I have Canon ir 2535 i recieve this message: Remove the paper from output tray, but i don't see any paper jam, i removed the paper tray and it still didn't work. any solution
  • 2072 Answers
SOURCE: rx tray full remove paper
That is an easy one.
Look into the area where the paper comes out. You have to look toward the upper rear area rear area. There is a white plastic flag, about 2 inches wide and 1 inch in height.
On each side of it you will see 2 areas where the shaft snaps into, that flag has popped out of those clips and is not seeing the sensor making the machine think there is a piece of paper in the output tray.
Reach in and gently maneuver that back into position and carefully snap it back into place.
That is an odd shaped actuator you can't see, but with some patience you can snap it back into place. Maybe also gently take a pair of needle nose pliers and slightly tighten those clips that it snaps into. I suggest that with a lot of concern so that you do not snap the plastic clips, they are part of the frame that if broken would be expensive to replace. Use your discretion as to whether they need to be tightened. If it snaps back in and feels solid DO NOT try to tighten them please.
Posted on Jan 03, 2008
Cogz
  • 1326 Answers
SOURCE: Canon PC 1060 error code E-002-000
A E002-000 is fixing unit error code. It is a power problem with the fixing unit. When you removed the paper jam did you see any piece of a blackish grey plastic pieces. If so you need to replace the fusing unit and or the upper fixing film..
Posted on May 11, 2008
SOURCE: GESTETNER DSc323 - SUPER G3
If you look at the paper exit you will see 4 white exit wheels
in the middle of the 2 center ones you will see that there is a black
lever. This needs to be pushed back into position so that it is horizontal to the exit wheels.
Hope this helps regards
Myott
Posted on Jun 01, 2008
solofixya
  • 34 Answers
SOURCE: Canon PC 1060 has a paper jam that we can't get to
It sounds like the paper jam is in the fixing assembly, and you can not access it unless you take it to a service center for canon products.
Posted on Nov 10, 2008
  • 148 Answers
SOURCE: How to remove the scanner unit on Canon PC1060
you sould not have to remove the scanner unit to clear a jam in the fuser
open all doors and remove anything marked green
remove the the cartridge assembly if it will come out
open the fuser section (usually a release that takes pressure off of the fuser rollers
remove the paper feed cartridge
you now should be able to follow the paper feed path from the time paper goes i until it comes out
if you are not sure of path take a piece of card stock and simulate it goig through feed ara
there are small microswitches/ poto eyes that sense paper lok for an small pieces also clean thes poto eyes with q tip and rubbign alcohol
reassemble
unlug from the wall then plug back in and turn on p roblem sould be solved
Posted on Jan 05, 2009
Says paper out or paper jam which nither are happening
  1. Unplug the power cord.
  2. Check to see if the print carriage moves freely from one side of the printer to the other. ...
  3. Remove the print cartridges. ...
  4. Gently move the print cartridge to the far right of the printer.
  5. Remove the paper from the paper In tray, but do not remove the drawer.
  6. Step one: Clear the paper jam from the output tray
    1. Carefully remove any loose paper from the output tray.
    2. Check the rollers in the output tray for jammed paper.
    3. Use a flashlight to see the rollers in the printer.
      Figure : Use a flashlight
    4. Gently remove any jammed paper or bits of torn paper from the output tray rollers. Use both hands to pull out any whole sheets of paper to avoid tearing them.
    5. Remove any bits of paper or torn pieces of paper from the output tray rollers.
    Step two: Clear the jam from the input tray
    1. Press the Power button to turn off the printer.
    2. Disconnect the power cord from the rear of the printer.
    3. Remove all paper from the output tray.
    4. Raise the output tray.
      Figure : Raise the output tray
    5. Grasp any jammed paper in the input tray with both hands, and then pull the paper slowly but firmly toward you to remove it.
      CAUTION: Remove paper from the tray as carefully as possible. If any torn pieces of paper remain inside the printer, more paper jams are likely to occur, and this could damage the print mechanism.
