Question about Panasonic Lands Phones
Set up Panasonic KX-T61610 caller id - Panasonic Lands Phones
SOURCE: Caller ID is not working in India.
For people who have purchased cordless phone in usa and caller id is not working they should purchase fsk to dtmf converter at any local phone shop and caller id will start working.
Here is the article on various frequency used by various countries for caller id.
Hope this will help you out.
Detailed Product Description
There are 3 major caller ID specifications in the world: DTMF, ETSI FSK and Bellcore FSK. When users buy a foreign telephone devices(such as cordless phone, fax machine or computer telephony interface), may encounter the problems of non-match for caller ID standard. This will cause the device unable to display the caller ID. EX220 can solve this problem easily. This product can receive all 3 kinds of caller ID format, and convert to FSK(Bellcore or ETSI selectable) to match foreign telephone's standard.
EX220 has a rechargeable battery inside the device, during idle status, it gets power from the telephone line and recharge the battery, so no need to use or replace battery. Just plug one end to telephone line, and the other to the telephone device.
For example, if you live in Netherlands, Saudi or India, the caller ID standard is DTMF. You purchased a cordless caller ID phone from US(which uses Bellcore FSK standard), or from Germany(which uses ETSI FSK standard). You won't be able to use the caller ID feature. In this case, just get one EX220 and connect it between the telephone line and the cordless phone, your cordless caller ID phone will display the caller's number immediately.
Remark:
1. Telephone sets for UK and Japan standard are not applicable.
2. In some countries, users must subscribe to Telecom for caller ID service
Feature List
Caller ID Format Conversion --- Convert 3 kinds of caller ID(DTMF, Bellcore FSK or ETSI FSK) to ETSI FSK or Bellcore FSK(selectable)
Date/Time Stamp --- The DTMF caller ID doesn't content date/time stamp. User can set up clock of EX201, so each call will be sent with actual date and time stamp
Area Code Setting --- User can set up the area code, so the dial back feature can easily applied
Rechargeable battery powered by line --- Just connect to the telephone line, the built-in rechargeable battery can get power from the telephone line, no need any external battery nor power supply
News
Now, Multi-Line caller ID converter is available.
Posted on Jan 08, 2008
CORDLESSGURU
  • 106 Answers
SOURCE: KX-TG6071M 5.8 GHz talking caller id not working
Hi trinigirl, You should not have to do anything to make the caller id information come through. There is no programming to perform for the regular caller id identification on your display after the second ring (it takes at least one ring cycle for the digital information to pass through). Your model also has the talking caller id function, which will announce in English the callers name or a custom name you can prepare in the phone book of handset number 1. With all that said, you are not getting caller id showing after the second ring, then your phone is bad (which is pretty rare for this symptom), or your phone line still does not have caller id activated. To troubleshoot your problem you need another phone line with working caller id and/or a different phone that is known good to pass caller id. That way you can interchange the phones/lines to see if it is your line or your phone. My guess it is your line somehow, though I have fixed phones that won't pass caller id, but rarely. If it is your phone, try rebooting it, thats about all you can do short of sending it in for repair. Let me know how it goes. CG
Posted on Feb 19, 2008
SOURCE: Panasonic KX-TG6051M 5.8 GHz -Caller ID view problem
I have a panasonic KX-TG6051CM 5.8 phone with 3 handsets. After less than a year 2 of the 3 handsets developed the same problem, almost in the same time ( a couples of hours apart). The battery indicator shows low battery and is charging continuously even though the battery is fully charged ( when i swap the battery with my 3rd handset, the battery indicator shows fully charged and works fine ). The handsets were never dropped, never used in a moisture ladden environment ( like bathroom ) and when not in use they were kept in the charger. Any help or suggestions will be much appreciated.
Posted on Mar 24, 2008
  • 30 Answers
SOURCE: How do you turn on caller ID on a Panasonic KX TGA181AL
Is your phone operated off a panasonic system? is so you need a caller id card. if not then you would need to inform your phone service provider that you need caller id. if you have caller id and you do have the caller id card you would need to get a hold of a panasonic tech who could turn on your c.id as long as it is being provided from your phone service and the card is installed.
Posted on Feb 21, 2009
SOURCE: panasonic kx-tg6051b instruction manual
http://service.us.panasonic.com/OPERMANPDF/KXTG6021.PDF
Posted on Jun 02, 2009
How do you Set up number of rings on panasonic Kx tg6621?
Go to your phone menu setup caller id service and check the caller list and assign your ringtone for a particular ID in panasonic kx tg6621
Nec sv8100 IPK DTerm phones Nec phones Inlinecom
Jul 10, 2014 | Panasonic KX-T7730 Corded Phone
ABOUT KX-TG6541
maybe if you ring the company name of the phone such as panasonic it maybe broken or read the instructions
Jun 05, 2014 | Panasonic KX-TG6541B Dect 6.0 Plus Digital...
I just received KX-T7730 phone with an LCD screen and it is not showing the caller ID # that is dialing in. It only displays CO 1. The previous phone similar to KX-T7730 shows the caller id #. So how can I...
The one who can show the caller ID when someone call is the caller only. He/she can set to hide his/her number ID in their phone so we can't see it. We can't force to see this caller ID, but if this calls disturbed you, you can install call blocker and only allow certain incoming call to be recieved.
Hope his help and rate please.
Jan 17, 2011 | Panasonic KX-T7730 Corded Phone
Caller ID not functional in Model KX-TG-9331T and 9332T
Do you have the converter that converts your caller id to U.S. caller id?
Mar 15, 2010 | Panasonic KX-T7633 Corded Phone
My panasonic kx-t7636 phone has caller id. however
you need to go to the call settings on phone and adjust the call waiting there ok
Jul 17, 2009 | Panasonic KX-T7636W Corded Phone
Feb 20, 2009 | Panasonic Lands Phones
I have a Panasonic KX-T61610 phone switching system. Some of my phone extentions are not working and some are. I have unpluged the unit and also pushed the reset and that didn't help. The extentions that...
Also, are there certain CO lines that can only work with this KX-T61610 system? Typical FXS? or any odd analog settings on CO lines or within the Key controller for the KX-T61610?
May 27, 2008 | Panasonic Lands Phones
Panasonic KX-T2375MXW
Program , mute , 6 : now you can type the time
press program to store.
Mar 07, 2008 | Panasonic KX-T7730 Corded Phone
KX-TG 1100SP CALLER INFORMATIONNOT DISPALYED
check page 18 from your user guide (or at "http://phone.manualsonline.com/mdownloads/2a9697eb-f1f9-a434-457a-98ab6de1d9cc.pdf" if you don't have the book), your security code may not be set. good luck!
Feb 26, 2008 | Panasonic KX-TG1100 Cordless Phone
Lands Phones Logo
105 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
