Question about HP Photosmart C8180 All-in-One InkJet Printer
CD label (Neato) printing problem
I have a HP c8180 all in one. Whenever I try and print a Neato A4 cd label -2up it rejects it says 'paper detected does not match paper size or type selected. Press the cancel button on the printer to cancel the job'.Paper type automatic; paper source 'main tray';print quality 'automatic'.If a standard A4 (or even the Neato label is put in wrong side up) the print comes out fine but not when on the print label side.
  • airgirl Jan 09, 2009
    Everytime I try to print the paper jams or comes out with top 1 inch of paper folded over
  • 181 Answers
Try to change your paper type to plain paper - it could be because it is a bit glossy that it thinks it's photo paper that is not inserted correctly.
Posted on Jan 16, 2009
Printer will not print onto Avery Clear Label paper
click START.,go to PRINTERS N FAXES n click it.,the window with list of printers on ur pc will open.selest ur printer icon n rightclick it.then click the PROPERTIES option.then click PRINTING PREFERENCES,u will find a PAPER SETUP or PAPER option.click it n select the type of paper as per ur requirement.apply the settings n carry on printing hassle free.thanks.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Jun 27, 2008 | HP Photosmart 2610 All-In-One InkJet...
L.S. How can I print label direct on cd/dvd. I have the HP Photosmart C5280. Thank uou in advance. H. Polak
You can't print directly to a CD or DVD. You need to print on a CD or DVD labels and you can find it on a computer store like Comp USA or Best Buy for example.
This an example can see it on http://www.neato.com/ under DVD Labels Good luck.
Nov 09, 2010 | HP Office Equipment & Supplies
I am trying to make labels for cd's but they are not printing correctly. The sheets show the cd to the side of the page but it's only printing straight down the middle so it's not letting me print...
I had the same problem. The solution I came up with was to use Microsoft Publisher to print the labels. First I drew a circle about the size of the cd and another inside it for the centre. I printed it out on a plain sheet of A4 paper and measured held it over the label to see how they matched up. I dragged the circles in publisher using trial and error until the circles came out in the same place as the circles of the labels. Then I designed the label inside the circle using publisher and when I printed it on the label it came out in the circle.
If you don't have publisher just check the paper shown in your print dialog and make sure you have changed it to the label type you're using rather than A4 Plain which is the standard.
Jul 27, 2010 | Avery DesignPro Deluxe CD-ROM...
Printing Direct to CD using Roxio EMC10 and HP All in One C5280
Solved by trial and error.
I went through every type of paper and printer combination listed in the Printer Preferences and eventually found a system compatible with Roxio EMC 10.
This by setting "Commercial Paper" and Neato 3-Disc Paper.
Whilst this is probably the incorrect way to do it, it has solved the problem and I can now print directly onto CD via my HP C5280 All in One Printer.
Tip. If you set Print preview before printing you can determine what the finished article will look like without having to wast numerous Discs trying.
Aug 28, 2009 | Roxio Easy CD & DVD Creator 6...
I have a photosmart d5363. battle to print on a printable cd.how do i calibrate from working from media face. 762438@yebo.co.za
Part of the Neato software is a calibration function (It is on the installation disk)
You run it and it prints out a chart which tells you how far out your printer is
You then change some values on the setup to suit the mechanics of your printer and it should be in line
I use Neato and find that even with a machine that is supposed to be lined up I get overprint
It is easier to make your layout then make a print on paper using a dark colour , lay this on top of a CD and see which way the machine drifts.
You can then drag the image around on the Neato scream to make sure that it is in the right place before you print a CD
Jun 04, 2009 | HP Office Equipment & Supplies
How do I print a label on a cd/dvd
your printer does not support CD label orinting. though you can still print CD labels but with some softwares. there are HP printers that prints CD labels. Check them out.
HP Lightscribe
Use LightScribe technology to label CDs and DVDs.
HP Photosmart D5460, D5463, D5468, and D7560 Printers - Printing Directly onto a Printable CD or DVD in HP Solution Center ...
On a computer running Windows, print directly onto a CD or DVD using the HP Solution Center software.
HP Photosmart Premium C309a, C309c, C309g, and C309n All-in-One Printers - Printing Directly onto a CD or DVD - c01622666
Review steps for printing directly to a CD or DVD.
HP Deskjet 900C series printers - CD Label.
These printers comes with a special software that enables them print on CD labels. Also try to get their softwares and see if you can interface them with your own printer and them print. Else you may have to get one of these printers that support CD labelling. Cheers!
May 19, 2009 | HP OfficeJet 4255 All-In-One InkJet...
How to print CD Lable in HP Office Pro K850 on Sticker paper
The Reason in drum you should change the photodrum.Good luck!
Apr 10, 2009 | HP Office Equipment & Supplies
HP Photosmart C8180 All-in-One InkJet Printer Logo
326 people viewed this question
Ben Johnson
