired on each sub, then positive from amp to positive on one sub; negative on that sub to positive on next sub; then negative on sub to negative on amp) Note though, with two dual voice coil subs, you can have a 1 ohm load with the first set up, which can damage your amp. Let me know if this helps :)
Posted on Jun 11, 2009
demonsm
  • 253 Answers
SOURCE: Have a Kenwood KAC-9104D the red triangle is flashing
maybe when hook up something sorted and blew the sub side .I have seen it happen
Posted on Nov 27, 2009
My Kenwood kac9152D turns on but why dose the red light on the top keep flashing?
The manual only says the power indicator burns when the power is on.
I can't find anything about it also should flash. The only thing I can think of, it has detected an error, like a blown amp or a low impedance on a speaker terminal.
Here is the manual:
http://images.kenwood.eu/files/prod/29/5/KAC-9152D_9102D_8152D_8102D_(EN).pdf
Jan 17, 2015 | Kenwood KAC-9152D Car Audio Amplifier
How many watts dose a kenwood kac-859 have
80 Watts x 4 + 240 Watts x 1 It all depends on how you have it hooked up. Let me know if you need additional information on this.
Thanks
Jan 03, 2011 | Kenwood KAC-859 Car Audio Amplifier
Nov 27, 2009 | Kenwood KAC-9104D Car Audio Amplifier
On a kac-x650d does the power light stay on or flash
Hello mpredday,
The Kenwood Excelon KAC-X650D power light is ON during normal operation. It blinks blue to indicate BMS selection, yellow for low voltage, purple for DC voltage on the outputs, red for overheating, and green for a shorted or grounded speaker wire.
Hope this helps.
Jul 29, 2009 | Kenwood Car Audio & Video
A red light is flashing
On the top? is it your power protection light?
May 26, 2009 | Kenwood KAC-5201 Car Audio Amplifier
Amp Problems
Unplug the stereo input signal from the amp. If the amp does not do it with the wires unplugged, you may have a problem with the radio sending too much voltage to the input of your amp causing it to go into protect mode. If it continues it is in your power source to the units. Let me know and I'll see what Ii can do. Hope this helps...
Jul 14, 2008 | Kenwood KAC-859 Car Audio Amplifier
Kenwood kac 859 amp
hi, note that if you are not using the proper gauge b+ and gnd cable with this amp then the current available at the amp wont be sufficint to keep amp on. also try using this amp while vehicle is idling. if this doesnt work then disconnect all spks from amp and check if red lite stops flashing. if it doesnt stop flashing then amp has internal fault. if lite stays on brite then proceed to check each spk load impedance, then reconnect each spk individually. the minute red lite starts flashing it will give you a clue that the channel or spk load is faulty. cheers
Jul 27, 2007 | Kenwood KAC-859 Car Audio Amplifier
Car Audio & Video Logo
66 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
