Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
D52w20 no color on full size screen
I turn on my tv and no colors whatsoever while on full screen but is i switch to PIP then I have colors except for red.
  • 1 more comment
  • juststoplook Jan 04, 2009
    the cables are plug in correctly in from both the antenna and composite
    neither antenna or composite work while on fullscreen only in PIP, i can only see some times red colors. i have check all settings
    of course it is the d52w20
  • 51 Answers
Sounds like a cable set not hooked up right. How are your cables hooked up?
Posted on Jan 04, 2009
  • 1 more comment
  • RFICKES
    RFICKES Jan 04, 2009
    Strange. Disconnect the composite set and use straight antenna, and report back. I have a feeling there's an option not set correctly on the composite set.
  • RFICKES
    What's the model number? This is under RCA D52W20. Is that correct?
  • RFICKES
    This is really strange, so I apologize if it sounds like I'm asking stupid questions...just want to make sure I'm not missing something. I've downloaded the owner's manual so I'm a little more familiar with the unit. So, let's try this....
    1. Can you bring up the menu on the screen, and if so, is it in colour?
    2. Do you have any devices, like a high-end DVD player, that have component out? Try hooking them into the unit, and see if you can get picture out of that.
    3. Are you using an HDTV tuner through the DVI? Does that work?
    If you could try those, and report back, it'll eliminate a few more possibilities. If not, it's starting to sound like the video board may be glitchy.
Why does my mitsubishi big screen tv keeps blinking
If its the lights by the on and off switches its the bulb,it should not have a picture maybe have sound only its around 40-80 dollars.Easy fix.if has picture a nd turns on and off its the color wheel
Jun 11, 2014 | RCA D52W20 52" Rear Projection HDTV-Ready...
My Rca 52 inch has lost color But If I set the feature
PIP means the set uses either two tuners or a dual tuner--could be a issue with the tuner. If it has a swap feature in the PIP use it to see if color when tuner is switched from main to PIP tuner.
A possible way around the issue is to look to see if rear audio/video inputs have color---you could route signal from a box etc to one of those and BYPASS the problem if rear inputs do not have this problem(not likely they will).
Jun 15, 2012 | RCA HD52W59 HDTV Projection Television
Blurred picture and colors. warped picture size
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some images of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Or goto the site www.TvRepairKits.com for the parts and instructions on how to fix it yourself.
Nov 28, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
How to reset tv. Have sound but black screen
LCD's use a colorful crystal see through display which only visible when light is shining through it. if you have sound and no picture it's always a faulty PSU. Very easy to change out actually.
Mar 27, 2010 | Vizio GV42L 42 in. LCD Television
My big screen tv show snow on all channels.
ok.
if you see only snow on the regular screen, might as well check the connecting antenna at the back since you mean all snow on all channels.
hope this helps.
Jan 17, 2008 | Akai PT4298HD Rear Projection Television
Color problems
green overpowering makes me think you have a crt problem. or even a bad blue or red crt.
Dec 18, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
52" RCA Projection TV
This is an indicates what is know as convergence problem...this could also be what is know as deflection problem... have a technician look at it.
Oct 30, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
NO Picture in Color except for PIP
have a tech check your tv the color circuit needs to be looked upon.good luck
Apr 29, 2007 | Akai PT5492S 54" Rear Projection...
Pip
On the front of the TV while it is on, press on the ACTION and POWER buttons at the same time and hold them for about 5 seconds until the screen goes blank and comes up with a diagnostic screen. Once that happens release them and press action again to clear the diagnostic information. Now your TV is se back the way it was brand new so you will have to proram the channels back into memory and apply your color,brightness,hue etc..settungs as those have all gone back to factory as well.
Mar 22, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Main screen color seems overmodulating. PIP subfeed color fine. White like under black light.
rule number one about all vs chassis with vertical can pip boards take them out and throw them away i could fix one but you couldnt beleive me and it wouldnt be worth your while do a search on your modle number until you come up with instructions on how to add two caps to the pip board connector to bypass it until you do this you are wasting your time Mitsubishi ... we're still building Zeros
Dec 08, 2006 | Mitsubishi VS-50705 50" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
