Toshiba satellite a200-1md can boot from usb drive
SOURCE: Toshiba Satellite 5005-S504; boot from USB? Reformat HD w/o CD-ROM?
First these laptops are what is called "Legacy Free", meaning there is no BIOS, at all, ever, for all time, not gonna be there.
Second, the Floppy option is referring to any supported USB Floppy drive. If you have one great, if not this will be more difficult.
NOTE**** - If at any point you do not know what I'm referring to, please do not attempt this, you will likely render your HDD useless.
If you have the Floppy on USB, then you will need the XP setup on Floppy Disk and there are alot of disks, and from my own experience so far, No, a USB flash drive will not work, I even tried an emulator which formatted it as a floppy disk.
If you do not have a floppy, then you will need to remove the harddrive and connect it via an external USB drive cage to another pc, create two partitions, one for your OEM OS disc, the other for the installation. Obviously your OEM OS Disc is not all that large, only partition what it needs, and make sure you make it a bootable partition. For XP you will also need the SATA drivers for the hard drive as XP does not have them included in the setup disc. If you do not have these, you will need to find them or just stop here, because you can go no further.
This is one of the biggest drawbacks of a "Legacy Free" system, you cannot change the SATA operation in BIOS like most other pc's. The system configuration is done through a windows utility from Toshiba.
Posted on Jan 09, 2009
SOURCE: toshiba satellite a50
try turn the usb on in the bios. it could be switched off. just tick one of the settings that will allow the usb drive to be recognized
Posted on Apr 14, 2009
jabems
  • 43 Answers
SOURCE: Toshiba Satellite Pro L300 USB Drive Problem
maybe the usb drive that u have now.. is in the raw files and theres nothing you can do.. you should replace the usb drive.. but try to insert that one in other pc. if it will read.. try to check the setup of your laptop
Posted on Oct 25, 2009
  • 13433 Answers
SOURCE: Toshiba Satellite A215-S5849 Laptop -
take out the battery and ac adapter for 5 minutes, hold down the power button for 60 seconds, plug back in the ac adapter and turn on, try entering the bios.
if the problem remains and since you are unable to boot from any device, you would either have to send this laptop to a repairer, or remove the hard drive from the laptop, use a adapter to connect it to a desktop machine or to another laptop and begin the windows setup on another machine, or install windows on another machine (may cause a blue screen when switched to another machine)
or make the hard drive bootable, copy windows setup files into the drive and install from the drive.
Posted on Apr 07, 2010
bigjohn007
  • 425 Answers
SOURCE: how do I boot my
hi,
here is what you are going to do.
I have linked below a video from you tube to guide you.
Just view this and give you the steps to do it.
Hope this is useful to you.
Don't forget to rate me. Thanks...
Regards,
John
Posted on Jan 11, 2011
My toshiba satellite a50, i want to change boot order to usb drive
If you want to change the boot just for one time press and hold F12 during the booting proces but if you want the computer to boot every time in USB mode you must press F2 to enter the bios setup, look for the boot priority option chnage save, exit and restar.
Enjoy
May 15, 2014 | Toshiba Sattelite A105-S2071 Notebook
How can i go in boot option
Normally when you power on your Toshiba Satellite laptop it attempts to boot the operating system installed on its hard drive.
In some instances you may want to boot the Satellite laptop from a different device, such as an operating system installation CD or a USB drive.
The boot order doesn't have to permanently be set to the hard drive.
It's possible to access the boot order before the operating system loads and change which device is set to boot first.
Turn off the Toshiba Satellite laptop.
Turn it back on immediately and wait for the "press the F2 key to enter Setup" entry to show up on the screen.
Press the "F2" key to access the Toshiba Satellite's BIOS menu.
Use the right arrow key to navigate to the BIOS tab labeled "Boot."
Scroll down to the option labeled "Boot Priority" and tap Enter.
Check through the list of devices and locate the specific device you want to use to Boot your Toshiba laptop, such as "CD-ROM," "USB" or "LAN."
Highlight the name of the device in the list and then tap Enter to make it the top boot priority.
Use the right arrow key again to scroll over to the "Exit" BIOS menu.
