Question about Miele Ovens
In Miele H4890 oven, fan runs for two hours
Fan to cool electronics often runs two hours after oven is turned off
  • 1462 Answers
SOURCE: Oven
oven has two fans. the second fan is out of sight and cools the casing. it is operated by a seperate stat. not unusual for it to run for up tohalf hour after switching off. if it runs for an excessive time may be a fault nwith fan stat
Posted on Mar 20, 2007
SOURCE: Turning off oven.
The fan only comes on in the back of the oven when convecting and Automaticaly turns off when you open the door. The exhaust fan coming from the front stays on for qutie a while, maybe 2 hours or so till the oven cools. I think it is just a function of the oven. A good thing in the winter but uses a bunch of airconditioning in the summer
Posted on Feb 27, 2008
Master_Tech
  • 770 Answers
SOURCE: Fan runs for hours after use
The fan is in place to cool the electronics it will run after the unit is off it is possible you have a bad sensor on the fan circuit leaving it to run too long
Posted on Apr 05, 2008
barkencoa
  • 3463 Answers
SOURCE: zanuisi top oven making noise
Yes , there is a cooling fan located at the top of the oven
It could be the fan blades catching, or a noisy fan bearing.
You would have to access it by removing the top oven cover to check., and yes it could be as a result of having it cleaned.
Plz rate my solution.
Thanks.
Posted on Jan 02, 2009
  • 44 Answers
SOURCE: very noisy fan
Hi
you need to replace the fan as this will be the cooling fan which cools the oven down. and can not be disconneted .
regards
Posted on Mar 21, 2009
Trying to cook prime rib that needs to rest in hot oven for 2 hours. How do I turn off cooling fan
that fan is a cooling fan but not for the food,it's to cool down the electronics in the oven like the clock assy. so it's doing it's job,that's why i tell people not to use the self clean feature on stoves or ovens,the temp. gets up to 1000 degrees and it will sooner or later damage the electronics in the machine,so if you're gonna use it use it after the holidays,i see people use it the day before thanksgiving,the oven stops working and parts have to be ordered or if it's an older oven you can't get parts anymore and they can't cook so that fan is a good thing.happy holidays.you have to set the oven on a low setting just to keep the oven warm.like 200 or 225,also some ovens have a warming draw under the oven door,if you have this make sure you clean it first,i've seen them filled with dust because nobody ever uses it.here i googled this for you
https://www.chowhound.com/post/meat-warm-360832
Dec 23, 2017 | Ovens
Neff electric oven stays hot after turning off
This is normal...there is a cooling fan built in to your oven designed to cool the facial controls when hot and can take some time to cool to an acceptable temper?ture that's why you can feel the air blowing,, usually above the oven door...if you switch off at the mains you are risking the plastic components on the facial melting. Just leave it to Run it is a very low wattage motor and costs very little to run
Oct 10, 2017 | Ovens
After baking at 425 degrees, ew30mc65js2 will not shut off - fan continues to run and some heat, although lower, continues after 1.5 hours
Hi - if you still have your user manual I think you will find that oven have a time delay designed into the electronics for cool down purposes after the cycles completed. If it does shutdown after say 1.5hrs, it may seem a bit long but its actually doing what its designed to do, it should not be heating but circulating the hot air thru the oven.
We use to have a similar problem with our F & P BI600 wall oven - what we've done is have the door slightly ajar to quicken the cool down process until one day the fan ran continously - then I had it disconnected.
I hope this may help with your situation, if its running continously then its best to disconnect the cool down fan, the bake fan is normally on a separate circuit and not affected.
Jul 13, 2011 | Electrolux Ovens
I used the oven in the house we just purchased (a GE wall oven JTP18 and after I turned it off a fan kept running. Is that normal?
Yes, the program and thermostat calls for the fan to cool the electronics, without that you can loose the electronic boards. Normally the fans will shut off once temps drop to 200 degrees Fahrenheit. Enjoy your new home.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 08, 2011 | GE Profile JTP18 Electric Single Oven
I have a new belling b170f and have just turned it on however the fan at the back wont turn off. how long would I expect the fan to run. The oven has not even been hot yet
If its less than a year old then call belling as it sounds like the thermostat for the cooling fan is faulty. Its designed to cut the cooling fan in at around 65 degrees celsius to protect electronics.
Mar 02, 2011 | Ovens
COOLING FAN DOES NOT STOP AFTER HOURS
Hi I am Vortash the cooling fan must be controlled by a thermostat , it appears that it has a problem on it and is not shutting off .
They are usually normally open contact switches that are on the top or the side of the oven ,they heat up close the connection and turn the fan on . yours sounds as if it is sticking . Other ovens are controlled by a rheostat a long tubed thermostat that goes to a main control consul on the oven , it controls the fan and responds to what the stat tells it .
It may be this controller is not turning the fan off afterwards , my suggestion is that unless you are electrically trained you get the help of a service engineer to check your oven out .... regards Vortash
Jun 15, 2009 | GE Profile JT912 Electric Single Oven
Apr 05, 2008 | GE JTP15 Electric Single Oven
Control panel fan won't turn off
Is the oven still hot?? this is a Electronics cooling fan it will run even after the oven is turned off give it some time it should shut off let me know if not
Jan 26, 2008 | Dacor Epicure 30" Double Wall Oven,...
Oven fan keeps running even after off and door open
3 to 4 hours is a long time. Get to the fans (behind the control panel) and check the screens for dust. Chances are the screens are clogged with dust and need to be cleaned so the fans can move air for cooling better. I had this problem on my GE JTP14, and after cleaning just one fan it can keep up with cooling the electronic area while the oven is running. It runs much less often.
Safety first! cut the breaker before removing anything with a nice conductive screwdriver! Hope this helps!
Jan 01, 2008 | GE Profile JTP18 Electric Single Oven
Oven
Mar 20, 2007 | Bosch HBL 5056 Electric Double Oven
Ovens Logo
1,314 people viewed this question
Top Miele Ovens Experts
Paul Bade
John
Are you a Miele Oven Expert? Answer questions, earn points and help others
