Question about Hitachi 60SDX88B 60" Rear Projection Television
Cant see top 2" of program
When i am watching tv i cant see the top 2". i dont have a manual and cant find the menu to adust the screen. where is the menu to adjust the screen?
  • 1,056 Answers
Try going to the service mode. I think it goes like this. Press menu, and hold it. Then press volume up and volume down at the same time for 8 seconds. Then you should be able to go to service mode. scroll down till you find the adjustment for vertical size, the top part. If the service mode proceedure I gave you is wrong, You can try asking someone else here if they know how to go into service mode for your particular model.
Posted on Jun 30, 2009
TV SHARP LC32HT3U DONT SHOW MENU ON SCREEN
Try a hard reset too. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset.
Aug 22, 2015 | Sharp Televison & Video
Forgot my parent control password and i cant watch tv
This sounds like a common problem on these TVs. Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Mar 04, 2012 | AOC L22W861 22 in. LCD HDTV
My screen indicates hdmi 720p on the top right corner then the video menu pops up. it goes back and forth making watching tv unbarable. also the volume flashes when it is pressed i have a Hesense 32 inch...
The HDMI 720p pop up,because on the tv Menu setup OPTION,U pick YES on the tv Program Title Display option,pick NO should stop the pop up HDMI 720p indicator.The volume bar indicator pop up when it press the button to turn volume up or down it is mornal functions of the tv.
Apr 04, 2011 | Televison & Video
Cant turn off closed caption
sherrillbrom
With our VIP receiver models, you have an option to turn on/off closed caption through the receiver. Press the Menu button on the remote, which will display the Main Menu on the TV screen. Press 8 (Preferences) and then press 6 (Closed Caption). On the Closed Caption screen, press 1. On the Closed Caption On/Off screen, select CC Off and then press Done from the TV screen (using your DISH remote). This will turn the feature off on the receiver. Test to see if it is turned off by watching a program that has CC. If it still appears, then the feature is activated through your TV. Please refer to your TV manual to turn the feature off. I hope this helps.
Ray Calo
DISH Network
Feb 21, 2011 | Televison & Video
When connecting my Blue Ray DVD Player (Panasonic DMP-BD35) to my JVC TV (LT-37DS6BJ) I get large black bars at the top & bottom of the screen despite changing the aspect ratio on the DVD. The TV...
It all depends on the dvd that you are watching you cant change it to anything bigger than what is was recorded.
You will have to just watch it like it is. I have the same thing with my dvd player its really thin picture its annoying
Dec 04, 2008 | JVC Televison & Video
Blurred pic on tv
you can take the back off find your flyback (the big part with a red or pink wire going to the picture tube) and adjust the small pot or potentiometer closest to the top while the set is on in front of a mirror and try adusting the focus control.
if cant get nothing but blur replace the fly or focus assembly if not built in the fly. I would change both.
Jan 26, 2008 | Hitachi C21RF39 21" TV
Input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Jan 05, 2008 | Sanyo DS24205 24" TV
Magnavox MPTV68A "Magnavox" emblem is displayed and won't disappear
I don't know the exact TV, but Magnavox usually have an item or two items in the menu system where the "Magnavox" and also the "blue screen of death" can be disabled. Look in your manual.
I'd suggest the reason it appears is temporary loss of signal from the antenna, set top box, cable system or whatever it is you receive your TV programming via. I don't have an answer as to why it occurs watching video, but turning off the logo and blue screen should help. If it still occurs, it's time for professional intervention!
Jan 02, 2008 | Philips Magnavox 27MS343S 27" TV
Hitachi 60SDX88B 60" Rear Projection Television Logo
77 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
