Question about Westinghouse Dishwashers
I have a 3h code showing on my SB915 Westinghouse dishwasher
  • 5 Answers
SOURCE: Westinghouse sb915 will not heat
Westinghouse SB907 had same problem, which I had thought might be the heating element. Fixed relay soldering on PCB where it was burnt/melted, now works! This probably applies to the Westinghouse SB925 also.
Posted on Aug 25, 2008
  • 52 Answers
SOURCE: Westinghouse sb915 - draining too early.
1. Is your drain point higher than the bottom of the dishwasher? (ie, does it drain into the garbage disposer or does the drain line drop down below the floor into house plumbing?) Did you just install the unit? You may have to install an "air gap" to prevent syphoning.
2. Did the dishwasher work then suddenly stop working? (asking for clarification)
Posted on Dec 13, 2009
taran_2005
  • 10515 Answers
SOURCE: Our Westinghouse Touchdry SB915 stops
If the dishwasher is beeping 10 times and none of the functions work, it is highly suggestive of faulty control board. You could disconnect the power supply for few minutes,say 15 minutes and then turn it on. If the problem persists, more likely you need to replace control board.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 28, 2010
SOURCE: Westinghouse SB915 wont heat up water
found the 2 large lugs mounted on the circuit board had been hot and had dry solder joint's removed solder cleaned with sand paper then re soldered and tested it now heats up .
Posted on Feb 04, 2011
  • 10 Answers
SOURCE: Hi, we haven't got a
press hold in for few seconds if not get unlocked you have to get new on and of switch due to this dishwasher switch burns out its popular with this dishwashers power switch burns out
HO 1 code dishwasher will not start
Jenny, I believe the HO 1 (or H: 01) means that the machine is set to delay starting for 1 hour. Continue pressing the "DELAY" button until the readout shows H: 00.
Mar 06, 2016 | Westinghouse SB915
Dishwasher not heating
I am guessing the hot water is not hooked up. Depending on the type of dishwasher and the setup of you kitchen, you can try to hook it up. You will need to pull it out to fix the heating.
Elisa Jed ' http://www.orlandoac.com/
Mar 24, 2014 | Westinghouse SB915
Dishwasher Westinghouse SB915 fills with water for wash cycle but does not wash.
Contact Westinghouse directly to request the wiring diagram.
May 30, 2017 | Dishwashers
My dishes come out clean but wet. They used to always come out dry. Do I need a service or replacement part? I have a Westinghouse touchdry SB915.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Aug 30, 2011 | Westinghouse Dishwashers
Hi, we haven't got a manual for our Westinghouse touch dry SB915 dishwasher and the lock has been activated. How do you unlock it?
Dec 27, 2010 | Dishwashers
Runs through entire cycle fine but water is cold
you need replaced the control board its very popular with this dishwashers cost around $220 as i have replaced mine
Apr 07, 2010 | Fisher DD603FCSS Dishwasher
Dec 13, 2009 | Westinghouse Dishwashers
Jul 26, 2009 | Westinghouse Dishwashers
Dishwashers Logo
Top Westinghouse Dishwashers Experts
Denis FixYa...
Denis FixYa...
Tom Chichester
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
