Question about Panasonic PT-61LCX65 61" Rear Projection HDTV
I have spots on my 61 inch panasonic - Panasonic PT-61LCX65 61" Rear Projection HDTV
  • 51 Answers
The lens on the projector is dirty, or on the reflector surface. Refer to the manual for cleaning instructions.
Posted on Jan 04, 2009
3 Suggested Answers
  • 17 Answers
SOURCE: Blue and Pink spot on my Panasonic Projection LCD
Panasonic didn't release a 61" LC13, are you sure that you dont have a PT-61LCX65, 35 or 15. If your model ends with a 5, call 1-800-211-PANA (7262) to schedule service, they have a fix fuzzy the fuzzy colored spots they are covering under warranty.
Posted on Sep 22, 2009
SOURCE: Color spots on 61" LCD Panasonic rear projection tv
rowdie1 is correct. You just need to call panasonic (number on website). Have your model and serial number handy. You have to go through several holds but you will eventually get scheduled for a service call with local authorized dealer. Tech takes the back cover off and plugs in a eprom reader/writer. Turns on TV. I sit and watch the dot go away after about 4 minutes. He lets it run for about two more minutes then all done. On service ticket is says "installed corrections". And best of all, no charge!
Posted on Jul 22, 2010
Colour spots on pt-61lcx65-k panasonic tv
Need to have a service tech come out and calibrate the TV. I had spots on my screen and the tech came out and hooked his computer up and calibrated it and it worked fine afterward.
Feb 24, 2013 | Panasonic PT-61LCX65 61" Rear Projection...
I have colored spots appearing on my screen when the TV is on. The spots are 2 to 6 inches in diameter and always appear in the same locations at various places on the screen. The first spots I noticed...
the light engine (optical block) is failing. there are lcd panels and light filters in the light engine. the problem your having is that they over heated and the image is burnt into the lcd or light filter. my be caused by a failing fan or just it's life span. the lcd panel or light filter are done for. you can keep calling panasonic and bug them over and over and they may send you a new tv. sony sent me one after 5 phone calls. i had the same problem. hope this helps.
Jan 14, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic pt-61lcx65 green spot
This may be a main board issue if the green spot moves. This is repairable. This may be a panel issue if it does not move and it is present on the panasonic splash screen and if it affects the osd menu.
Jul 29, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
Sep 10, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Green and purple spots on my screen.
This unit requires the EEPROM correction tool Part # LSUQ0100.Only an authorized Panasonic service center will have this tool.
Jan 14, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Green spot / glow in center left side of Panasonic PT-61LCX65 LCD Projection HDTV
This unit has a chonic issue with corruption in the eeprom that causes spots and shadows. The correction is to find some service center that has the jig to hook up to your unit and correct the eeprom. This is an extended warranty issue with Panasonic and if you contact them they should be able to refer you a qualifed service center and Panasonic will pay.
Apr 06, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Green & red spots
The eeprom on this unit becomes corrupt and Panasonic has a jig that hooks up to the unit and corrects the problem. This problem has an extended warranty and you should call Panasonic and have them refer you to a service center to correct the problem and Panasonic will pay for this.
Mar 19, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
had the same problem on my 52" LCD rear-projection Panasonic,
contacted Panasonic support (number is on their website) and after
several transferred calls, they set up a service call with an area
service rep, who callled the house that evening to confirm appointment.
He came to the house, removed the set back cover, and installed an
EEPROM upgrade, problem is fixed and was told problem will not re-occur.
No cost due to Panasonic extending the warranty to fix known issue with
sets. (Mine was over 3 years old).
Mar 11, 2008 | Televison & Video
HELP Green spots
"eprom upgrade" by a Panasonic tech will solve your problem...
Dec 27, 2007 | Panasonic PT-61LCX65 61" Rear Projection...
Green spots
have you tried doing convergence from the menu? and them magic focus?
Oct 22, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Panasonic PT-61LCX65 61" Rear Projection HDTV Logo
134 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
