Canon irc3380 jam code 0105 - Office Equipment & Supplies
2 Suggested Answers
  • 109 Answers
SOURCE: always paper jam
there is so many reason for that
where the jam when u try to copy 1 copy
Posted on Mar 21, 2010
I have this error codecode e000 and 0105 under when i turn on my Canon CLC 1180. where was the fuser user in the CLC? How can i check it?
I think the 1180 is close to the 1120 copier I know. The error code is indicating an upper heater open circuit. The fuser is the very left item when the main drawer is pulled opened to remove a paper jam. There are two handle grips front and rear to remove the assembly. You have to check continuity of the heat lamp, fuses, etc.
Jun 13, 2011 | Canon CLC 1180 Copier
How can I correct error Code E602-0001 on my Canon copier?
You can try to reflash the hard drive or replace the hard drive
Sep 27, 2010 | Canon imageRUNNER C3200 Copier
Error code
theres an error with either Heater lamp, Thermistor, DC controller
Nov 25, 2009 | Canon CLC 1140 Copier
Error code E000 and 0105 under
its problem power supply please repear it near by a good technician who repear it
Nov 21, 2009 | Canon CLC 1000 Color Copier
My 2270 jambs paper from tray one every time. I changed the pickup rollers still no help. All my other trays feed properly even the stack bypass
Hi mate,
Prior to your issue i may enlighten you with this source.
Technical Infomation 0105/0101/0102/0103/0201/0202/0203/0204 Jam Code: Paper lint adheres to surface of vertical path roller
Description
Since a type of paper that can easily generate lint was used, the paper lint adhered to the surface of the vertical path roller and decreased the paper feed performance of the roller, causing the jam code "0105."
Depending on paper sources, the following jams occur.
- Cassette 1: 0105 (registration sensor PS9 delay)/0201(cassette1 retry sensor PS10 stationary)
- Cassette 2: 0101 (cassette 1 retry sensor PS10 delay)/0202(cassette 2 retry sensor PS11 (cassette pedestal) delay)
- Cassette 3: 0102 (cassette 2 retry sensor PS11 delay)/0203 (cassette 3 retry sensor PS1 (cassette pedestal) delay)
- Cassette 4: 0103 (cassette 3 retry sensor PS1 (cassette pedestal) delay)/0204 (cassette 4 retry sensor PS2 (cassette pedestal) delay jam)
To prevent this, a vertical path roller to which paper is hart do adhere was used for the following machines (the color of the roller was changed from black to gray).
- iR2230 120V THF03592 and later/120V TW SHD00033 and later /220V CN SHC01553 and later/230V EUR THG02606 and later /230V THH00339 and later
- iR2270 120V SLH28893 and later/120V TW KJN00097 and later/ 220V CN KJL00763 and later/230V EUR KGL54733 and later/230V KGM03613 and later/230V CA SLF02281 and later
- iR2830 120V THK01045 and later/220V CN SHE01035 and later
- iR2870 120V SLG13303 and later/120V TW KJR00054 and later/220V CN KJP00589 and later/230V EUR KGD13135 and later/230V KGE00333 and late/230V CA SLD00411 and later
- iR3530 120V THL01319 and later/120V TW SHK00085 and later/220V CN SHH00829 and later/230V EUR THM01596 and later/230V THN00209 and later
- iR3570 120V SKV61037 and later/120V TW KJU00760 and later/220V CN KJS00928 and later/230V EUR KFW21901 and later/230V KFX02555 and later/230V CA SKT01761 and later
- iR4570 120V SKU23728 and later/120V TW KJX00122 and later/220V CN KJV00690 and later/230V EUR KFQ15439 and later/230V KFR02186 and later/230V CA SKQ01030 and later Field Remedy
When the symptom occurs with the machine without the foregoing serial numbers, replace the vertical path roller.
Kindly rate me !!!!!!!!thank mate.
Sep 23, 2009 | Canon imageRUNNER 2270 Copier
How can i get paper to feed automatically without having to press the ok button on an canon irc3380?
actually u are printing from microsoft words or excell.1)pls check the paper size setting
2)check your paper size setting at printer driver page setup.
3)get the device status at printer driver advance setting.
Aug 05, 2009 | Canon Office Equipment & Supplies
Always paper jam
Apr 24, 2009 | Canon ImageRUNNER 3570 Copier/Printer
How to set output of scanned docs to default to PDF format using Canon irc3380
hello, go additional function,next programming communications,next common TR, next send out file,choose file to pdf
Dec 21, 2008 | Canon imageRUNNER 2200
78 people viewed this question
k24674
jasbo
jasbo
