Question about Hardware & Accessories
Instructions for use of mercury 24 hour timer switch
  • 4 Answers
SOURCE: Timex 250 Vac 25 Amp 24 Hour Timer Switch Won't Keep Time
Can the clock be repair or replace, my will not keep time.
Posted on May 23, 2009
SOURCE: clear instructions for power plus
I can't identify 'power plus' timer specifically.
I'm going to guess at answer based on other manuals.
Your timer has a dial on it's face. You rotate dial to set time of day. And the time of day lines up with a triangle marker usually located on center part of dial on right side.
The dial has 48 plastic pieces around outer edge of dial, and each one of these 'slices' or pieces of plastic represent 1/2 hour.
So the dial has 48 'slices' around the dial, and each 'slice' can be lifted up to set timer on-off functions. Sometimes they lift up and out instead of straight up.
Usually when slice is up, timer is ON, and when slice is down, timer is OFF.
Posted on Oct 03, 2010
SOURCE: I need instructions for how
GE 15075 manual:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Plug-In-15075-Manual-eng.pdf
GE 15075 is a plug-in timer.
Before you plug it in, set the timer so you're not bent over at the receptacle.
Rotate dial until current time lines up with triangle located on inner dial.
There are movable pins located around the dial.
These pins cause the timer to turn on and off.
Pins out = timer on
Pins in = timer off
plug in your lamp and the timer turns on and off.
After power outage, set current time again.
Posted on Oct 26, 2010
jyackle5
  • 8197 Answers
SOURCE: lost instructions for Woods INDUSTRIES 59112
You can get the manual on the link below.
http://waterheatertimer.org/pdf/Noma-TD1000.pdf
Posted on Jan 23, 2011
SOURCE: greenbrook GP 24 24 hour
Open following link to identify timer and download manual:
http://www.greenbrook.co.uk/categories.php?cat=4
If timer is not shown, then add a comment with in-focus photo of timer posted on Flicker for possible help
Posted on Jun 25, 2011
How do I set a 24 hour timer D809/1
HPM 24 hour timer instructions: rotate dial clockwise until current time lines up with pointer located on inner dial. There are segments located around edge of dial. Pull up these segments to set on-off times. Turn Load switch ON. Plug Load into timer. Plug timer into receptacle. Manually rotate dial clockwise and observe Load turning ON-OFF. This will show if timer is ON or OFF when segments are pulled up.
I think the D809/1 has 15 minute intervals. The only manual on the HPM site for a 24 hour timer close to this is:
https://hpm.com.au/app/document/asset/23/16/6/d8180d-hpm-24hr-outdoor-timer-instruction-sheet.pdf
Sold at Bunnings in Australia, you might find a manual with one! Alternatively, here is another place they are sold and given they are inexpensive, it might be worth it to just get the instructions. Amazingly, if you try to search for a manual for this, you can not find it. You just get comments like the techs were not help, the manual was in Chinese, and after translation, were not even understood by the techs. Heaven knows what the truth is. The HPM manual above is clearly in English. Note the device manual above likely is set for half hour intervals. Good luck.
http://www.radioparts.com.au/ProductDisplay.aspx?popup=1&Category=SXKK1045&Product=49161200&ProdDesc=D809%2F1+24+HOUR+ANALOGUE+TIMER+HPM
Aug 11, 2017 | Hardware & Accessories
Tl24 wiring diagram
1) Copy following link:
http://waterheatertimer.org/How-to-wire-timers.html
2) Add a comment Feb 2013 and describe timer in detail
Feb 07, 2013 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
Looking for instructions how to use Electric light Switch timers
Electronic timers are usually 7-day.
Usually a 24-hour timer has mechanical analog dial that rotates as time passes.
Copy following link for instructions by experimenting with features:
http://waterheatertimer.org/How-to-set-timers.html
There are many timers on the market today, including plug-in, box-type, timer modules, delay timers, indoor-outdoor timers, and knock-offs of each brand. Each has different watt load rating that usually appears on side of timer.
Some timers work with any type bulb, and others only with incandescent.
Copy following links to help identify timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
http://waterheatertimer.org/Woods-timers-and-manuals.html
Jul 26, 2012 | Hardware & Accessories
Hi I have got an EDAPT timer but no Manual. Not sure how to set it up. Could you please help?
