How do you reset fault code f08 for a hotpoint wt940 washer
5 Suggested Answers
  • 5 Answers
SOURCE: Error code f08 on Wt940 ultima.
not sure if this will help but try:
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a "table tennis like" ball. Lift it out carefully and you will probably find an obstruction like a coin or similar. I found a hairgrip but it was enough to stop the ball functioning. DO NOT TAKE OFF THE WHITE HOSE CLIPS
Comment by pulmicort, posted on Feb 02, 2008 Further to my comments re clearing scrap from table tennis ball after code F4. Machine started ok but then F5 came up. Had to take the pump off and apart to reveal broken hairclip actually seized in pump. If you are handy at all this is simplicity itself.
Slide pump to left and lift and it comes clear. Take off 2 black hoses only where connected to main machine. Pull off electrical connection. Pump and hoses lift out easily. 3 screws open the pump. Clean any obstruction and reassemble. A 30 minute operation.
Posted on Apr 16, 2008
barkencoa
  • 3463 Answers
SOURCE: hotpoint fault f-07
F07 means that the heater relay is stuck, you need to test the heater and replace if req'd.
If heater o/k then you still have a problem with the heater circuit somewhere.
Maybe a control assy
Plz rate this solution.
Thanks, and a merry xmas.
Posted on Dec 20, 2008
57 varieties
  • 1653 Answers
SOURCE: hotpoint WT940 has fault code F-03 on the display
Switch the machine off at the mains power for 30 minutes and switch on again. If the error persists then you will need to look at the Wash thermistor (NTC) as this is faulty and may need replacing although there is a small chance that it is a wiring fault between to the thermistor. This is a reasonably common problem and is easy and relatively cheap to repair.
Posted on Oct 25, 2009
barkencoa
  • 3463 Answers
SOURCE: Hotpoint wt741 fault code f08
You need to check all the connections to the pressure switch the heater and the module as generally speaking it is due to a bad connection, you shoul not need to disconnect anything.
Hope this helps.
Posted on Jan 16, 2010
I have a hotpoint ultima wf860 it was all fine then all of a sudden its saying the error code f-18 how can I fix this please as I havent enough money for a newone yet. many thanks x
Hi, The link below is a user manual for a hotpoint ultima wf860 and below that are the error codes, I wish you all the best......CHEERS...
file:///C:/Users/Steve/Desktop/4992cbf9-f956-4127-bdab-caa958e02377.pdf <---"NEED TO COPY AND PASTE"
Hotpoint Washer Error CodesF01 - Electronic circuit board fault
F02 - Motor circuit fault
F03 - Temperature sensing fault
F05 - Waste pipe blockage or pump issue
F06 - Door lock fault
F07 - Electronic circuit board fault / heating circuit fault
F08 - Heater fault
F09 - Software fault
F11 - Pump circuit fault
F12 - Electronic control fault
F13 - Dryer temperature sensing fault (washer dryers only)
F15 - Heater control fault (washing machines and washer dryers)
F16 - Drum lock position sensor fault (top loading machines only)
F18 - Internal data error
F19 - Fan motor or heating fault (washer dryers only)
Apr 01, 2016 | Hotpoint Washing Machines
What does "f08" mean on
The error F08 indicates that the heater relay is stuck. This could be a fault with either the pressure switch, heater or the module connections.
Think you need to book a service call from engineer.
Feb 06, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima WT965A fault code F08 what do i need to do to fix it please. wachine is full of water and i cant select any cycle to empty it.
To empty the washer, remove the drain hose from the outlet, and lay it down to floor level, this will let the water run out into a bucket or similar.
Code F08 is indicating means heater relay cann ot be activated.
Check all connectios to and from the pressure switch, the module, and the heater.
Hope this helps.
Jan 06, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius Fault Code F-08. What does this mean?
F08 means Heater relay stuck: check pressure switch, heater & module connections..
Dec 10, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hot point f-08 fault code
F08 means that the heater relay cannot be activated.
Suggest you check heater, and or thermistor (thermostat) for a fault, replace as req'd.
Please rate my solujtion.
Thanks.
May 20, 2009 | Hotpoint Ultima WF860 Front Load Washer
Apr 02, 2008 | Hotpoint Ultima WF860 Front Load Washer
Error/fault code f08
in the bottom access panel taped to the side is a service manual with codes
Mar 30, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
3,882 people viewed this question
Top Washing Machines Experts
