Question about Samsung Ln40a530p1f
Samsung ln40a530p1f no power no red light - Samsung Ln40a530p1f
Won't turn. on red standby light changes to on but then goes right back red
TV won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
More results from www.cnet.com
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
How do you fix a television that won't turn on? - Ask.com
www.ask.com > Technology > Television & Video
Jan 03, 2016 | Televison & Video
My TV won't turn on. I have the Samsung 1080p model number ln40a530p1f the red light keeps blinking but the TV doesn't come on what should I do?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 24, 2015 | Samsung Televison & Video
Samsung 75 smart tv , is power on or off when red light is on ????
Red light means that the unit is in standby mode, It has power but is not turned on.
Jul 24, 2015 | Samsung New 75"" Class 74.54"" Diag. LED...
I have a Samsung Tv model # LN40A530P1F and the picture is different colors
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Feb 25, 2015 | Samsung Ln40a530p1f
Samsung 40 lcd tv fault
Does the line stay or does it come and go? You could have a faulty t-con/LCD panel connection. It could also be the panel itself !!!
Oct 30, 2013 | Televison & Video
When I turn on my samsung LN40A530P1F it starts scanning thru and never stops...remote doesn't work when I try to shut it down
If it will not shut down with the remote (manual power also?) it is a microprocessor issue--if have not tried it unplug it and or a box if connected and wait--plug them back to allow them to reboot.
The remote can be tested to see if it is good but will not cause the scanning issue etc.
May 29, 2012 | Samsung LN46B650 46/49.5 in. LCD HDTV
Samsung LN40A530P1F LCD TV keeps blowing main power fuse when i turn set on it blows right away i have replaced fuse many times. Also when back was off i noticed a arcing as fuse blows at a component just...
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=LN40A530P1F
If a fuse blows like that there is a major problem, inside. I suspect that what your are seeing is the inrush thermistor, and they exhibit this under great load. I would explect that this fault maybe in the actual PSU. Due to the lack of service manual support, i would get a quote for repair from an authorised service center.
Jun 22, 2010 | Samsung LN40A530 40 in. LCD TV
Samsung ln40a530 blinking red light, no video
Blinking lights are usually an error code. Do you have a manual that will decode the number of blinks? Its not always the power supply.
Apr 21, 2010 | Samsung LN40B530 40 in. LCD HDTV
Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Jul 20, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Samsung Ln40a530p1f Logo
75 people viewed this question
Jerry Greenberg
Jerry Greenberg
