Question about ASUS AMD 760 MP Chipset A7M266-D (A7M266-D/PA-UAY) Motherboard
My d drive CD-DVD ROM,has gone problem again with 3 others
Ive tried to install another 3 working d drive CD DVD-ROM,s bot they all power up but wont play or now more importantly do autorun to download new xp windows professionall and in the bios as it,s the 3rd one down in the boot order where it says CD-ROM,its showing none,now thinking back this is what was occuring with my original DVD-ROM,the screen said my files where corupt,no problem changing to a new hardisk install but how do i get the DVD-ROM, to play and autorun and be recognised in the bios in the boot sequence instead of showing up as none,is there a setup i have to do to activate it to work another CD-ROM,d drive on my computer which is a duo core asus tower motherboard is a AMD motherboard asus code is,A7M266-D,any help a.s.a.p./i would be greatlull in advande for,many regards,garnedd
  • Alan Jones
    Alan Jones Feb 04, 2009
    thank you ericram for your good presented advice which managed to solve my problem 100% many regards gor your time to help me,garnedd
    Novelist:
  • 101 Answers
First of all, here is a link to download the ASUS A7M266-D manual in PDF format:)
http://www.unitycorp.co.jp/support/download/manual/a/a7m266_d_e.pdf
The CD/DVD must appear in the BIOS before it will be seen and used by Windows. There are two reasons it (they) might not be seen. There is a jumper pin block on the back of each CD/DVD to designate Master, Slave or Cable Select. you must move the little plastic jumper clip to the correct position. If you are using a 40pin IDE cable, the top drive should be Master and the bottom drive should be Slave. If you are using the newer, smoother 80pin cable then both should be set to Cable Select. Having the jumper in the wrong position will prevent the IDE controller from sensing one or both of the drives as the signal will get confused in the cable.
Next you have to change a BIOS setting to inform the system that you now have a new device on that channel (unused channels are usually defaulted into the NONE or AUTO position so you do not get a device missing error message on startup). This is where the manual comes in. The specific instructions for the Award BIOS in you system are found on page 48 of the manual.
If you are just replacing the original CD/DVD, it should be in the Secondary Master channel. If you are adding a second drive then your new CD/DVD will be in the Secondary Slave channel, which you should change from NONE to AUTO. You will have to reboot for the change to take effect. Go straight back into the BIOS to verify that the added drive is recognized (the BIOS should list the drive type and information). Once you can see it on the BIOS screen, Windows will recognize and automatically configure it.
Now, as for your Windows saying the drivers are corrupt, that is a different problem which usually happens after removing software to burn CDs/DVDs. It is not an uncommon problem. I believe a link that describes your problem and solution is here:)
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Finally, you mention XP Professional like you are going to reinstall your hard drive. It may not be necessary unless you are doing it "just because". If you have/had XP Home on the hard drive, you will have to do a full installation for Professional, you will lose all data and programs, AND you will need to locate the correct drivers for your system to get all the pieces to work. You will also need an XP Professional COA to activate the new operating system, as you cannot activate Professional with a Home edition key.
For most users, there is no advantage in using Professional over Home edition (there are some new features used for networking, remote desktop, etc. that single machine home users just do not have reason to use). If you are installing Pro just to fix your DVD problem, it is probably unnecessary.
Please comment with your results.
Posted on Jan 04, 2009
Cd rom on windows XP wont work?
how old is the computer cd rom might be time for new one
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
or
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it if this fails you might try cleaning the lens it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the ac power 3. remove power cable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected
hope this helps
Jun 12, 2012 | Computers & Internet
Hello felows ,, i have a XP lap top ,, my problem is that the cd drive reads dvd , cd -rom , audio cd ,, but when i put a dvd - raw , it wont read it ,, the cd is a hp deskjet 2050 j510 series to...
No all cds/dvd work in all cd/dvd drives. I suspect your drive cannot read that make of cd although anothers cd rom can. Try making a copy of the disk on someone elses pc and try that in yours and you will probably find it works. You could always copy the cd to a pen drive and install it on yours from that.
