Question about Zenith P60W26 60 in. HD-Ready Plasma Television
Hdmi port not working for ps3
The hdmi port is not conecting to my ps3 but it will work through my directv. i have tried two different hdmi cables.
  • Anonymous Jan 15, 2009
    i have the same problem. the HDMI port has been having probs for a few months. the screen was flickering, turning green, switching off during play, etc. a few tweeks of the cable usually sorted this out. some times the HDMI just didn't register and the ps3 needed resetting as everyone describes here. i bought a new HDMI cable and everything was fine for a month. playing one minute switched off for a couple of hours came to play again and nothing. works fine through component SD but no chance through HDMI. the PS3 at times recognises a HDMI connection but will not output through it. will have to call SONY and it's 13 months old! the problem started at about 10 months so BEWARE!
Believe it or not it might be your tv. mine did the exact same thing and i thought it was my ps3 but who wlda guessed its the tv lol. soo heres what you do. leave ur ps3 plugged in to your tv through hdmi, then all you do is unplug your tv from the wall, and wait for about 20 mins then volia!!!!! hmdi at its best. i do not know how it works but it does and i hav not had a problem since.
Posted on Sep 15, 2010
How to fix issues whith component outputs on haier hlh26atbb 26 in. lcd ?
When you make the connection with HDMI are you changing the source or input key on the television to activate HDMI port? If you don't activate the corresponding source you connect to and leave the TV in the TV mode, you won't actually see the device you are connecting. It's possible the TV does not support the 1080P from your PS3.
Apr 17, 2015 | Haier HLH26ATBB 26 in. LCD Television
Help with sound problem
Try doing the following: go to audio output settings and set your audio output port to HDMI.
Jun 19, 2013 | Video Game Consoles & Games
Cant get output ps3 on hdmi cable
  • Make sure the system is off.
  • Hold down the Power Button for 5-6 seconds - until you hear the second beep.
    This resets the video settings to defaults (standard video output).
    Power up the PS3 again and it should auto-detect the hdmi at this point.
    If that does not work use the original audio/video cable that came with the system, power it on, then adjust the video settings and try the hdmi cable again.
  • May 18, 2012 | Video Game Consoles & Games
    Hi, I have a samsung LE40B750. It is connected
    Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
    Sep 05, 2011 | Samsung Televison & Video
    I plugged in my PS3 using an HDMI cable and i get no feedback
    If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
    May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
    Sony Playstation 3 + HDMI + Samsung Series 5 47"LCD Problems (tried all solutions i found) OK at my wits end now. Heres the testing I have done. Have the ps3 connected to the set using the av...
    make sure ur not using both the av cable and the hdmi on some models it causes conflict although they are on different inputs. also did you try using a blu ray player or another ps3 on that hdmi port using the same cables or different cables? if another equipment work/don't work u can at least start to narrow down your problem..
    Apr 27, 2010 | Sony Playstation 3 (PS3) Console
    HDMI picture is saturated in the wrong color
    The problem is generally the cables, period. If there is a condition whereby the cable was bent, kinked, overheated, or the end damaged in any way, this problem can exist. Many times when a cable is attached to the device, it is cross-threaded or left loose. If the contact is not 100%, you can experience this condition. I suggest that you obtain NEW cables and connect them tightly and firmly in place. This should eliminate the problem, UNLESS the male connection on the device/s have been compromised.
    Jan 14, 2018 | Philips SWV6813-17 HDMI 3-Way Switcher
    No surround sound from my PS3 through the Onkyo 5100. Video OK
    Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
    Jan 24, 2009 | Onkyo Audio Players & Recorders
    PS3 to XBR1 HDMI
    hey, im hopeing the tech will be able to sort it out for you, theres not much any of us can tell you what he couldnt tell you tomorrow so be patient.
    if he doesnt get it sorted drop us a comment and il try to help you.
    Mar 23, 2008 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
    Zenith P60W26 60 in. HD-Ready Plasma Television Logo
    1,579 people viewed this question
    Top Zenith Televison & Video Experts
    matt martin
    matt martin
    Computer Repairing
    Computer Repairing
    Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
