Question about Garden
What size fuelline does poulan 2700 chainsaw require
5 Suggested Answers
  • 2239 Answers
SOURCE: is there an easier way
It realy depends on what mahine it is and wheather it has a moulded hose or a straight hose, and what diameter the hose is, i have made a simple tool for straight hoses from a thin strand of piano wire,sharpen the end to a point, bent the end ( approx 2 mm ) over and back on itself tightly 180 degrees, make sure it is as tight as possible, connect a handle to the other end, now insert the hooked end through the fuel pipe hole in the top of the tank and out through the fuel filler hole, now connect the fuel hose onto the hook, pull it so the sharpened end makes a hole in the tube, now pull the wire back through, and with a bit of practice the hose should pull through, do not forget the trim the end of the hose where the hole was made.
Posted on Jan 20, 2011
  • 2239 Answers
SOURCE: poulan chainsaw / model p3416
There is no actual brand required, you need two stroke oil designed for use in a chainsaw to mix with the fuel at 25-1, try to get oil manufactured by a chainsaw company, and you need non fling chain oil for the oil tank at the front of the saw to lubricate the chain.
Posted on Jul 25, 2011
  • 2239 Answers
SOURCE: I need to know the file size to sharpen a Poulan
If it has 3/8 low profile chain as most machines do it will be a 5/32 file.
Posted on Jul 29, 2011
  • 252 Answers
SOURCE: what size of chainsaw file
hi there susan brown6
if your chain is a 3/8 lo pro chain the file will be 5/32nd ------- and if its a 0.325 size use a 3/16th file -------- or if its a 3/8 -0.58 chain use a 7/32nd file
but its more likly to be either 5/32nd( for 3/8 low pro chain ) or 3/16 th for .325 chain
cheers
pauly46
Posted on Sep 10, 2011
Fuelline diagram
Hi Rodney:
An interesting situation as having to replace all fuel lines is somewhat unusual.
If you google the model number along with "Parts Diagram" you may get lucky. Between the diagram and the saw you should be back to work in no time.
Jul 28, 2015 | Poulan Garden
What is the replacemnet cord size for my #pp5020av
www.ereplacementparts.com lists the part as Kit Rope 40" (Type 4.5)
Part Number: 530069919 Priced at $2.84 and if you need a new handle, it's only $2.73
The link is below.
http://www.ereplacementparts.com/poulan-pp5020av-stroke-gas-chainsaw-parts-c-16962_17147_162366.html
Aug 04, 2014 | Poulan Pro PP5020AV 50 cc Gas Powered...
I have a Poulan Pro PP4620 AVX 46cc Gas Chainsaw w/20
If this is the tooless adjustment, it sounds like the small gears in the cover have stripped, remove the side cover, turn it over and remove the cover over the tentioning mechanism, replace parts as required.
Apr 18, 2012 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
Poulan chainsaw / model p3416 16" manual What brand of motor oil is required for this saw?
Jul 24, 2011 | Poulan Garden
Poulan Woodshark 1950 14" Chainsaw Family: WPWES
Checked all the parts lists, they seem to use the same primer through all types no.s part no. 530047213.
Jun 24, 2011 | Poulan Garden
What file size do I need to sharpen chain
It realy depends on the type of chain you have fitted, hobby chain fitted to small home owner saws is normally a 3/8 low profile and requires a 5/32 file, slightly bigger machines have a .325 chain and require a 3/16 file, big machines have a standard 3/8 chain and require a 7/32 file, the correct file should fit nicly into the cutter and sit slightly abobe, this will stop you file under the cutter head and creating a hook.
Feb 25, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