    6. Lower the output tray.
    7. Reconnect the power cord to the rear of the printer.
    8. Press the Power button to turn off the printer.
    If you are not satisfied with this answer then for detail answer please read here > http://www.brotherprintersupportnumber.com
Feb 14, 2016 | Epson WorkForce Pro WP-4540 Color Ink-jet
Canon ir 2520 error code
Remove the peper the output tray
Nov 19, 2013 | Office Equipment & Supplies
My printer says I have paper jam, please remove. but i have only been able to remove partial pieces. How do I get at the rest left in a spot I can not reach
Here's a link from which you should be able to download the online manual with a troubleshooting section that includes specific instructions on clearing a paper jam. See also this page, as I have no great confidence in the links I get from canon, their website is so backwards. If you choose the service and support option, then ask "how do I clear a paper jam" you'll see the instructions they offer.
Issue: Paper is jammed inside the printer
Solution: Remove foreign object from paper feed area (MP130)
Remove foreign object from paper feed path If error message
  • [PLEASE CLEAR PAPER JAM AND PRESS [OK]] or
  • [CHECK PRINTER]
is displayed, follow this procedure to remove paper or obstructions from the machine. Clearing Jams In The Paper Output Tray:
  1. Gently pull any jammed paper out of the Paper Output Tray.
  2. Press .
  3. If you cannot see any jammed paper in the Paper Output Tray, remove it from the machine's interior.
    1. Press to power off the machine.
    2. Lift up the Scan Unit until it locks into place.
    3. Open the Paper Output Tray.
    4. Look in the print area for an obstruction (such as a paper clip, staple, tape, etc.) and then remove it.
  4. If you are printing from an application software, follow the instructions displayed on your computer.
Clearing Jams From The Auto Sheet Feeder:
  1. Gently pull out any jammed paper from the Auto Sheet Feeder.
  2. Press .
  3. If you are printing from an application software, follow the instructions displayed on your computer.
Sorry I can't offer you much more, but just try to get all the bits out. Sometimes a pointy tool on a vacuum will help. Otherwise, maybe you can wrap and tape a post-it note around a popsicle stick or something to reach the paper and try to coax it out, or maybe a bit of folded tape on the end of a ruler or something like that. Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 02, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Canon printer mx328 is when i scan it display ''the paper output tray'' what mean and how to clean it. Please help.
Hi
If the Paper Output Tray is closed, open it. The machine resumes scanning.If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
Cheer
Jul 12, 2011 | Canon PIXMA MX310 All-In-One Printer
Blicking light canon d480
try this
Turn off the printer.
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Also open the back cover of the printer if this model has one.
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 18, 2011 | Canon imageCLASS MF3240 All-In-One Laser...
Canon ir400 paper jamming at heater section
just remove the cartridge and remove the paper essay
if you don't know how to remove the cartridge just see the user manual booklet or download user manual from cannon website for proper model printer user manual
Apr 16, 2011 | Office Equipment & Supplies
What does e073 0003 error mean on canon 1180.
E, 0, 7
FINE Cartridge is not installed in the correct position
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
E, 0, 3
Summary
Techbelkin please rate me
Nov 03, 2010 | Office Equipment & Supplies
Error e03, but there is no jammed paper
E, 0, 3
Summary
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
How do I remove paper jamed in the printer?
Paper Jam :
Cause 1 : Paper jammer in the Paper Output slot or the Rear Tray.
Action : Remove the paper following the procedure below.
a) Slowly pull the paper out, either from the Rear Tray or from the Paper Output Slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, turn the machine off, open the Scanning Unit (Printer Cover) and remove it.
Be careful not to touch the components inside the machine.
After removing all paper, close the Scanning Unit (Printer Cover), and turn it back on.
*If you cannot pull the paper paper out, turn the machine off, and turn it back on. The paper will be ejected automatically.
b) Reload the paper in the machine, and press the OK button on the machine.
If you turned off the machine in step a), all print jobs in queue are canceled.
Reprint if necessary.
If you canot remove the paper or the paper tears inside the machine or if the paper jam error continues after removing the paper, contact your Canon Service representative.
Cause b)Landscape credit-card-size paper jammed inside the machine.
Action : Do not load credit card-size paper in landscape orientation.
Slowly pull out the paper from the Tray and remove it.
If you canot remove the jammed paper or if the paper jam error continues after removing the paper, contact your Canon Service representative.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Nov 25, 2009 | Canon PIXMA MX300 All-in-One Printer
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
159 people viewed this question
jasbo
jasbo
