Question about Toshiba Computers & Internet
Toshiba Laptop satellite l500-226 Dark screen-cant really see it!! help!!
SOURCE: Toshiba satellite A205-S5847 booting problem
Check your GraphicCard. Have you tried downgrading to XP and can you tell if you facing same problem?
Posted on Jul 26, 2008
  • 320 Answers
SOURCE: toshiba satellite L30 PLS30L-00M00D
Please go to the below link and select the type of operating system you are using and download the drivers. Hopefully it should work.
"http://eu.computers.toshiba-europe.com/cgi-bin/ToshibaCSG/download_drivers_bios.jsp?service=EU"
Thank you..
Posted on Sep 10, 2008
Geekman
  • 32281 Answers
SOURCE: Friend's Laptop Screen has become too dark to work with
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Apr 24, 2009
  • 36 Answers
SOURCE: cant type @ key in toshiba satellite L300 laptop
you need to change the layout of your keyboard. "Regional Settings" in windows.
Check on http://en.wikipedia.org/wiki/Keyboard_layout what your layout is and configure the correct one in the operating system you are using
Posted on Aug 11, 2009
  • 25 Answers
SOURCE: TOSHIBA SATELLITE A205-S5000 WORKED THIS MORNING,
It sounds like the battery is done...happens a lot. You may be able to just by a new battery pack to solve the problem.
Posted on Oct 06, 2009
My laptop screen is black, no light or picture at all. I can use an external moitor but the laptop monitor show s no form of life. Would this be my Inverter, my monitor/screen or something else.
First of all do you see anything on the screen, but really really dark, or is it pitch black. If you see something but it is black, then it is your screen backlit bulb and needs to be replaced. If it is just pitch black and nothing, then it mostly your inverter or a loose connection between your base to your screen since laptop tends to open and close alot.
Jan 17, 2011 | Toshiba Satellite M60 Notebook
Toshiba Satellite 105A screen too dark to see password box
have you tried the F5 key?
On a lot of laptops that toggles the video output between the laptop display and the external display connection (socket on rear of laptop).
Cheers,
Steve
Apr 09, 2010 | Computers & Internet
The screen on my Toshiba satellite p205 went dark on me i check and u can see the window but really dark i replace the lcd screen and the problem persist help please what can the problem be my video...
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Nov 24, 2009 | Toshiba Satellite P205-S7806 Laptop
Toshiba Satellite a45-s130 screen has gone real dark need a flash
Paul, Georgiana and You, 1. do you have an antivirus installed on your laptop? if not, then install one rightaway. 2. also from start->control panel->system->hardware->display adapters and monitor. uninstall the display adapters and reinstall them. similarly uninstall and reinstall the monitor drivers. 3. go to http://www.drivershq.com/Drivers/Toshiba/Satellite/A45-S130/4183/9941/10606/Drivers.aspx you will find here a driver detective that can detect your driver problems. try with that. 4. on the site above you will find drivers, for you to download and install on your laptop. if you still have problems, then you have
Sep 02, 2009 | Toshiba Satellite A45-S130 Notebook
Toshiba Laptop Dark screen-cant really see it!! help!!
sounds like your inverter is gone. The inverter supplies voltage to the backlights of your lcd.
Mar 25, 2008 | Toshiba Satellite A70 Notebook
Computers & Internet Logo
24 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
