Question about Nintendo DS Console
Touch screen not working
My touch screen will not work. It does not work with the stylus or fingers. Can it be fixed?
  • strasilla Nov 21, 2007
    We just got a ds from ebay and the touch screen is not working! When we started it up we were able to calibrate the screen, but when he started the game, the touch screen would not work.
  • Anonymous Apr 05, 2009
    i touch the screen w/ my stylus and it wont work
There is a problem with dust and dirt getting between the casing and touch screen. get an old toothbrush an give it a brush all the way around that should cure it
Posted on Jun 25, 2007
Change the touch screen,about £10 from e-bay.
when used hard ,screen gets distorted and won't calibrate properly,and in extreme cases,stops working altogether.
Posted on Jan 17, 2008
Removing the plastic protector worked for me.
Posted on Dec 11, 2007
  • snash1 Jan 30, 2011
    thank you
2 Suggested Answers
  • 3 Answers
SOURCE: DS Nintendo Screen not repsonding
there are two ribbons on the inside of the console ( right side ) . they are fiddley little things, maybe one of those has slipped out of the clip?
Posted on Feb 21, 2008
Hello, My touch screen not function, but all switch work normal.When need touch screen to change something hi not work. the display work good .
Have you tried touching the screen with a pen, or stylus. Or even your finger nail? My KORG does not work well with fingertips, needs something harder.
Apr 01, 2014 | Korg Pa800 Synthesizer
Tip
How to Sync Stylus with LeapFrog Leapster 2 Learning System
If you need to sync the device to the stylus just follow the steps below.<br /><br />1. Turn your <span>Leapster</span> 2 off, and remove the game cartridge<br /><br />2. Hold down the 'hint' button while the game is off. The 'hint' button is the middle small button in the row of three above the directional pad on the left, with a '?' on it.<br /><br />3. With your finger still firmly on the 'hint' button, turn the <span>Leapster</span> 2 back on. Keep your finger on the 'hint' button.<br /><br />4. The screen should be displaying the calibration screen. You can release the 'hint' button now.<br />5. Press the 'A' button on the right to enter the calibration screen.<br /><br />6. A small '+' sign will appear on the screen. Touch it with the stylus. A new '+' sign will appear. Touch this with the stylus too, and repeat for as many '+' signs as your <span>Leapster</span> 2 throws at you.<br /><br />7. The screen will return to the calibration screen. You can now turn the machine off. Leave the cartridge out of the console, and turn it back on.<br /><br />8. Your stylus and touch screen should now be working, enabling you to sign in as usual.<br /><br />9. If it is working correctly then you can turn it off, add a game cartridge and turn it back on.<br /><br /><b>Thanks for <span>using</span> <span>Fixya</span></b>
on Mar 09, 2011 | Toys
The touch screen doesn't work with my finger tip, only when my nail touchs screen, also did the screen calibration, did not not help
It may be a resistive screen rather than a capacitive screen which is not as sesitive to touch. You may need to use a stylus as it may need slight pressure vs just touch if it is a resistive screen.
Apr 05, 2013 | Garmin zumo 550 GPS Receiver
The pen has stopped working when touching the screen
If your Leapster 2 will turn on, but the touch screen is not responding to the stylus, try re-calibrating the stylus with the screen using the steps below: 1. Turn your Leapster 2 off, and remove the game cartridge.
3. With your finger still firmly on the 'hint' button, turn the Leapster 2 back on. Keep your finger on the 'hint' button.
6. A small '+' sign will appear on the screen. Touch it with the stylus. A new '+' sign will appear. Touch this with the stylus too, and repeat for as many '+' signs as your Leapster 2 throws at you.
Thank you for using fixya! I hope I had helped you with your problem. May you have a good day!
Mar 28, 2011 | Leapster 2 Handheld Game
The touch screen does not respond to the stylus what can i do?
Welcome to Fixya. If you need to sync the device to the stylus just follow the steps below.
Thanks for using Fixya,
Mar 02, 2011 | LeapFrog Leapster 2 Learning System
How do I change the sensitivity to the screen so that I can use my longnails & not my finger?
you will not be able to use your fingernail on the hero screen. the touch screen is similar to the iphone (capacitive) and different to most other touch screens that use a stylus (resistive).
your finger is required for the screen to pick up where you touch.
there is a special stylus you can buy that will work, but make sure it is specifically for the iphone. a standard plastic tipped stylus will not work.
Nov 19, 2009 | HTC Hero Smartphone
My stylus wont work
when this happened to my daughters nds lite she had to have the touch screen replaced
Jul 28, 2009 | Nintendo DS Lite Console
Samsung YP-P2 MP3 Touch screen
it is pressure sensitive so, unfortunately, a stylus type pen won't work
it'll only register your fingers
Dec 29, 2008 | Samsung YP-P2 Digital Media Player
Problem with the touch screen an stylus
Press the Up + Down buttons at the same time. This will turn off the "Digitizer" function on the tablet and allow the user to use their finger, the stylus, or blunt end of a pen.
Aug 21, 2008 | Itronix Duo-Touch Tablet PC
PPC 6700 Touch Screen Sensitivity Changed
Realigning your screen might fix your problem. Settings -> System-> Screen > align screen.
I hope this helps
C
Dec 14, 2007 | Audiovox PPC 6700
Nintendo DS Console Logo
815 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