EDAPT timer is 24-hour analog timer with segments located around timer dial and a slide switch located on side. Appears to be mains 240V timer.
http://www.thewarehouse.co.nz/red/catalog/product/Edapt-24-Hour-Timer-Analogue?SKU=767408
Instructions for analog timers appear on following link.
Aug 24, 2011 | Hardware & Accessories
Please e mail the intermatic timer instruction model# 59419 rosecthimote@aol.com
59419 is the Woods 2 pack plug in 24-hour dial timer with 2-prong outlet.
If this is not your timer, add a comment.
http://www.amazon.com/59419-Appliance-2-Prong-Outlet-24-Hour/dp/B002Y1KZHQ
See all Woods timers and manuals:
Manual for Woods 59419:
http://waterheatertimer.org/pdf/Woods-59419.pdf
Instructions:
Rotate dial until current time lines up with arrowhead located on inner dial
When plugged in, dial rotates
24 segments located around outer edge of dial; each segment is 1 hour
You have to pull these segments up using fingernail or small screwdriver
Segment pulled up = lights OFF
Segment down = lights ON
Override switch located top of timer, move switch to TIMER
Plug lamp into timer
Make sure lamp is turned ON
Plug timer into wall
Dec 04, 2010 | Woods Hardware & Accessories
I have basic timer # 15417. No instructions came with it and I don't know how to set it..
GE 15417 is electro-mechanical plug-in timer
GE 15417 GE15119 GE15131 are combined in one instruction sheet:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/15119-Manual-eng.pdf
1) Rotate dial until current time lines up with stationary black triangle located in center.
2) Segments around outer dial divide 24-hour day into 48 half-hours. Lift segments for times you want lights to be OFF. Segments down for times you want lights ON.
3) Slide-switch on side of timer is manual override. To use timer function, set switch to 'Timer ON'
4) Plug light into timer, plug timer into wall.
5) Maximum load is usually around 500Watts >> check markings on timer for exact load capability.
Nov 18, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
Intermatic ej351, i ned the instructions for resetting the timer. to turn it on at 630pm and off at 100am pleae
1) Use this procedure to automatically program, letting switch timer "record" ON/OFF activities over 24-hour period.
-Move control lever to OFF-CLEAR for about
20 seconds. Red indicator light goes off and previous
time settings are cleared.
-Move control lever to ON position. Red indicator
light starts flashing.
-At 6:30pm, manually press dial 'on' >>> then at 1:00am manually press dial 'off'
-At the end of 24-hour period, switch timer is programmed and Red indicator light will stay ON, indicating
switch timer is in AUTOMATIC mode.
2) Or you can manually program times using instructions from page 1 of manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
Sep 19, 2010 | Hardware & Accessories
There is also a way of setting it by simply turning the light on and off at the desired time. Can yu help?
Manual: http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
The manual says:
"To automatically program, letting the switch
timer "record" your ON/OFF activities over a 24-hour period,
storing them as programmed settings:
Move the control lever to the OFF-CLEAR position for about
20 seconds. The red indicator light will go off and any previous
time settings will be cleared from memory.
Move the control lever to the ON position. The Red indicator
light will start flashing.
Press the dial as an ON/OFF switch to turn lights ON and OFF
at the ON and OFF times you desire for the first 24 hours.
At the end of the 24-hour period, the switch timer will be programmed
and the Red indicator light will stay ON, indicating
that the switch timer is in AUTOMATIC mode."
Sep 17, 2010 | Intermatic Programmable 24 Wall Switch...
GE 24 hour programmable basic timer - how do i push the keys down. is there a diagram? I tried and tried. The product is the Basic Time.. no pin. #15119
So, this timer came with no instructions. What do you want for $3.99. Made cheap in China and instructions cost more than the timer.
The timer has a dial with tabs all around the 24 hour clock. They are in the down position which is on. You must pull all the tabs up in the times you want the timer off. This is different from all the other timers I have that used that have two removable tabs that are placed at the start and end times.
Put the switch on the side of the timer in the timer position.
Oct 06, 2009 | General Electric GE 24-Hour Timer, 2-Pin...
Hardware & Accessories Logo
93 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