Tap the down arrow key to highlight the "Save and Exit" option.
Press Enter to save the new boot order and restart your Toshiba Satellite laptop.
Repeat the procedure when you want to change the boot order back to its original setting.
How to boot your Toshiba PC from CD-ROM, LAN, or diskette
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?soid=403623
Toshiba support
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=ex&bbid=bb42&url=&dialogID=111194172&stateId=1%200%20111190763
Aug 02, 2013 | Toshiba Satellite 2415-S205 Notebook
How to change disk controller in bios on Toshiba Satellite A135-s2276?
Hello here is the homepage:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1596141&
You need this for the drivers.
And you can downlaod a manual
Press the "F2" key to access the Toshiba Satellite's BIOS menu. Use the right arrow key to navigate to the BIOS tab labeled "Boot."
Read more: How to Change the Boot Order for a Toshiba Satellite ' eHow.com http://www.ehow.com/how_6383103_change-boot-order-toshiba-satellite.html#ixzz2Cn6HdU2k
Turn on or restart your computer and watch for a message during the post about a particular key, usually Del or F2, that you'll need to press to ...enter SETUP. Press this key as soon as you see the message.
Go to boot and select the boot order.Use F4 or F5 to change.
First boot device: Cd/dvd drive
Second: the harddrive.
Leave the bios and save the settings.
Place your windows cd in the drive and reboot.
Now you can install windows again.
Good luck
Nov 20, 2012 | Toshiba Satellite A135-S2276 Notebook
Toshiba satellite l750-16l "a disk read error occurred"will a new hard drive fix
You hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 06, 2012 | Toshiba Computers & Internet
Need to update bios toshiba satellite c660,using ubuntu live dvd, will not boot hard drive, all normal recovery options used up
Hi There,
There are currently no easy ways to update a bios through linux at all - including live cd's. Your best bet is to make a bios update USB stick (or floppy depending on the age of the computer)
Here's a link to those instructions:
http://www.biosflash.com/e/bios-boot-usb-stick.htm
Alternatively, speaking from my own experience with a similar situation, you can take the hard drive out, use it in place of the usb stick, boot from it, update your bios, and go from there.
Jun 06, 2012 | Toshiba satellite c660
I am trying to figure out how to boot from a usb drive on my toshiba satellite 1415-s105
1. Press F12 key while the Toshiba splash screen is on, this will bring up the boot options menu.
2. Immediately after pressing the power-on button, press the U key.
For more information on boot options for Toshiba:
Jul 21, 2011 | Toshiba Satellite 1415-S105 Notebook
I have a Toshiba satellite a45-s120 and no CD/DVR-Rom can I use a bootable Flash Drive to install windows XP?
`st go into your system setup and see if you have under boot priority book from usb device. if so make that your 1st boot device. then its best that you download a prebuilder utility to configure your bootable flash drive
May 30, 2011 | Toshiba Satellite A45-S120 Notebook
Have a Toshiba Satellite M40 I'm trying to work on for a client and having serious trouble... I have the original restore cd and a legitimate Win xp Pro cd and the machine won't boot off either. It just...
try holding f2 or f10 at boot, right when you turn it on, and hold it in until you get into bios or a boot selection screen. then you need to set the cd drive as the primary, only boot device for the time being
May 21, 2010 | Toshiba Satellite P15-S470 (PSP10U-0GGPGR)...
Hello, is there a way to boot the a15-s157 from the usb drive?
Yes you can by using a USB External Portable CD/DVD Drive. This are any basic methods to run or boot from the CD/DVD Drive.
I use it, good luck!
Sep 29, 2009 | Toshiba Satellite A15-S157 Notebook
Boot from usb
Sounds like the boot order menu is what you have. Set the boot order menu to try other devices before the hard drive. (Example: CD/DVD drive, floppy; if present, USB devices, hard drive). You should have a default key for accessing the boot menu (usually f11 or f12). Hit this key and choose the USB option. Make sure the device you want to boot to is already connected before you turn on the laptop.
Mar 01, 2009 | Toshiba Satellite A60 Notebook
Computers & Internet Logo
195 people viewed this question
David Payne
David Payne