Jun 03, 2011 | Computers & Internet
Dvd drive noisy put in dvd go to my computer driver is showing but wont play driver ejects
1. Try a different cd or dvd to see if it's reading any dics
2. Boot computer and try again
3. Uninstall the dvd drive from your computer (windows xp machine) , Right-click "My Computer-icon" -> Manage -> Device Manager -> DVD/CD-rom Drives -> right-click and select uninstall Restart the computer and it should install the drive again automatically Try reading the discs again
5. Update driver if available, see manufacturers website for driver updates
6. Try the dvd drive in another pc (if possible)
7. Propably faulty drive, replace the drive with a new one
Mar 06, 2011 | Computers & Internet
My cd-rom is missing in my computer system
Hello, Please you will fit the sata/pata cable tightly in your cd/dvd RW
If it will face same problem install a new cable if you have spare cable.
Same as before
Alternative Start Mode
1. Re-boot PC, as it starts tap F8 several times until the windows boot window appears.
2. Scroll to "Start with last known good configuration.)
3. Press "Enter"
Or
2. Scroll to "Safe Mode" (With networking, if you want to access the internet)
3. Press "Enter"
System Restore
1. Go "Start"
2. "All programs"
3. "Accessories"
4. "System tools"
5. "System Restore"
6. ensure "Restore to an earlier time" is checked and click "Next"
7. Select an earlier date when your PC worked well. (Must be a highlighted date)
8. Click "Next"
9. Allow system restore and reboot
It could be a problem with the lens, you should try cleaningthe lens, it's already gone bad there is no harm in trying
If it doesn't work, you can either replace the lens or purchase a new DVD/CDdrive Hope it will help you Don't forget to vote me
Dec 24, 2010 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Wont read dvd video discs
1st step; Acquire/buy a cd/dvd rom drive cleaning tool kit from your local pc store.
2nd step; Install a dvd coder/decoder software, try Power DVD player software it has a trial version
3rd step; After installing the DVD coder/decoder from Power DVD player try playing a dvd movie rom disc it should work/play... hope these tips help ;-)
May 24, 2009 | LG GMA-4020B Super-Multi...
Dvd rom not working
please uninstall the driver and then unplug the dvd rom and then restart the system and then install again all things new.ok
May 15, 2009 | E-Machines emachines (emachinees) CD-ROM...
Toshiba tecra m2v s330
Try borrowing a compatible HDD instead of buying a third one for testing and check if the same error exists. Try also using an external DVD drive to see if your internal CD-ROM is defective. Try also using another Windows XP CD installer. You can also use other OS installation CD to check it. Otherwise, there is something wrong with your lappy's motherboard due to tear and wear, heat, vibration, misuse and shock.
Mar 20, 2009 | Toshiba Tecra M2V-S330 Notebook
Unit will not boot from cd/dvd, drive test good.
The main programing on the motherboard (bios) should recognize and read from the CD drive, If it doesn't then there is three possibilities as to the problem. 1- the bios have glitched, so, start by doing a bios flash. 2- the optical eye or the reader board in the CD drive has gone out, and the drive will need replaced, 3- there is a malfunction with the motherboard, and the board will need to be replaced. These three are the only possibilities and fixes for this problem.
Jul 26, 2008 | IBM ThinkPad 600E 2645 Notebook
DVD DRIVE/CD-WRITER
GO TO CONTROL PANNEL
SYSTEMS
HARDWARE
DEVICE MANAGER
CLICK DEVICE MANAGER(WINDOW)
EXPAND CD /DVD ROM DRIVES
RIGHT CLICK ON SELECTED DVD/CD DRIVE
SELECT PROPERTIES
1.SELCT DRIVER ( CLICK UPDATE DRIVER)
2.CHECK DVD REGION CODE.
3.UN-INSTALL DRIVER
4. REINSTALL DRIVER AGAIN(AFTER STEP 3)
OR
IN DEVICE MANAGER RIGHT CLIVK DVDCD ROM DRIVE
UN-INSTALL DRIVER
OK
REBOOT COMPUTER
ADD HARDWARE(CONTROL PANNEL)
IT WILL PROPMPT FOR INSTALLATION OF DRIVER
SAY OK.
PROCEED WITH WINDOW INSTRUCTIONS
DVD/CD ROM DRIVER WILL GET INSTALLED AFRESH.
HOPE IT WORKS.
Jul 01, 2008 | Computers & Internet
Dvd-rom icon missing
(1) Check bios for detection if detected continue the following steps else DVD is gone or you can remove test it in other system.
(2) You can manually DVD from control panel by clicking add new hardware wizard, continue the step.
(3) last option try install your operating system agin.
Apr 19, 2008 | Panasonic Matshita- | CW-8124-B | USB 2.0...
ASUS AMD 760 MP Chipset A7M266-D (A7M266-D/PA-UAY) Motherboard Logo
165 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
