Question about Panasonic 47" Smart Viera ET5 Series LED HDTV - TC-L47ET5
How to connect my viera et5 series tv to my laptop
I have a new hp laptop running on windows 8 which id like to connect to my tv via viera link
SOURCE: Viera Link not work between two brand new Panasonic devices
You need to select setup from the TV menu then switch the Viera link on. I think retuning must have switched it off.
This worked for me
Posted on Oct 03, 2009
  • 126 Answers
SOURCE: How do I set up
Cliff, it al depends on what kind of DIRECT TV receiver you have, if it has an HDMI port on the back of the receiver then all you have to do is plug it in and change the input on your TV to HDMI
Enjoy thats a great TV
Posted on Dec 03, 2010
SOURCE: Panasonic Viera Link stop working
Hey, you're not the only one to have this problem. Please see also
http://www.fixya.com/support/t5668469-viera_link_stopped_working_stating
Hope someone can help us all!
Posted on Jan 25, 2011
SOURCE: I have a new Panosonic Viera TC-P54VT25.
I have had my Panasonic Plasma tv for 5 months there was a loud pop and the tv went off and now there is a red light blinking 10 times and the tv will not turn on.
Posted on Feb 06, 2011
  • 5477 Answers
SOURCE: what kind of wire do I need to connect my samsung laptop to panasonic viera hd 3d plasma tv?
Most TVs will have HDMI and RCA component and composite jacks. Some TVs will also have a VGA port. Your laptop will have a VGA port. (If the laptop is fairly new, it may also have an HDMI port.)
Not all TVs will support an HDMI signal from a computer, so the VGA signal is often better. However, that limits you to SD (anything with HDCP will fail.)
Very few TVs ship with the HDMI or component cables. However, there are some vendors who do package the HDMI cable with their TV. Without knowing which exact model of TV and laptop, I can only make a few suggestions. I know that the TCP42ST30 (Plasma 42") doesn't have a VGA port.
Look at your laptop for any external monitor port. VGA ports are generally blue female ports with 15 holes (D-Sub). If your TV has a matching VGA port, get a standard VGA monitor cable.
If you have the VGA port on the laptop but not on the TV, you can try a converting from VGA to HDMI. (You may need a DVI to VGA adapter and either a DVI to HDMI cable or a DVI to HDMI adapter.) Note: this gives an analog signal (RGB format) to the TV. You'll also need to make sure that your VGA port is active (in the BIOS for some computers) and then set your computer to send the signal to the external monitor. It is best to turn off both the computer and the TV before connecting the two. Then turn on the TV and set it to the correct input before turning on the computer. (In Windows 7, I set the video signal for the external monitor by right clicking on the desktop and selecting Graphics Properties. Set the signal to the external monitor and click Apply. Then click OK (in the external monitor's screen).)
If this doesn't work, you need a VGA to component video converter. (Not a VGA to component video cable - those are for projectors that read the RGB signal.) See http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215-p1.html .
Some laptops come with an HDMI, mini-HDMI or a DisplayPort option. For the latter two, you will need the appropriate cable with that end and the HDMI connector on the other. Then connect the TV and the computer as described above. (Note: my TVs accept a computer signal at the HDMI port labeled HDMI/DVI. However, you need to make sure that your TV understands this signal. It isn't the same format as that from a set-top box. My laptop has VGA and HDMI out; the desktops have VGA, DVI and HDMI (on one).)
If you add a comment with the model of your TV and laptop, I'll be glad to give you more specific options to connect the TV and the computer.
I hope this helps.
(A DVI port is a digital video out option with ~21 pins and is usually white.)
Posted on Feb 03, 2012
Horizontal lines on my panasonic lcd tv
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 01, 2016 | Panasonic 55" Smart Viera ET5 Series LED...
