Question about Bosch 22 in. SKT5002GB Built-In Dishwasher
Bosch SKT5002, My dishwasher's sprinkler is not rotating because the pressure is weak. What can I do to fix it?
5 Suggested Answers
BIKER T
  • 909 Answers
SOURCE: Bosch Dishwasher with very little water pressure or power
It all stems back to your incomming water supply. Either the sieve is dirt or the valve is blocked with sedementation. Some valves are servicable and some are not,if your valve has screws then its revicable. (low water pressure restricts movement on arms.)
Posted on Sep 18, 2009
Macmarkus
  • 2605 Answers
SOURCE: SHE68MO6UC does not wash
Hi, welocome to fixya. By the description you've provided, it sound's like the wash motor is either seized or just stuck, let's hope it's the later. Bosch had issued a service tip about this problem several years ago titled "Loosening Frozen Impellers" strange choice of word's considering nothing is froze..at least you'd hope lol. Essentially what it say's is this...Remove the pump fitler ( inside the tub under the bottom rack ) locate the hole to your right down in the sump well, you should be able to see it with a flashlight so it's a well lit area. Once you've located this hole ( it's providing access to the wash impeller without pulling the unit from the cabinet ) reach in with a 8mm nut driver and locate the end of the impeller and turn it clock-wise until it feel's to turn freely. Give it a test perhaps in a rinse cycle before you put all the filter and screen back together. It should be fine unless the motor is seized, we'll cross that bridge when we get to it, try the repair tip for now. Let me know how that help's and/or if you need further assistance. Thank's for visitng "fixya" for you repair tip's. If this is indeed helpful please rate the solution accordingly, if not, again please let me know. Thanks again and good luck. Macmarkus :)
Posted on Jun 05, 2010
  • 403 Answers
SOURCE: top arm stopped rotating on Bosch clasixx
not worth fixing, you are better off putting that money towards a new one. unless you can find the arm and repair it yourself
Posted on Nov 27, 2011
ercupa190
  • 12223 Answers
SOURCE: Door of detergent holder on Bosch dishwasher won't shut. It just pops open. Is there an easy fix?
Proceed with this step:
Timer
check the timer, and the linkage see it is defective.
Bi-metal switch or wax motor
test the swithc or the motor for defective.
Detergent cup, itself
can be clogged, for to open.
sincerely. God bless you.
Posted on May 07, 2012
Arms have stopped rotation. How do I adjust to speed up rotation?
Sounds like lowered water pressure, or plugged inlet screen at sprinkler or hose, Or City has reduced pressure. Or trash in the outlet nozzles themselves, or It's been dropped and bent. Or?
Jun 07, 2015 | Mintcraft 631739 3-arm Rotary Lawn...
Top arm stopped rotating on Bosch clasixx
Nov 10, 2011 | Bosch 24 in. SGS43C12 Classixx...
Have 5 199LMHS sprinklers with 3 prong base. 3 of them spray, but do not rotate. Very stiff with water pressure, but free with water turned off.. How can I repair?
sometimes if the water pressure to rotating sprinklers is too high, they won't work due to to much force ,, your system should be running between 50 and 70 PSI tops, if its more than that you need to add a pressure regulator to your system
Jul 15, 2011 | Gilmour Garden
I have a bosch dishwasher, the arms are clear with water coming out but not spinning. how can I fix this?
water coming out of horizontal holes is not enough to rotate arms remove them and check the outermost holes these are angled so they rotate the arms they will be blocked even though all the others are clear.
Feb 15, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Sep 18, 2009 | Bosch 24 in. SHX46B05 Stainless Steel...
Spray arms do not rotate with only a little water pressure
You can buy a repair kit for your spray arms from an appliance parts store
Aug 24, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Impulse sprinklers stick after cloclwise rotation; no return
i wouldbet it is a pressure related problem , can you isolate them so you are only running 1 at atime? at least reduce the number of sprinklers running at the same time just to test them, drop the number by1or2 and i`m sure your problem will be fixed youdoit
Jul 22, 2009 | Orbit Sprinkler System Power Source...
... calling Master_Tech Bosch Dishwasher SHU43C07UC
Hello Mary, I checked on your dishwasher and what you have is a pressure fill dishwasher. This unit has a pressure switch to make sure the water level is correct. When the dishwasher is full of water (the indention that is around 2 inches in from the side walls and front) is where the water level should be out to. If the water isn''t out this far, then the pressure switch is shutting off early and not filling properly. I read your entire essay, it is perfect, so this sounds like an issue of either not enough water, or the circulation pump impeller has separated and not creating enough water pressure at the wash arms. Since you stated that you removed and cleaned the filters, that shouldn't be the issue. That is normally where I find this issue at is clogged filters, espically in hard water. I have seen results in the pass where too much detergent was used causing the pressure switch to shut off early. In those cases filling the detergent dispenser with cooking oil and running the longest cycle removes the excess detergent. It is proteins that the detergent is designed to break down. So quit worring about your water pipes, the issue is with the dishwasher. Hope this helps.
Feb 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 22 in. SKT5002GB Built-In Dishwasher Logo
61 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
