My Belkin F7D6301 has a constant red light, resetting the router did NOT work, now what
Techroy
  • 52 Answers
SOURCE: Belkin G router. All lights are on solidly. No
If the gateway address of the router is responding the try uploading the firmware using the tftp utility that might fix your issue, try a 2 do a Hard reset for 2 minutes with the power cable connected to the router, then release the Power supply and reboot it, then check the light status.
Posted on Mar 17, 2010
  • 37 Answers
SOURCE: belkin wireless
the red light means u havent got a connection if u have installed properly try upgrading the firmware the problem might be the routers
http://www.belkin.com/support/product/?lid=en&pid=F5D9230-4&scid=221
Posted on Dec 09, 2007
bee2busy
  • 51 Answers
SOURCE: Setup asistant will not work with Belkin wireless router & computer
Try the manual method.connect router to pc with ethernet cable
1.logon to 192.168.0.1
2.Connection type ; PPPOE
3.type in your username@ISp and pass
4.Save settings
5.Configure wireless setting(SSID,Wep)
Configure pc with the same SSID and WEP
uplug the ethernet cable and check if your are able t connect wireless
if you still have issue use this guide
Cheers !!!
Posted on Feb 23, 2008
  • 415 Answers
SOURCE: was working ok then internet down and red light on
Try rebooting both the modem and the router. It could be that the modem didn't pick up it's ip number when the internet went down. Then try pluggint you computer directly into the modem first to make sure it is setup and working properly. Then plug in the router (to the modem) and the PC plugged in directly to the router and check.
Once you have it connecting at that point then check the wireless settings on both the router and the pc. Then enable the wireless on the pc, unplug the LAN and switch to wireless network on the pc and see if it won't work.
If it works plugged in on the LAN but then not on the wireless then either your configuration isn't correct (ie wrong gateway ip number...gateway should be the same ip number as the router...ie 192.168.***.***) or perhaps the wireless part of the router died. It is possible for the wireless to die and the LAN (hard wired connection) to still work.
Posted on Aug 08, 2011
  • 88 Answers
SOURCE: I have a Belkin Wireless
Good day,test your connection directly to your pc,and monitor,and if still looses connection ,call your provider.thanks
Posted on Aug 17, 2011
Belkin f6d46304 v2
hold reset button unplug and plug back in after few secons make sure your ethernet is pluged in from sevice provider
Jan 16, 2014 | Belkin Computers & Internet
Belkin n600 db wireless n+ router stopped working
Your Belkin Router Has Stopped Working And You No Longer Have Wireless Internet Please Follow these Steps To resolve this issue
  • Restart Your Router And Modem.
  • Make Sure Internet Service Is Running Fine Via Internet Service Provider.
To know more info visit at Belkin Support And Belkin Router Troubleshooting Guides TechVaidya After All, This If Your Belkin Router Did Not Work Just Reset Your Belkin Router Using The Reset Key and Setup Your Router Again[Don't Worry its Easy and Simple And I Will Guide You How to Setup The Belkin Router.
Oct 14, 2012 | Belkin N600 DB Wireless Dual Band N Router
So I got this Belkin router (N) and the wireless light just comes on and goes off as it feels what up?
Idea of Belkin router is blinking orange is simple but there can be many more reason behind that light code .
It just can be ISP issue (may be internet service provider is down )
you might want to restart the modem than router and wait for like 1 min this Belkin router blinking orange to green.
For more details kindly visit
Belkin router blinking orange FIX belkin router amber light Issue
Good luck.........
Feb 27, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Computor doesnt connect to internet states a local network cable is unplugged 4 green lights on routerand one red light turn off all power and unplugged cable also reset button but no internet connection...
If the red light is your DSL light it means you have a line fault or no internet connection. Contact your provider
If the red light is your broadband / internet light - it means you are not logged on properly. Chck your username and password are correct - especially after the reset!
Oct 06, 2009 | Belkin (F5D5231-4) Router
Belkin Router problem
A red light on your belkin router means its already busted as you decribe other lights are not ON at all. In all other types of modems and routers Red LED light on it mean synching up and if more than 20 secs with a red light is already considered busted.
Note: You may also check your phone cable rj11 , power surges, defective phone jack.
Jun 15, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin wireless
fix your problem related with Belkin wireless router by follow easy steps.
  1. First, you need to unplug the Belkin wireless router from the modem and now connect the computer to your modem with a cable Just to see you are getting the internet.
  2. Now connect the modem to the router using an internet cable to the internet port(Ethernet port).
  3. try connecting wireless router with a computer using an another internet cable.
  4. type 192.168.2.1 at the URL (on the top of the search bar ) and the now router setup page is open.
Now there are easy steps where you can setup the router and you can change the password.
Belkin wireless router is not working Get belkin router setup
Dec 09, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
