Question about Dryers
How to replace belt on samsung dryer model # DV209AEW/XAA
Just need detailed instructions on how to put new dryer belt on
4 Suggested Answers
  • 291 Answers
SOURCE: have a samsung dryer model DV209AEW/XAA. I "hand
Check to make sure your child lock is off first. Hold the time and signal buttons simultaneously for three seconds. Unlikely, but do check. Some of these dryers have a safety switch that the idler pulley has to engage to allow the dryer to run. I tried to find a schematic for this model but could not get one to tell if you do have a safety switch. Look at the arm of the idler pulley and see if it is contacting the switch actuator correctly. When a belt breaks or pops off, sometimes the arm of the pulley will move to the other side of the switch actuator and will not allow the dryer to run once a belt is reistalled. I would also look to see if a wire was knocked off of the motor switch when your belt came off. Good Luck, Appliance Specialists
Posted on Dec 03, 2010
hunter19_46m
  • 7482 Answers
SOURCE: I need to replace the
Hi lisavawter...
Your best bet is to buy a service manual, so it will tell you everything you need to know about servicing your dryer...
You can get one at this webpage...
Please take time to rate me
http://www.samsungpart.com/Products/Parts_and_Accessories/DV209AEW/XAA/Default.aspx
Posted on Aug 12, 2011
Macmarkus
  • 2605 Answers
SOURCE: I need to know how
Hello, welcome to FixYa.
Based on your post, you have a Samsung dryer and the belt has come off.
I've seen this many, many times...though the belt usually doesn't break it just comes off. Very common for Samsung dryers for whatever reason.
**Unplug the unit before proceeding...safety first**...
The good news is if you can get to it from the back you can simply remove the small panel around the exhaust tube as shown here,
if it's not accessible from back you'll need to go from the front...that's do-able too, just a little more involved. Let me know.
Once in the back the belt should look like this when routed properly, with the "V" grooves towards the drum and motor pulley.
i.e.
Hope that moves you forward...or even better, fixed up.
Let me know what you find. I will try to help in any manner I can of course as well. Good luck.
Regards,
Macmarkus :)
Posted on Aug 26, 2011
Samsung elec dryer, Model dv5451aew xaa 01. Drum not spinning. Belt ok. Dr Sw ok. Changed both fuses on heating element. Nothing.
Samsung dryer won't spin, belt is fine - Fixya
www.fixya.com/support/t8946132-samsung_dryer_won_39_t_spin_belt
Apr 14, 2011 - Question about Samsung DV218AEW Electric Dryer. 2 Answers ....Samsung dv410aer/xaa motor hums but drum will not spin. Mar 21, 2014 ...
How to Fix a Samsung Dryer: the Drum Won't Spin
www.ehow.com > Home
From time to time a dryer's drum can fail either by jamming up, a technical error ...Support US Samsung: The Dryer Drum Does Not Spin ยท Repair2000: How to .
Oct 16, 2015 | Samsung Dryers
WHAT DOES ts error code on a samsung dryer
A ts error means that there is either a thermistor short or the vent is blocked. First check the entire dryer vent from the dryer to the outlet. Clean any lint build up and make sure that the vent isn't constricted around any objects if you have flexible ducting. Check that the flap hasn't shifted to block the vent outlet. (I've seen this a few times.)
If that doesn't solve the problem, replace the thermistor. It's part 7 on this diagram: http://www.searspartsdirect.com/partsdirect/part-model/Samsung-Parts/Dryer-Parts/Model-DV209AEWXAA0000/1482/0151200/50039356/00005?blt=06&prst=&shdMod= . If your dryer is still under warranty, contact Samsung for the repair.
I hope this helps.
Sep 05, 2014 | Samsung Dryers
I am trying to replace the belt on my front load Samsung dryer model dv419aew/xaa
you will need to pull the top to gain acces to the control panel which you will remove to get to the screws on the front and go from there
Mar 24, 2014 | Samsung 7.3 Cu. Ft. Electric Dryer
Samsung Dryer Model DV419AEW /XAA Dryer will not
I doubt its the main board. Try seeing if the drum is tight and seeing if the belt broke by spinning it by hand. If the drum is real sloppy and you can't feel motor tension, you need a belt. I would rule out the mainboard until last because the belt is like 89 cents.
http://www.amazon.com/341241-Whirlpool-Kenmore-Dryer-Belt/dp/B00064NH6E
http://www.youtube.com/watch?v=zNATJ8qyqP4
Sep 27, 2013 | Samsung Clothes Dryer Control Panel Main...
Samsung dryer DV209AEW/XAA, How does the belt go on the pulley system in the back of the dryer? Can't seem to get it tight.
I never fixed a thing in my life and thanks to Macmarkus, who was right on the mark with what was wrong with my dryer, I was able to make the repair without uttering one cuss word. I didn't have to spend a dime either. Thanks so much. Rich
Aug 26, 2011 | Samsung 7.3 Cu. Ft. Electric Dryer
I need to replace the belt on my dv209aew dryer, I need to take my dryer apart and put it back together
Hi lisavawter...
Aug 12, 2011 | Dryers
Dv209aew/xaa where is heating element
Under the drum on the right hand side. To get to it you will need to remove the top panel. UNPLUG it. take out the 4 screws that hold the control panel in place. Take out the three screws that hold the Main control board( on the lefthand side). Unhook the control board connectors from the main control board. Remove the control panel. Take off the 2 bottom screws inside the door, take off the 4 screws that hold the front cover plate. Take off front the front cover. Take off the 5 screws that hols the drum plate. Remove it. Remove the belt, and the metal bracket on top. Take out the drum and you will be able to access the element.
Jan 30, 2011 | Samsung DV218AEW Electric Dryer
Have a samsung dryer model DV209AEW/XAA. I "hand
Dec 03, 2010 | Samsung 7.3 Cu. Ft. Electric Dryer
Our dryer (Samsung Model DV218AGW/XAA) has power, no error messages, but will not start. When you press the "start" button, there is a click, but the drum will not move, no heat, etc...
I had the same issue with a Samsung DV209AEW/XAA.
What I found was the belt had come off and the spring on the drum belt pully had come off.
After I disassembled the whole top and front to figure out I could not access what I needed from there I discovered I needed to enter in from the vent is.
Anyway here is some info:
Rear Access:
1) On the back where the Vent comes out you have 4 total screws. 3 of them are on the outside edge and the fourth is more of a middle mount that holds the tube to this bracket. Remove all four screws now you can lift and lean this plate to remove it.
2) This will also free up the vent tube and it can be pulled and cleaned also if you desire.
3) With these items out of the way you can now access the pulley for the belt and other items.
Nov 13, 2010 | Samsung DV448AEE Electric Dryer
Dryers Logo
206 people viewed this question
Top Dryers Experts
