Question about Smeg FAB32 Bottom Freezer Refrigerator
Leaking Fridge I have a SMEG fridge freezer that I have had for about 5 years now. We recently moved home and since having moved our fridge seems to ice up really badly at the back until its about 2 inches thick. Then all of a sudden (usually over night!) it will defrost itself all over the kitchen floor. It has now done this about 3 times in 3 months. Can anyone suggest what might be the problem please and also a solution?! Thank you.
    Sergeant:
  • 236 Answers
You may have a faulty defrost timer, best consult a local dom apps store.
Posted on Jun 02, 2007
SOURCE:
Smeg fridge freezer FA421XS not cooling
There is copper lines by the compressor it sounds like its low on freeon the cooling chemical you can purchase a kit and weld a valve on the in line and load it up with more freeon that may work
Oct 12, 2014 | Smeg FA421X Top Freezer Refrigerator
Why is my smeg fridge not keeping anything cool
Hi...the same thing has happened to me. My Smeg Fab28 refrigerator compartment has stopped cooling. The freezer still works. There was a build up of ice on the back fridge wall, and the milk was freezing up, so I turned down the temp. After the ice melted, I heard a bang like a bunch of ice had dropped. I turned the temp back up but it steadily stopped cooling even more. I decided to defrost the freezer, and had the power off completely for about 5 hours. When I turned it back on, the freezer worked, but the fridge is not cooling AT ALL.
Did you fix the problem and if so, how?
Thank you
Bev
Jun 02, 2014 | Smeg Refrigerators
Door and handle problems. Smeg fa311x
sounds like your door is sprung. take door off and lay flat on a table outside of the door down. loosen screws on door liner . screws are hidden under door seal. when all loose not removed make sure door is flat on table. tighten the screws being careful not to move door. reinstall door and it should be ok. this is usually cause be either someone leaning or hanging on the door when it is open. or putting to heavy of items in the door trays.
May 26, 2012 | Smeg FA311X Top Freezer Refrigerator
I have a tall smeg fridge freezer. Freezer compartment working perfectly. Fridge not cooling despite all lights being on. I've switched it off then on, turned the thermostat down, then up again...
Hi Evelyn,
Has the freezer been defrosted lately? Perhaps a buildup of ice will not let the refrigerator cool sufficiently. Try this and let me know how it works out for you. If it does not have a self defrosting cycle on it, it may take some time, just do not use a sharp object in the freezer as this could puncture the freon lines and that would render the unit useless.
Joe
Sep 21, 2011 | Smeg Refrigerators
My fridge freezer fc36rx smeg seems to not be working correctly, the top fridge is not getting cold but freezer ok, Please help
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Nov 12, 2010 | Smeg Refrigerators
Fridge/Freezer
Probably be cheaper to get new one, it has probably had the compressor fail or a leak in the cooling system.
Sep 16, 2017 | Smeg FR148A Refrigerator
Smeg Fab40 fan stopped working - there is a build up of ice at bottom right freezer.
There is an upgrade kit for the FAB40 to prevent ice build up which falls under the warranty for the FAB40. I've had it installed and it basically replaces the entire back of the inside of the freezer. Following the upgrade, my FAB40 would ice up completely, plugging the ducts to lead cold air to the fridge below. You can spot this syndrome by the water dripping throught the grate at the top of the fridge compartment. This is melted ice from the freezer ducts. SMEG has now sent their top guy, a drunk and pretty rude guy who replaced the whole backside again, and I'm hoping it will improve.
The bottom line is, SMEG is just ****. Very, very expensive ****. I invested about 10.000 dollars in SMEG equipment three years ago, and every single piece of machinery in my kitchen has broken and needed repair during that time. I deeply regret having bought stuff from them and next time I will definitely go with something different.
Mar 31, 2010 | Smeg FAB40PS Top Freezer Refrigerator
Kenmore bottom freezer 73504. All freezer items fully defrosted.
I went to local.google.com to find fridge repair person nearby. They were able to come out the same day and solve the problem. The starter kit for the compressor was replaced. Sears couldn't make it until the following Monday when I called them on a Wednesday. I highly recommend shopping local and keeping the home town economy moving.
Jun 24, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Smeg FAB32 Bottom Freezer Refrigerator Logo
428 people viewed this question
Top Smeg Refrigerators Experts
Mike
Jay Finke
Jay Finke
 Mikey
Mikey
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
