Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machine Problem
Sometimes the unplugging helps, or hitting "Cancel" several times.  Guaranteed to work though is to remove top, reach down the top to the door lock.  (Tight squeeze and need to be a little tall to reach) Once your hand is down there, on bottom of lock mechanism is a small handle that must be pulled straight down and manually unlock the door.  This can also be accomplished by removing lower front panel and reaching up to do the same.   BTW, while in the top, make sure all the electrical connections are tight.  I found some loose before, probably from the spinning action.
  • 15,935 Answers
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
My washing machine bosch maxx5 is locked and giving a key sign
Try hitting cancel, unplug machine for 5 mins then plug back in and hit cancel.
If this doesn't work, post the make and model for better help.
Apr 13, 2013 | Washing Machines
Washing machine wont start
Try unplugging the machine for 15 seconds. After it is plugged back it open and close the door several times. I know this sounds weird but it resets the safety circuit that sometimes shut these machines down. There may be some other safety reset sequences specific to the machine (you can search these on the net) if the one I told you doesn't work. Please rate my answer so I get points for it.
Jan 20, 2012 | Whirlpool Washing Machines
My son put a load of laundry in and forgot the hot water heater was broke when he turned the machine on. It wouldn't run and the door is still locked. We tried unplugging it, holding the cancel butt
Remove the lower panel by taking out the screws at the bottom. Unplug washer. Then reach up inside to the bottom of the door switch and pull down on lever to unlatch the door. Try running machine again after plugging back in.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The maytag neptune MAH8700AWW Front Lodaer door will not unlock. Help. I need to know how to get the door unlocked. I have unplugged it for 30 minutes. I don't know what else to do
Hello there and thank you for choosing fixya
there may be several ways to do this first if you press the cancel or off button and wait for several minutes without touching it it may unlock. if not check to see if there is a kick panel at the bottom of the machine if so remove it then pull the machine out about 10 inches and tilt the machine back now reach up under the machine and feel for the door lock there will be a small cable with a tear drop piece hanging there pull down ******* this and this will open the door for you.
Also these machines have a internal memory on them and sometimes it takes up to 1 hour to reset so you may need to unplug it again and leave set for a minimum of the 1 hour ok
Please keep me posted on how this is going i have more information i can give you but i need to see how all of these things go first ok?
Best regards Mike
Aug 04, 2011 | Maytag MAH9700A Neptune Energy Star Front...
When i started the machine, it went to start, then clicked and gave me a f dl error message. the door is now locked and will not even allow me to get clothes out. i have unplugged the machine several...
Unplug the unit, remove the lower access panel (front of the machine) reach up and find the small lock release tab and pull downward to release the lock manually. remove your clothing. This is usually do to a door switch failure. Replace the door switch. It may also be a wire coming loose or making intermittent contact. Hope this helps
Oct 22, 2010 | Whirlpool Washing Machines
Control locked how to unlock
Sometimes fiddling with the machine controls you can get it to release. By fiddling I'm talking about selecting a cycle and then trying to cancel by hitting the cancel/stop/pause button. If this does not work and unplugging the machine does not work, you are going to have to manually do this.
First, unplug the machine. Next, at the bottom of the machine is a toe panel. Under the panel are typically 2-4 screws. Remove these screws (either 1/4 or 9/32 nut driver) and place the toe panel aside. Now, you can reach up underneath the door lock assembly which should be on the right side of the washer door (opposite side of the door hinges). You will have to feel around, but u can pull down on a plastic "catch" or lever. This will unlock the door!
May 28, 2010 | Whirlpool GHW9400 Front Load Washer
My washing machine stops all the time and beeps with the F 11 flashing. I have tried unplugging the machine so it can reset itself but that doesn't work. I am ready to throw it away! It seems to have...
Dec 22, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
What causes the HE3t washer to stop in spin and rinse cycle?
Dec 06, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washer stops with an F1 Code during rinse cycles.
Well I have the same problem the only way I have found that my washer works is that on the soiler level make sure you put that on the heavy. And that should work I know its a pain but thats what I do and my washer washs with out stopping
Dec 04, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool washine machine #AWM 3082 - door wont open
Try to unplug the unit for five minutes, then plug back in. Try to start a load, as soon as the door locks agian, hit cancel. That will sometimes let you get back in. Im not sure if this is a top loader or front loader, but there is a way (if its a front loader) to remove the bottom front kick plate, then you have to reach up the inside to the door latch assm, on the bottom of that is a small round handle, pull it straight down, and the door will unlock. If its a top loader (i.e. Cabrio, Oasis, Etc), you can open the top only by unclipping the top from the base. You can do this by putting a putty knife in between the top and cabinet, then finding the clips, pushing them in and lfting, you can get your stuff out that way.
Nov 16, 2008 | Whirlpool LHW0050PQ Front Load Washer
Washing Machines Logo
Sal De GO PATS
fordexpert
Ed Mac
