Question about Whirlpool 24 in. Built-In Dishwasher wih Towerless Wash System Dishwasher
I have a whirlpool quiet wash dishwasher. The door won't close.
The door seems to be hitting on the left side on top and it won't properly click shut so that it can wash. We didn' bump it or anything and can't figure it out.
  • 640 Answers
Drop the left leg,,the legs are adjustable..
Posted on Jan 04, 2009
Maytag fridge right door won't stay closed
it may be necessary to reset the hinge adjustment to move the door further across the opening giving the magnets a better area to hold on to . there is a slight amount of adjustment in the mounting points of the hinges. You may have to replace the door gaskets as they become hard over time and the magnets cannot work properly in the hard plastic
Jun 21, 2013 | Refrigerators
Whirlpool dishwasher door will not click shut to allow washing cycle to start
Check to be sure the gasket that is between the unit and the door is in its proper palce, it may be knocked out of its normal spot and keeping the door form closing all the way where the latch would engage.
Apr 22, 2013 | Dishwashers
I noticed our top freezer door was left open approx 8-9 hours overnight. Now it seems it won't shut off? Is the motor burned out?
It will probally have to go thru a defrost cycle before everything goes back to normal. keep the doors shut and wait 24 hours and check it. hope this helps.
Aug 08, 2011 | Gladiator Freezerator Top Freezer...
My 1992 Jeep Cherokee Laredo is acting like it DOES have an impact sensor. Even the connectors for bridges are causing the engine to stop. Power is still on (lights, heat, gauges). I have to struggle to...
Sounds like a loose connection, positive or ground. When problem is ongoing, jump starter relay, load side, the load side is that line with arrowhead, unplug relay, use jumper wire between those two terminals on left side of diagram. The starter motor should crank. If you try that make sure tranny is in park or neutral and parking brake is set. If it cranks with jumper but won't otherwise, have to check control side of relay, right side in the picture. That top wire is voltage from ignition switch, bottom wire is ground.
Apr 09, 2017 | Jeep Cherokee Cars & Trucks
I can't get washer to start. I believe the top
Washing machines have a safety switch on the lid. If the lid isn't shut, if won't run. You may have upset the safety switch. Depending on the machine, it should either have a micro switch that is tripped by the lid or the lid will have a tab that hits a switch as the lid closes... be sure to listen for a positive click ... you may try bending the hinge a bit to make proper contact too.
May 26, 2010 | Washing Machines
Shut door oven stays on. hit hard on left side it goes off
When door is closed, it activates 2 or 3 door limit switches depending on design .By bumping door hard, one of the limits are disrupted. that switches off the micro.(you are lucky by default because if wrong limit is switched accidently there could be a very loud bang.).
Pull plug out and remove cover. look for limit switches situated near door latch. Try and adjust limits to make a better contact on the door latches. Please note voltages very high on power side even though switched off. Just work at the door area.
Sep 17, 2009 | Kenmore Microwave Ovens
Hit a bump and the fuel system shut down
it should be located in the trunk on rh side behind the strut tower
Dec 06, 2008 | 1994 Ford Escort
Kenmore 665-15962 Elite 8 yrs old
Won't start nor drain. what could the problem be? please help.
Apr 02, 2008 | Kenmore 15872 Dishwasher
Whirlpool 24 in. Built-In Dishwasher wih Towerless Wash System Dishwasher Logo
569 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