Tip
Stream AVCHD to VIERA TV via DLNA-Transfer MTS from Synology NAS to HDTV
HD Video Streaming from NAS to Plasma TV-Join MTS Clips without Re-encoding <br />How to Connect and Stream AVCHD MTS from NAS to HDTV via DLNA? <br /><br />I have Synology DS110+ NAS for storing and sharing movie collections, photos and music via home network. The Synology DiskStation Manager 2.3 was installed on Windows 7, and my Panasonic TC-P46S30 presents pretty good image quality. The 46" Class VIERA S30 Series 1080p Plasma TV supports AVCHD/MPEG2/JPEG/MP3 playback. While I try to do MTS <b><a href="http://www.aunsoft.com/final-mate/">Streaming MTS from NAS to Plasma TV</a></b>, I notice there is larger space between clips than the MP4 videos on NAS. <br /><br />I am not sure if it is because the decoding or streaming on HDTV that makes the differences. I would like to join the MTS clips into one large file, so that there could be less buffering notice for HD video playback. After google search, I find Aunsoft Final Mate as the fast <b>AVCHD joiner without re-encoding</b>. It keeps the native format without changing the file extension. Here I would like to share with you my experience with the Final Mate. <br /> <br /><b><a href="http://sony-mts-converter.com/2011/07/stream-avchd-to-viera-tv-via-dlna-transfer-mts-from-synology-nas-to-hdtv/">How to Connect and Stream AVCHD MTS from NAS to HDTV via DLNA</a></b> ? <br /><br />1. <b>Quickly import videos to Aunsoft Final Mate</b>. <br />Run Aunsoft Final Mate as the straightforward AVCHD merger. To <b>Import the videos from NAS</b>, just go to the Resource tab, and click the "Add file path" button to browse the folder with the AVCHD files on NAS. <br /><br />2. <b>Easy ways to join AVCHD files without re-encoding</b>. <br />For the first movie, just choose the clips from Resource tab, drag and drop to the timeline for lossless movie. To get another movie with different events, click the Create New Movie button to get new movie ID. Drag and drop clips to movie ID for a separate movie. You can also choose File &gt; Create A Movie for Lossless Output to get new movie ID. <br /> <br />3. <b>Get movie within seconds</b>. <br />Click the Export button under the volume settings, and click the OK button to start joining AVCHD files, removing the gap between clips. <br /><br />When the joining process is done, just <b>transfer the movies to NAS</b>, and use remote controller to <b><a href="http://www.aunsoft.com/final-mate/">Stream AVCHD to VIERA TV via DLNA</a></b>.
on Jul 04, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Im using a 2Wire Gateway DSL connected via ethernet to a Mac G4, I also have a laptop running windows vista and it has strong wi-fi connection, sending packets at optimal levels and speed. BUT Problem
Vista has a well known flaw of not allowing you to easily change access rights after selecting "public network" in the initial network connection screens. The easiest fix is to change the name of your wifi access point, reconnect, and be absolutely certain to select "home network" when the prompt comes up.
The best solution however is to ditch that crummy excuse for an operating system and upgrade to Windows 7 or 8.
Oct 05, 2014 | Computers & Internet
How to connect viera link
What is Viera Link? Viera Link allows the control of other Panasonic home AV devices via the television remote control.
By pressing the Viera Link button on the television remote, it is possible to turn on and navigate the menus of other Viera Link equipment. Please note, Viera Link requires an HDMI connection between the television and the external source.
More control functions have been added with each new generation of Viera Link compatible products. However, it is important to note that the newer functions only work if both products are from the same year of manufacture. Therefore, if an older source is used with a newer year of television, only the older functions common to both years will work.
Aug 26, 2014 | Panasonic Viera TH-42PX80U Plasma TV
Code for connect windows media center to tv
Instead of trying to connect this to your TV via 8-digit code, you should try running an HDMI cord from your computer to the back of your TV. Quality of picture is better, and it streams flawlessly.
Nov 24, 2012 | HP Computers & Internet
We have connected our asus K52J lap top to our panasonic viera plasma TH-P50V20A via a HDMI cable . We have picture ON THE TV but sound from our lap top only. How do we get sound from our TV
Hi there
I've just looked at that TV model, and it appears that your TV does not support a separate audio connection for HDMI sockets. It also appears that your laptop model has a issue with sending audio via HDMI. Are you running Linux, or windows?
Hope this helps
TV_Doctor
Jan 03, 2011 | Panasonic Viera TH-50PX80U Plasma TV
Connect lcd LE10 32'' model to laptop
connect them via HDMI. Audio and video from your laptop will go the TV. You need an HDMI cable for that connection.
cheers!
Jul 11, 2009 | Panasonic Viera TC-32LZ800 32 in. LCD HDTV
Panasonic viera doesn't display computer correctly
Right click onyour desktop and click properties (Windows XP) or personalize (Windows Vista).
Click the tab that says Settings(XP) or the link that says Display Settings (Vista)
Adjust your resolution by sliding the bar up or down until your dispaly matched the optimum resolution of your TV.
Dec 29, 2008 | Panasonic Viera TH-50PZ80U Plasma TV
SET UP VIERA LINK PANASONIC PT960
Can you explain a bit more please. What exactly is the problem? Are you getting any picture or audio through to the TV? Are you getting any picture or audio through to the home theatre? Have you got the home theatre setup via HDMI? Have you connected the audio from the cable to the home theatre via optical or phono? What model is your LG LCD HDTV?
I already have the manual in front of me for your home theatre system. If you can give me some more information I can help you out.
Thanks.
Nov 30, 2008 | Panasonic Home Theater System System
Panasonic 47" Smart Viera ET5 Series LED HDTV - TC-L47ET5 Logo
364 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
